Cross Formation
Started by Dracos, September 15, 2010, 12:41:49 PM
Sep 14 19:26:15 <Kotono>   Thus the party is rested, recovered and ready to go. The last door in the warm room looms!
Sep 14 19:26:28 *   Kamvakua tugs it open.
Sep 14 19:26:44 *   Mari wakes up and gets ready for another day of traveling through the freezing wastes. But you know...There is an unopened door right there. It'd be a shame not to at least peek inside before leaving, right? Mari walks over next to Kam to look inside.
Sep 14 19:27:17 <Kotono>   The door opens! Ahead is a stairway winding up 20 or so feet to another passage.
Sep 14 19:29:03 <Mari>   "Up, huh? Anyone think this might lead to the surface?" Mari takes a brief stroll up the stairway, just to get an idea where it goes.
Sep 14 19:29:06 *   Nikkolai peers through the press of bodies at the stairway. "Well. If you wish to take a closer look, I'm all for it. But personally, I want to move on as soon as possible. We have work to do and...people are waiting for me." Nikkolai adds after a slight pause.
Sep 14 19:29:31 *   Adail nods, "Hopefully it will. It needs some way of getting to the surface aside from random cave-ins."
Sep 14 19:29:56 <Kamvakua>   "It's a long walk back anyway.  Doesn't hurt.  Unless it does."
Sep 14 19:30:03 *   Kamvakua takes a moment to heal himself on that note.
Sep 14 19:30:10 <Kamvakua>   roll 1d8+4 CLW on Kam
Sep 14 19:30:11 <Kotono>   Mari goes up! It goes up to a short hall, leading to a single door ahead. This is a plain door carved out of the icy walls.
Sep 14 19:30:18 <Knight>   "That is not quite what 'all for it' means, I think," notes Knight, reading a complex-looking tome full of schematics and diagrams.
Sep 14 19:30:25 <Kamvakua>   roll 1d8+4 CLW on Kam
Sep 14 19:30:26 <Hatbot>   ACTION --> "Kamvakua rolls 1d8+4 CLW on Kam and gets 7." [1d8=3]
Sep 14 19:30:34 <Kamvakua>   roll 1d8+4 CLW on Kam
Sep 14 19:30:35 <Hatbot>   ACTION --> "Kamvakua rolls 1d8+4 CLW on Kam and gets 5." [1d8=1]
Sep 14 19:30:40 *   Nikkolai shrugs. "Any direction up is an improvement." Nikkolai is right behind Mari!
Sep 14 19:31:27 *   Mari opens the door! If it can be opened, at least.
Sep 14 19:32:08 <Kotono>   The party heads along to the door. It's a door, nothing dreadful happens on approaching it. On opening the door you see a long walkway of ice. It hovers over a vast, dark pit deeper than you can see. The walkway is 10ft wide, going on several hundred feet.
Sep 14 19:32:47 *   Mari peers down. "On second thought, let's go back and do some climbing?"
Sep 14 19:32:56 *   Kamvakua looks across it to see if there's a way up at the other end.
Sep 14 19:33:09 <Knight>   "I am not finding myself eager to cross this chasm," speaks up Knight. "It reeks of danger."
Sep 14 19:33:11 <Kamvakua>   "Yeah.  We agreed we'd turn back if it looked like more death traps."
Sep 14 19:33:15 <Kotono>   The other end is hundreds of feet away. You can distantly see another door at the far end.
Sep 14 19:33:16 *   Nikkolai raises an eyebrow. "I'm glad I'm not afraid of heights." He comments, setting out across the bridge. "Come on! It's not *that* thin.*
Sep 14 19:33:43 <Mari>   "No, but it's made of *ice*. Get back here, you nitwit!"
Sep 14 19:34:14 *   Adail shakes his head, "I can go ahead to check this out if you'd like. But turning back works just as well. And yes, it's not the thickness but the traction that will likely be the problem, Nik."
Sep 14 19:34:40 *   Nikkolai is certainly not going to listen to anyone who calls him a nitwit. There wouldn't be a bridge of ice there unless it was meant to be crossed!
Sep 14 19:34:57 <Kotono>   OOC: Make a balance check, Nikkolai. Since you lack ranks I think, that's probably a straight dex check.
Sep 14 19:36:14 <Nikkolai>   roll 1d20+4
Sep 14 19:36:15 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+4 and gets 11." [1d20=7]
Sep 14 19:36:38 <Kotono>   roll 1d100
Sep 14 19:36:38 <Hatbot>   ACTION --> "Kotono rolls 1d100 and gets 2." [1d100=2]
Sep 14 19:36:58 <Kotono>   Nikkolai keeps his balance and proceeds on, ignoring the rest of the party. The bridge seems stable, the sorcerer making it to the other side safely enough. The door is another carved out of ice he can see.
Sep 14 19:37:37 <Mari>   "You know you're gonna have to walk back again, right Nik?" Mari calls out over the abyss.
Sep 14 19:37:40 *   Nikkolai waves his hand and calls over, "Come on, already! You want to get out of here, don't you~?"
Sep 14 19:38:19 <Adail>   "Except that we have no way of knowing if that even is the way out." Adail sighs. "We have a way out back the way we came, let's make use of it."
Sep 14 19:38:30 *   Kamvakua doesn't show any sign of moving.
Sep 14 19:38:35 <Knight>   "Should I go and pick him up?" asks Knight, tapping her foot the pedals of her horse. "Honestly..."
Sep 14 19:38:52 *   Nikkolai trots over to the door, to at least see what lies beyond it.
Sep 14 19:41:13 <Kotono>   The door opens! As it does, a great chime sounds! The sound is loud and echoing! In that echo the walkway breaks out into cracks, all but the ends shattering into a collapse of ice below into the depths! Beyond the door lies another stairway ascending up.
Sep 14 19:41:33 <Kotono>   OOC: Make a spot check, Nikkolai.
Sep 14 19:42:05 <Nikkolai>   roll 1d20 Spot!
Sep 14 19:42:06 <Hatbot>   ACTION --> "Nikkolai rolls 1d20 Spot! and gets 1." [1d20=1]
Sep 14 19:42:12 <Kotono>   OOC: Roll 1d20-20.
Sep 14 19:42:37 <Nikkolai>   roll 1d20-20
Sep 14 19:42:37 <Hatbot>   ACTION --> "Nikkolai rolls 1d20-20 and gets -12." [1d20=8]
Sep 14 19:42:42 <Kotono>   OOC: Carry on.
Sep 14 19:43:33 <Knight>   "Nikkolai! I'm coming to get you! Try not to break anything else!" yells Knight! Gusts of steam blow out the vents in her metal horse's hooves, prompting it to levitate a foot off the ground before it jets forward, across the chasm!
Sep 14 19:43:35 *   Nikkolai blinks, winces, and then looks behind him at the shattered walkway. He sighs. "These stairs go upwards!" He calls out to the others.
Sep 14 19:43:36 *   Adail nods to Knight, "I think that would be for the best at this point."
Sep 14 19:43:56 <Kotono>   OOC: What's your fly speed, Knight?
Sep 14 19:44:00 <Knight>   OOC: 90ft
Sep 14 19:44:18 <Mari>   "Did you miss the part where the bridge just broke?" Mari yells over the gap. "I've had enough traps, let's just go!"
Sep 14 19:44:33 <Kotono>   KNight flies 180ft ahead, roughly halfway over the abyss! As Nikkolai looks ahead, suddenly...
Sep 14 19:45:01 <Kotono>   roll 1d20+14 flatfoot AC, Nikko?
Sep 14 19:45:02 <Hatbot>   ACTION --> "Kotono rolls 1d20+14 flatfoot AC, Nikko? and gets 19." [1d20=5]
Sep 14 19:45:19 <Nikkolai>   OOC: 20~
Sep 14 19:45:56 <Kotono>   A whizzing of air and tremendous force hits right besides Nikkolai! He can see something white against the white ice and dim light, but can't make it out! OOC: Init. Knight and Nik roll. If any of you feel you can do anything useful you can roll as well, though if not just railbird and call over.
Sep 14 19:46:11 <Kotono>   roll 1d20+5 ????
Sep 14 19:46:12 <Hatbot>   ACTION --> "Kotono rolls 1d20+5 ???? and gets 25." [1d20=20]
Sep 14 19:46:18 <Nikkolai>   roll 1d20+8+5 Nerveskitter, baby
Sep 14 19:46:19 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+8+5 Nerveskitter, baby and gets 30." [1d20=17]
Sep 14 19:46:22 <Knight>   roll 1d20+1 what
Sep 14 19:46:24 <Hatbot>   ACTION --> "Knight rolls 1d20+1 what and gets 13." [1d20=12]
Sep 14 19:46:33 *   Kotono has changed the topic to: Nikkolai(30)>????(25)>Knight(13)
Sep 14 19:46:36 <Adail>   roll 1d20+8 surely I can MM from this distance if I see an enemy
Sep 14 19:46:36 <Hatbot>   ACTION --> "Adail rolls 1d20+8 surely I can MM from this distance if I see an enemy and gets 26." [1d20=18]
Sep 14 19:47:02 <Kotono>   OOC: Act Nikko. Adail, the MM range is 100 + 10ft level, and the gorge is several hundred feet long.
Sep 14 19:48:21 <Kamvakua>   roll 1d20+2
Sep 14 19:48:23 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+2 and gets 5." [1d20=3]
Sep 14 19:48:34 *   Kotono has changed the topic to: Nikkolai(30)>Adail(26)????(25)>Knight(13)>Kamvakua(5)
Sep 14 19:49:46 *   Nikkolai nearly falls on his ass in his haste to backpedal away from the source of violence. He strains his eyes to see, wary of whatever attacked him! (Holding for the moment)
Sep 14 19:50:14 <Kotono>   You can see a white outline of...something! You can't quite make it out! OOC: Adail, were you going to do anything besides MM? If not ???? is up.
Sep 14 19:50:59 *   Adail grimaces and peers into the distance, "What...what's going on over there?"(OOC: nah, I got nothin')
Sep 14 19:51:49 *   Nikkolai desperately throws out a scorching ray, hoping against hope to hit it, even if he can't quite make it out!
Sep 14 19:52:06 <Nikkolai>   roll 1d20+9 TA
Sep 14 19:52:07 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 29." [1d20=20]
Sep 14 19:52:10 <Nikkolai>   roll 1d20+9 TA
Sep 14 19:52:11 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 11." [1d20=2]
Sep 14 19:52:17 <Kotono>   OOC: Crit check, then d100 for miss chance. Crit, but miss chance first. 1d100.
Sep 14 19:52:50 <Nikkolai>   roll 1d100
Sep 14 19:52:51 <Hatbot>   ACTION --> "Nikkolai rolls 1d100 and gets 86." [1d100=86]
Sep 14 19:52:57 <Kotono>   OOC: Hit and crit. Double damage, roll it.
Sep 14 19:53:53 <Kotono>   OOC: Oh wait that was the second ray. Roll a confirm on the crit threat first.
Sep 14 19:54:35 <Nikkolai>   roll 1d20+9 confirm
Sep 14 19:54:36 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 confirm and gets 28." [1d20=19]
Sep 14 19:55:32 <Nikkolai>   roll 4d6
Sep 14 19:55:33 <Hatbot>   ACTION --> "Nikkolai rolls 4d6 and gets 20." [4d6=5, 4, 5, 6]
Sep 14 19:55:35 <Nikkolai>   roll 4d6
Sep 14 19:55:36 <Hatbot>   ACTION --> "Nikkolai rolls 4d6 and gets 12." [4d6=1, 1, 4, 6]
OOC: There were 2 successful hits, one of them a crit, but Nikkolai got confused and only rolled the crit.
Sep 14 19:55:52 <Kotono>   Blazing fire slams into the sight unseen! A rumbling how echos from it as fire pierce through it's hidden body! BUt it's not downed, instead rushing Nikkolai, slamming it's body into him! OOC: Bull rushed. It has improved bullrush so no AoO, so make a strength check, Nikkolai.
Sep 14 19:56:19 <Nikkolai>   roll 1d20-1
Sep 14 19:56:20 <Hatbot>   ACTION --> "Nikkolai rolls 1d20-1 and gets 9." [1d20=10]
Sep 14 19:56:22 <Kotono>   roll 1d20+14 ow
Sep 14 19:56:22 <Hatbot>   ACTION --> "Kotono rolls 1d20+14 ow and gets 21." [1d20=7]
Sep 14 19:57:15 <Kotono>   The thing slams into Nikkolai! He's sent flying back ten feet, plummeting over the end of the ledge end over end! He begins to plummet down!
Sep 14 19:58:52 <Knight>   "Fool!" yells Knight, pushing a lever on the side of her mount! The wings shift back into a sleek, triangular form, and she dives towards Nikkolai with one arm outstretched!
Sep 14 19:58:59 <Knight>   OOC: I will use BURST OF SPEED to double my speed for a turn
Sep 14 19:59:21 <Kotono>   OOC: Make a ride check? This shouldn't be too hard with your ranks.
Sep 14 19:59:44 <Knight>   roll 1d20+19 i don't think I've ever made on of these before
Sep 14 19:59:45 <Hatbot>   ACTION --> "Knight rolls 1d20+19 i don't think I've ever made on of these before and gets 33." [1d20=14]
Sep 14 20:00:17 <Kotono>   Knight is like a plunging arrow, diving down! Her mouth is faster than Nikkolai's plummet, swooping under him! Nikkolai lands stomach down on Knight's lap, winded but safe! OOC: Free act for the moment.
Sep 14 20:01:10 <Nikkolai>   "...I know you're going to say it, so go ahead and get it over with." Nikkolai wheezes, the breath momentarily knocked out of him at impact.
Sep 14 20:01:33 <Knight>   Knight's expression is a stony mask of dismay, and she remains entirely silent on the trip back to their original ledge.
Sep 14 20:01:56 <Mari>   "Get back here, you two!" Mari yells.
Sep 14 20:01:57 <Kotono>   It is a safe enough trip, the two returning to the rest of the party in one piece.
Sep 14 20:02:26 <Kamvakua>   "Good work saving him, Knight.  I take it something is really over there?"
Sep 14 20:02:31 <Nikkolai>   "In my defense," he adds quietly, "the stairs *did* go upwards." Nikkolai clambers down hurriedly, straightening his clothing.
Sep 14 20:03:00 *   Adail sighs, "All's well that ends well, I suppose. Shall we head back to our original entrance and hope it hasn't somehow closed itself up in the meantime?"
Sep 14 20:03:07 <Knight>   Nikkolai is unceremoniously dumped off the side of the horse. She gives Kamvakua a patently incredulous glance. "Shall we get a move on?" she asks, deciding not to wait for someone to wonder what's at the bottom of the cliff before turning to head back.
Sep 14 20:03:36 <Mari>   "That doesn't mean they actually go to the surface. Let's just head back where we came from and get out of here." Mari marches off after Knight, not having any words for Nik right now.
Sep 14 20:03:42 <Kotono>   "Master," Yulia flies over to his head, perching. "I'm so glad you're safe!"
Sep 14 20:04:25 *   Adail scrambles up to his usual place on Kam's shoulder as they head out.
Sep 14 20:04:49 *   Kamvakua nods and helps Nikkolai up, heading off along the back of the party for now.
Sep 14 20:05:10 <Nikkolai>   "Yes, well." Nikkolai sighs. "At least someone is." He silently sets off behind them.
Sep 14 20:05:11 <Kamvakua>   "You alright?" He wondered of the man.
Sep 14 20:06:50 <Nikkolai>   "I'm fine, I suppose." Nikkolai replies shortly.
Sep 14 20:07:00 <Kotono>   The party finds the way back to the surface safe enough. The hole is still there, possible passage back out without incident if the party cares to return up.
Sep 14 20:07:30 *   Mari gets out her climbing gear and starts upwards!
Sep 14 20:07:44 <Kotono>   OOC: Make a climb check then, Mari?
Sep 14 20:07:49 <Mari>   roll 1d20+17
Sep 14 20:07:50 <Hatbot>   ACTION --> "Mari rolls 1d20+17 and gets 18." [1d20=1]
Sep 14 20:07:57 <Knight>   "You'll need to carry Serith up, Kamvakua," instructs Knight, sighing. "Get on, Nikkolai."
Sep 14 20:08:44 *   Adail eyes Serith's size, "We may need to put the shrinking ropes back on you for him to manage that easily."
Sep 14 20:08:52 *   Nikkolai gives Knight a mocking bow. "At once, my lady." He clambers up once more, perhaps settling on the horse a little rougher than is necessary."
Sep 14 20:08:58 <Kotono>   Mari starts to climb but doesn't get anywhere that try.
Sep 14 20:09:35 *   Mari frowns and makes another attempt while Knight's ferrying people out of the pit. May as well, right?
Sep 14 20:09:37 *   Nikkolai holds his hand out. "Give me the rope. Perhaps we can lower it down once at the top."
Sep 14 20:10:03 <Kotono>   OOC: Climb again, Mari.
Sep 14 20:10:14 <Mari>   roll 1d20+17 c'mon
Sep 14 20:10:15 <Hatbot>   ACTION --> "Mari rolls 1d20+17 c'mon and gets 29." [1d20=12]
Sep 14 20:10:17 <Kamvakua>   "I'll carry Serith and Adail up first then," Kamvakua's boots began flapping again as he lifted serith up, flying up slowly out of the hole and looking for a sturdy place topside assuming he can get there.
Sep 14 20:10:48 <Kotono>   This time Mari makes it back up to the surface! With this plan and work, rope, horse, climbing and other things getting the party back up to the surface! Once there Seirth sniffs, "We must continue," she growls through Adail.
Sep 14 20:11:52 <Mari>   "Yeah, I've had enough cold for a lifetime. Let's go get some justice done and get back to civilization."
Sep 14 20:12:04 <Knight>   Knight drops Nikkolai off at the top of the hole. "Please do not risk yourself idly," she says, heavily. "If you perish here, I will do likewise."
Sep 14 20:12:37 *   Adail moves from his perch on Kam to a perch on Serith's back.
Sep 14 20:13:56 *   Nikkolai eyes Knight a moment, a slightly puzzled look on his face. He reaches out and pats the woman on the leg once, twice, before moving behind her to assume his place in the party.
Sep 14 20:14:30 *   Kamvakua takes the rear, keeping watch.
Sep 14 20:14:33 <Kotono>   roll 1d100
Sep 14 20:14:35 <Hatbot>   ACTION --> "Kotono rolls 1d100 and gets 4." [1d100=4]
Sep 14 20:14:36 <Kotono>   roll 1d100
Sep 14 20:14:36 <Hatbot>   ACTION --> "Kotono rolls 1d100 and gets 10." [1d100=10]
Sep 14 20:15:33 <Kotono>   A few hours pass. Serith draws to an abrupt stop! Through Adail she says, "I smell something foul," she growls low in her throat, echoing int he windy blizzard.
Sep 14 20:16:07 <Knight>   "How close are we to our destination?"
Sep 14 20:16:16 *   Mari scans the drifting snow around her, eyes and ears open for whatever the presence might be.
Sep 14 20:16:19 *   Adail looks around and flicks his ears, hoping to see or hear what is troubling Serith.
Sep 14 20:16:31 *   Kamvakua glances around carefully, giving a sniff, though doubtful to smell anything.
Sep 14 20:17:46 <Kotono>   OOC: LIsten anyone who cares to make it.
Sep 14 20:17:58 <Kotono>   "Not too much farther," Serith says, "Soon."
Sep 14 20:18:01 <Knight>   roll 1d20+1 hahaha
Sep 14 20:18:02 <Hatbot>   ACTION --> "Knight rolls 1d20+1 hahaha and gets 13." [1d20=12]
Sep 14 20:18:06 <Mari>   roll 1d20+13
Sep 14 20:18:07 <Hatbot>   ACTION --> "Mari rolls 1d20+13 and gets 19." [1d20=6]
Sep 14 20:18:18 <Adail>   roll 1d20+16 hey listen
Sep 14 20:18:18 <Hatbot>   ACTION --> "Adail rolls 1d20+16 hey listen and gets 29." [1d20=13]
Sep 14 20:18:59 <Kamvakua>   roll 1d20+12
Sep 14 20:19:01 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+12 and gets 23." [1d20=11]
Sep 14 20:19:41 <Adail>   "Wolves..." Adail notes, then sniffs the air and nearly recoils from the scent, "And I smell undead."
Sep 14 20:20:05 <Kotono>   The wind is bitterly cold! Cascading around you from all directions you can hear it - mournful, dry, creaking howls! A wolf's howl, but strained. They are distant but closing in fast! Several of them, all around! Serith's voice rumbles again, "Inferior predators, heavy with the scent of death!"
Sep 14 20:20:46 *   Adail pulls a paw back to greet them with Hunting Fangs the moment they come into his view.
Sep 14 20:20:49 <Mari>   "Kam, you should yell and scare 'em off again! We don't have time to waste fighting animals."
Sep 14 20:20:51 <Kamvakua>   "They aren't aggressive like earlier.  Almost...mournful.  I thinks something killed some of them.  They may want through without a fight," Kamvakua looked for a way they could clear the path.
Sep 14 20:20:58 <Nikkolai>   Nikkolai asks curiously, "I cannot recall. Did the bodies that the Ice Queen inhabit reek of death? Perhaps she can only possess corpses?"
Sep 14 20:21:11 <Knight>   "This can't be chance," opines Knight. "Form a circle! Nikkolai, in the center! Prepare to hold them off."
Sep 14 20:21:29 *   Mari shakes her head. "Uh-uh, Nik. They seemed pretty normal to me. For ice people."
Sep 14 20:21:49 *   Kamvakua moves to the center, preparing to growl loudly when they get near.
Sep 14 20:22:06 *   Nikkolai nods. "Pity. It would have been too easy if we were to meet her in the open. And too convenient."
Sep 14 20:22:10 <Kotono>   OOC: If you guys are making this circle, how's it work? Who's next to who and in the center and what?
Sep 14 20:22:49 <Kamvakua>   OOC:Pent,  Knight front, Serith left, Kam right, Nikki center, mari right back, adail left back
Sep 14 20:22:52 <Mari>   OOC: spellcaster in the center, presumably. I should be near someone I can flank with, but I geuss that's everyone these days.
Sep 14 20:23:01 <Knight>   OOC: Flank with adail
Sep 14 20:23:04 <Knight>   OOC: Adail doesn't need to be part of the circle
Sep 14 20:23:15 <Nikkolai>   OOC: Don't suppose I can prep the party with a haste?
Sep 14 20:23:22 <Adail>   OOC: I'll start moving once they show up, yes. Mari should be near Serith then, since that's where I am at current.
Sep 14 20:24:26 <Nikkolai>   "Bright one! Bless us with haste! I fear we'll be in combat soon." Nikkolai says grimly.
Sep 14 20:24:52 <Kotono>   Yulia is quick, just quick enough! Haste wraps around the party, blessing them all as...OOC: That was pretty much yo8ur prep time. Init all.
Sep 14 20:24:59 <Knight>   roll 1d20+1
Sep 14 20:25:00 <Hatbot>   ACTION --> "Knight rolls 1d20+1 and gets 20." [1d20=19]
Sep 14 20:25:07 *   Kotono has changed the topic to: Knight(20)
Sep 14 20:25:13 <Kotono>   roll 1d20+7 Yulia
Sep 14 20:25:14 <Hatbot>   ACTION --> "Kotono rolls 1d20+7 Yulia and gets 15." [1d20=8]
Sep 14 20:25:14 <Adail>   roll 1d20+8 init
Sep 14 20:25:14 <Hatbot>   ACTION --> "Adail rolls 1d20+8 init and gets 20." [1d20=12]
Sep 14 20:25:18 <Kotono>   roll 1d20+2 Serith
Sep 14 20:25:18 <Hatbot>   ACTION --> "Kotono rolls 1d20+2 Serith and gets 15." [1d20=13]
Sep 14 20:25:19 <Nikkolai>   roll 1d20+8+5
Sep 14 20:25:19 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+8+5 and gets 31." [1d20=18]
Sep 14 20:25:25 <Mari>   roll 1d20+9
Sep 14 20:26:43 <Kamvakua>   roll 1d20+2
Sep 14 20:26:45 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+2 and gets 22." [1d20=20]
Sep 14 20:27:02 <Kotono>   roll 8#1d20+5
Sep 14 20:27:03 <Hatbot>   ACTION --> "Kotono rolls 8#1d20+5 and gets 138." [8#1d20+5 = 13, 15, 16, 22, 17, 24, 9, 22]
Sep 14 20:27:06 <Kotono>   roll 1d20+9
Sep 14 20:27:07 <Hatbot>   ACTION --> "Kotono rolls 1d20+9 and gets 26." [1d20=17]
Sep 14 20:27:09 <Kotono>   roll 1d20+9
Sep 14 20:27:10 <Hatbot>   ACTION --> "Kotono rolls 1d20+9 and gets 19." [1d20=10]
Sep 14 20:28:37 *   Kotono has changed the topic to: Nikkolai(31)>Mari(28)>????1(26)>Wolf 6(24)>Kamvakua=Wolf 4=Wolf 8(22)>Adail=Knight(20)>????2(19)>Wolf 5(17)>Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:28:47 <Kotono>   OOC: Open Nikkolai. You can't see anything but the blizzard yet, but you can hear howling.
Sep 14 20:29:56 *   Nikkolai scans the blizzard intently, ready to let fly the moment he sees a furry shape! OOC: Holding
Sep 14 20:29:58 <Kotono>   OOC: Okay then. Mari.
Sep 14 20:30:32 *   Mari remains watchful for enemies, waiting with weapons ready. (OOC: full defense + amulet charge)
Sep 14 20:31:02 <Kotono>   OOC: Okay. ????1 is up, doesn't do anything you can see. Wolf 6 is up.
Sep 14 20:31:34 <Kotono>   The first one comes into vision 25 feet to your right flank, approaching the party! It looks like a big, white, frozen wolf! It's fur is bloodied in several places, bone showing through! It advances ahead as...OOC: Nik, you have a helf action if you wanna blast it or whatever.
Sep 14 20:33:00 *   Nikkolai snarls soundlessly, flicking his wand and sending out two bolts of fiery magic at the frozen wolf!
Sep 14 20:33:07 <Nikkolai>   roll 1d20+9 TA
Sep 14 20:33:08 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 23." [1d20=14]
Sep 14 20:33:10 <Nikkolai>   roll 1d20+9 TA
Sep 14 20:33:11 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 29." [1d20=20]
Sep 14 20:33:19 <Kotono>   OOC: Crit confirm on that second roll.
Sep 14 20:33:28 <Nikkolai>   roll 1d20+9 Confirm
Sep 14 20:33:28 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 Confirm and gets 19." [1d20=10]
Sep 14 20:33:32 <Kotono>   OOC: First one hit, second one is a critical hit.
Sep 14 20:33:47 <Nikkolai>   roll 4d6 #1
Sep 14 20:33:49 <Hatbot>   ACTION --> "Nikkolai rolls 4d6 #1 and gets 15." [4d6=5, 1, 6, 3]
Sep 14 20:33:55 <Nikkolai>   roll 4d6 #2
Sep 14 20:33:55 <Hatbot>   ACTION --> "Nikkolai rolls 4d6 #2 and gets 8." [4d6=1, 4, 1, 2]
Sep 14 20:34:01 <Nikkolai>   roll 4d6 #3
Sep 14 20:34:02 <Hatbot>   ACTION --> "Nikkolai rolls 4d6 #3 and gets 9." [4d6=2, 4, 1, 2]
Sep 14 20:34:05 *   Kotono has changed the topic to: Mari(28)>????1(26)>Nikkolai(24)>Kamvakua=Wolf 4=Wolf 8(22)>Adail=Knight(20)>????2(19)>Wolf 5(17)>Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:34:12 <Kotono>   roll 32*1.5 this is academic, but
Sep 14 20:34:12 <Hatbot>   ACTION --> "Kotono rolls 32*1.5 this is academic, but and gets 48."
Sep 14 20:34:57 <Kotono>   Nikkolai's fast firebeams roast the wolf in it's place! It burns apart, bursting with powerful fire and crumbling to dust! OOC: Kam, you're up as well as the two wolves. Do you want to go first or wait for them to resolve and then hit 'em? I presume the latter for obvious reasons, but correct me if I'm wrong.
Sep 14 20:35:20 *   Kamvakua waits for them, his spear at the ready.
Sep 14 20:35:34 <Kamvakua>   OOC: Wait and AoO :)
Sep 14 20:35:59 <Kotono>   The fourth wolf comes behind the party! It's undead state is obvious as it gets within 15ft of Kamvakua, letting out a terrible blast of frozen air! OOC: I'll roll the damage dice first and see if it even penetrates your cold res. If not no point in a save.
Sep 14 20:36:02 <Kotono>   roll 4d6
Sep 14 20:36:03 <Hatbot>   ACTION --> "Kotono rolls 4d6 and gets 23." [4d6=6, 5, 6, 6]
Sep 14 20:36:08 <Kotono>   OOC: Wow. Reflex.
Sep 14 20:37:09 <Kamvakua>   roll 1d20+7
Sep 14 20:37:10 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+7 and gets 25." [1d20=18]
Sep 14 20:37:19 <Kotono>   OOC: No damage then, you made the save.
Sep 14 20:37:48 <Kotono>   The bitter cold engulfs Kamvakua, but isn't even felt! Meanwhile one appears to the other flank, emitting it's bitter winds towards Adail and Serith! OOC: Seirth is cold immune to irrelevant, make ref Adail.
Sep 14 20:38:16 <Adail>   roll 1d20+19 ref
Sep 14 20:38:16 <Hatbot>   ACTION --> "Adail rolls 1d20+19 ref and gets 23." [1d20=4]
Sep 14 20:38:31 <Kotono>   Adail leaps up, avoiding the cold air altogether safely, untouched! OOC: Go Kam.
Sep 14 20:40:04 *   Kamvakua moves toward the one ahead of him, lashing out with a fierce blow to knock it down.  OOC: Rage (+20/20 hp), Bull's Strength.
Sep 14 20:40:29 <Kotono>   OOC: Right.
Sep 14 20:41:18 <Kamvakua>   roll 1d20+22 Touch attack
Sep 14 20:41:21 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+22 Touch attack and gets 33." [1d20=11]
Sep 14 20:41:28 <Kotono>   OOC: Hit.
Sep 14 20:41:53 <Kamvakua>   roll 1d20+18
Sep 14 20:41:53 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+18 and gets 38." [1d20=20]
Sep 14 20:42:05 <Kotono>   roll 1d20+10 irrelevant, proceed to free hit.
Sep 14 20:42:05 <Hatbot>   ACTION --> "Kotono rolls 1d20+10 irrelevant, proceed to free hit. and gets 25." [1d20=15]
Sep 14 20:42:22 <Kamvakua>   roll 1d20+22 actual attack
Sep 14 20:42:24 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+22 actual attack and gets 30." [1d20=8]
Sep 14 20:42:29 <Kotono>   OOC: Hit.
Sep 14 20:42:44 <Kamvakua>   roll 3d6+16+2d6 (holy)
Sep 14 20:42:45 <Hatbot>   ACTION --> "Kamvakua rolls 3d6+16+2d6 (holy) and gets 41." [3d6=3, 6, 6][2d6=4, 6]
Sep 14 20:42:46 *   Kotono has changed the topic to: Mari(28)>????1(26)>Nikkolai(24)>Kamvakua=Wolf 8(22)>Adail=Knight(20)>????2(19)>Wolf 5(17)>Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:43:10 <Kotono>   Kamvakua strikes forward, lashing the legs out from the wolf a splits econd before impaling it through the side! It turns to ash and crumbles away in the holy onslaught! OOC: ADail and Knight, go.
Sep 14 20:44:38 <Knight>   Knight holds a moment, squinting into the blizzard to see what might come next. OOC: hoooolding.
Sep 14 20:44:46 *   Adail concentrates, sending a golden pulse of light out from his body. Then he snaps his paw at the remaining wolf that's in view, "Hunting Fang!"(OOC: Good Devotion, all in 30ft of me gain DR2/Evil and attacks count as Good. Also, MM the wolf)
Sep 14 20:44:50 <Adail>   roll 4d4+4
Sep 14 20:44:50 <Hatbot>   ACTION --> "Adail rolls 4d4+4 and gets 14." [4d4=4, 2, 2, 2]
Sep 14 20:46:34 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua=Wolf 8(22)>Adail=Knight(20)>????1>????2(19)>Wolf 5(17)>Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:46:36 <Kotono>   The fourth wolf is stricken all over, staggered back and part of it's hind leg breaking apart! At this moment...ahead, at the very edge of Kam's vision in the storm behind you...he can see it. It's humanoid, wrapped from head to toe in swaddling white cloths. Only it's eyes and hands are uncovered, the latter dead white and the former a listless, swirling white as it stares at Kamvakua! OOC:
Sep 14 20:46:36 <Kotono>   Make a will save, Kam?
Sep 14 20:47:11 <Kamvakua>   roll 1d20+9 will
Sep 14 20:47:13 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+9 will and gets 25." [1d20=16]
Sep 14 20:47:56 <Kotono>   Kamvakua feels his will almost break, the gaze too terrible to look at for long! He endures it with his utmost will, feeling a preternatural urge to OBEY! OOC: ???2 is holding. Wolf 5 is up.
Sep 14 20:49:23 <Kotono>   A fifth wolf comes forward towards Knight, advancing at her!
Sep 14 20:51:12 <Knight>   Knight prepares to lunge forward, lance extended to skewer her canine adversary!
Sep 14 20:51:28 <Knight>   roll 1d20+20 -6 PA
Sep 14 20:51:29 <Hatbot>   ACTION --> "Knight rolls 1d20+20 -6 PA and gets 28." [1d20=8]
Sep 14 20:51:30 <Kotono>   OOC: That be a
Sep 14 20:51:32 <Kotono>   OOC: Hit.
Sep 14 20:51:43 <Knight>   roll 6d6+21+18
Sep 14 20:51:44 <Hatbot>   ACTION --> "Knight rolls 6d6+21+18 and gets 60." [6d6=2, 6, 3, 2, 4, 4]
Sep 14 20:51:49 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua=Wolf 8(22)>Adail(20)>????1>????2(19)>Knight(17)>Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:52:22 <Kotono>   Knight is swift, impaling the creature onto her lance! As she does she can see it at the edge of her vision - identicla to what Kamvakua saw. It's eyes bore into her...a terrible presence...but nothing happens! OOC: Wolf 3 is up.
Sep 14 20:52:35 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua=Wolf 8(22)>Adail(20)>????1(19)>Knight(17)>????2=Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:53:02 <Kotono>   A third wolf comes forward, coming out and breathing 15ft away from Mari! OOC: Ref.
Sep 14 20:53:31 <Mari>   roll 1d20+16+1 haste
Sep 14 20:53:32 <Hatbot>   ACTION --> "Mari rolls 1d20+16+1 haste and gets 22." [1d20=5]
Sep 14 20:54:07 <Kotono>   Mari rolls under the breath, springing up untouched and undamaged! OOC: Serith, Yulia and wolf 5.
Sep 14 20:54:26 <Kotono>   Seirth growls low and pouncehs ahead, looking to rip the presumtive wolf asunder!
Sep 14 20:54:51 <Kotono>   roll 1d20+2 claw (+2 charge, -2 PA)
Sep 14 20:54:52 <Hatbot>   ACTION --> "Kotono rolls 1d20+2 claw (+2 charge, -2 PA) and gets 17." [1d20=15]
Sep 14 20:54:56 <Kotono>   OOC: +18
Sep 14 20:54:56 *   Adail holds onto Serith's fur with one paw as she pounces!
Sep 14 20:55:00 <Kotono>   roll 1d20+20 claw 2
Sep 14 20:55:01 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 claw 2 and gets 30." [1d20=10]
Sep 14 20:55:03 <Kotono>   roll 1d20+20 bite
Sep 14 20:55:03 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 bite and gets 26." [1d20=6]
Sep 14 20:55:36 <Kotono>   roll 4d4+20+2d6+6
Sep 14 20:55:36 <Hatbot>   ACTION --> "Kotono rolls 4d4+20+2d6+6 and gets 42." [4d4=1, 3, 4, 3][2d6=2, 3]
Sep 14 20:55:43 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua(22)>Adail(20)>????1(19)>Knight(17)>????2=Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)>Wolf 7(9)
Sep 14 20:56:14 <Kotono>   The wolf is shredded apart, Serith a flying nightmare of fur and teeth! It's parts are sent flying all over! Yulia meanwhile holds, helpful spells at the ready if needed! OOC: Wolf 2 is up.
Sep 14 20:56:26 <Kotono>   The second wolf comes from away, coming to 15ft of Knight and letting out it's cold breath at her! OOC: REf.
Sep 14 20:56:33 <Knight>   roll 1d20+6 that's a joke and a half
Sep 14 20:56:33 <Hatbot>   ACTION --> "Knight rolls 1d20+6 that's a joke and a half and gets 8." [1d20=2]
Sep 14 20:57:10 <Kotono>   roll 4d6 cold damage full.
Sep 14 20:57:10 <Hatbot>   ACTION --> "Kotono rolls 4d6 cold damage full. and gets 15." [4d6=6, 1, 5, 3]
Sep 14 20:57:50 <Kotono>   The breath engulfs Knight, leaving her frozen all over! The first wolf comes out of the mist, going to breath from 15ft away at Kamvakua, positioning itself between Kamvakua and the white-wrapped humanoid! OOC: Ref.
Sep 14 20:58:31 <Kamvakua>   roll 1d20+9 ref
Sep 14 20:58:32 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+9 ref and gets 23." [1d20=14]
Sep 14 20:58:42 <Kotono>   roll 4d6 halves this probably fails.
Sep 14 20:58:42 <Hatbot>   ACTION --> "Kotono rolls 4d6 halves this probably fails. and gets 8." [4d6=1, 2, 3, 2]
Sep 14 20:59:05 <Kotono>   The breath isn'te ven felt by the reinforced goliath! Meanwhile the seventh wolf emerges out near Mari, repeating the smae trick on her again!
Sep 14 20:59:07 <Kotono>   OOC: Ref Mari.
Sep 14 20:59:13 <Mari>   roll 1d20+16+1 haste
Sep 14 20:59:14 <Hatbot>   ACTION --> "Mari rolls 1d20+16+1 haste and gets 37." [1d20=20]
Sep 14 20:59:51 <Kotono>   But Mari is infinitely too fast, dodging with criminal ease! OOC: Mari, go. Two wolves within 15ft. Note they're larg eso they have reach if you don't tumble.
Sep 14 21:01:51 <Mari>   OOC: I guess I'll delay until Adail in case he charges in. I can flank with him afterwards. I lose nothing by doing so, really.
Sep 14 21:02:02 <Kotono>   OOC: Okay. Nik, go.
Sep 14 21:02:51 *   Nikkolai snaps out two bolts of fiery magic once more, hoping to incinerate another wolf in one blow!
Sep 14 21:02:56 <Nikkolai>   roll 1d20+9 TA
Sep 14 21:02:57 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 13." [1d20=4]
Sep 14 21:03:01 <Nikkolai>   roll 1d20+9 TA
Sep 14 21:03:01 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 15." [1d20=6]
Sep 14 21:03:05 <Kotono>   OOC: Which wolf? That's  two hits either way.
Sep 14 21:03:28 <Nikkolai>   OOC: Wolf seven?
Sep 14 21:03:33 <Kotono>   OOC: Sure.
Sep 14 21:03:47 <Nikkolai>   roll 8d6*1.5
Sep 14 21:03:48 <Hatbot>   ACTION --> "Nikkolai rolls 8d6*1.5 and gets 34.5." [8d6=3, 3, 4, 2, 1, 5, 1, 4]
Sep 14 21:03:55 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua(22)>Adail(20)>????1(19)>Knight(17)>????2=Wolf 3(16)>Serith=Yulia=Wolf 2(15)>Wolf 1(13)
Sep 14 21:04:15 <Kotono>   The seventh wolf is burnt alive, turned into crispy critters! As it crumbles away...OOC: Go Kam.
Sep 14 21:04:45 *   Kamvakua goes to clear his path.  One wolf?  Two wolves?  There would be none soon.
Sep 14 21:04:57 <Kamvakua>   roll 1d20+22 touch attack on the new wolf
Sep 14 21:04:58 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+22 touch attack on the new wolf and gets 31." [1d20=9]
Sep 14 21:05:09 <Kotono>   roll 1d20+10 opposed for tripping.
Sep 14 21:05:09 <Hatbot>   ACTION --> "Kotono rolls 1d20+10 opposed for tripping. and gets 28." [1d20=18]
Sep 14 21:05:12 <Kamvakua>   OOC: Battle Blessing: Eagle's Splendor.  Safety anyway.
Sep 14 21:05:17 <Kamvakua>   roll 1d20+18 trip
Sep 14 21:05:18 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+18 trip and gets 23." [1d20=5]
Sep 14 21:05:41 <Kotono>   But Kamvakua can't bring it down, the wolf too big and well centered to go down! OOC: Adail.
Sep 14 21:07:21 *   Adail bounds off Serith's back, moving to get behind a wolf near Mari so she can flank and throwing a hunting fang at the creature on his way in!(OOC: No tumble, let it waste it's AoO on me.)
Sep 14 21:07:31 <Adail>   roll 4d4+4 hunting fang
Sep 14 21:07:32 <Hatbot>   ACTION --> "Adail rolls 4d4+4 hunting fang and gets 13." [4d4=1, 4, 3, 1]
Sep 14 21:07:45 <Kotono>   roll 1d20+16 AoO is a go.
Sep 14 21:07:45 <Hatbot>   ACTION --> "Kotono rolls 1d20+16 AoO is a go. and gets 31." [1d20=15]
Sep 14 21:07:48 <Kotono>   OOC: AC?
Sep 14 21:08:01 <Adail>   OOC: 33. 35 if you're evil~
Sep 14 21:08:18 <Kotono>   Adail leaps forward, nimbly getting in range and avoiding it's jaws as magic missiles hit the wolf! OOC:  Mari, going onw?
Sep 14 21:08:34 *   Mari dashes in to take up position opposite Adail, then stab the wolf in the back!
Sep 14 21:09:03 <Mari>   roll 1d20+12+1+2+4 haste/flank/SoS
Sep 14 21:09:03 <Hatbot>   ACTION --> "Mari rolls 1d20+12+1+2+4 haste/flank/SoS and gets 25." [1d20=6]
Sep 14 21:09:17 <Kotono>   OOC: Hit.
Sep 14 21:09:42 <Mari>   roll 1d6+2+2d6+4+1 halved SA + SoS/fire
Sep 14 21:09:43 <Hatbot>   ACTION --> "Mari rolls 1d6+2+2d6+4+1 halved SA + SoS/fire and gets 13." [1d6=1][2d6=4, 1]
Sep 14 21:09:47 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua(22)>Adail(20)>????1(19)>Knight(17)>????2>Serith=Yulia=Wolf 2(15)>Wolf 1(13)
Sep 14 21:10:12 <Kotono>   Between the missles and sparking sword, the wolf goes down! It twitches a few times but lies there, dead for a second time! OOC: ????1 is up.
Sep 14 21:10:54 <Kotono>   The white-wrapped thing gazes steadily at Kamvakua! OOC: Make a wills ave.
Sep 14 21:11:25 <Kamvakua>   roll 1d20+11+1 (KoS)
Sep 14 21:11:27 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+11+1 (KoS) and gets 15." [1d20=3]
Sep 14 21:12:40 <Kotono>   Kamvakua's eyes go blank, as....OOC: Knight, go.
Sep 14 21:13:13 <Knight>   OOC: How far is the dude from me?
Sep 14 21:13:27 <Kotono>   OOC: 30ft away, just at the edge of your vision in the blizzard ahead.
Sep 14 21:14:26 <Knight>   The hissing trail she already made should lead her back to the others, Knight wagers, and she girds herself to charge straight into the enshrouded figure, just at the edge of her sight!
Sep 14 21:14:32 <Knight>   roll 1d20+20 deadly chaaarge PA -6
Sep 14 21:14:33 <Hatbot>   ACTION --> "Knight rolls 1d20+20 deadly chaaarge PA -6 and gets 29." [1d20=9]
Sep 14 21:14:38 <Kotono>   OOC: Hit.
Sep 14 21:15:17 <Knight>   roll 8d6+44+24
Sep 14 21:15:18 <Hatbot>   ACTION --> "Knight rolls 8d6+44+24 and gets 93." [8d6=6, 4, 3, 1, 5, 1, 2, 3]
Sep 14 21:16:18 <Kotono>   Knight charges ahead, impaling the thing right in the center of it's chest! It looks down despite the horrific wound, looking right back up! Without pain somehow it acts, fists striking out at Knight despite being impaled on her lance!
Sep 14 21:16:25 <Kotono>   roll 1d20+18 AC?
Sep 14 21:16:26 <Hatbot>   ACTION --> "Kotono rolls 1d20+18 AC? and gets 25." [1d20=7]
Sep 14 21:16:26 <Hatbot>   ACTION --> "Kotono rolls 1d20+18 AC? and gets 29." [1d20=11]
Sep 14 21:16:37 <Knight>   OOC: oh wow, uh, 28
Sep 14 21:16:54 <Kotono>   roll 1d6+6 and one negative level.
Sep 14 21:16:55 <Hatbot>   ACTION --> "Kotono rolls 1d6+6 and one negative level. and gets 10." [1d6=4]
Sep 14 21:17:39 <Kotono>   One of the blows strikes Knight across the forehead! Immediately her body weakens, spirit withering to it's noxious touch! She can feel her muscles atrophy, energy slacken into exhaustion! OOC: Serith, Yulia and Wolf 2 are up.
Sep 14 21:19:17 <Kotono>   roll 1d2 1 Kam 2 Knight
Sep 14 21:19:18 <Hatbot>   ACTION --> "Kotono rolls 1d2 1 Kam 2 Knight and gets 2." [1d2=2]
Sep 14 21:19:32 <Kotono>   Serith looks about, growling before deciding to go and charge, heading for the wolf on Knight's far flank!
Sep 14 21:19:39 <Kotono>   roll 1d20+20 (+2 charge, -2 PA)
Sep 14 21:19:40 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 (+2 charge, -2 PA) and gets 34." [1d20=14]
Sep 14 21:19:40 <Kotono>   roll 1d20+20 (+2 charge, -2 PA)
Sep 14 21:19:41 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 (+2 charge, -2 PA) and gets 38." [1d20=18]
Sep 14 21:19:41 <Kotono>   roll 1d20+20 (+2 charge, -2 PA)
Sep 14 21:19:42 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 (+2 charge, -2 PA) and gets 37." [1d20=17]
Sep 14 21:19:54 <Kotono>   roll 4d4+20+2d6+6
Sep 14 21:19:55 <Hatbot>   ACTION --> "Kotono rolls 4d4+20+2d6+6 and gets 40." [4d4=1, 2, 2, 3][2d6=2, 4]
Sep 14 21:20:05 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua(22)>Adail(20)>????1(19)>Knight(17)>????2>Serith=Yulia>Wolf 1(13)
Sep 14 21:20:40 <Kotono>   At the same time the wolf is torn apart, even as it's body crumbles, it manages to go and charge Knight's flank, trying to bite her with it's last act!
Sep 14 21:20:43 <Kotono>   roll 1d20+18
Sep 14 21:20:45 <Hatbot>   ACTION --> "Kotono rolls 1d20+18 and gets 26." [1d20=8]
Sep 14 21:20:48 <Knight>   OOC: tink
Sep 14 21:21:13 <Kotono>   But Knight's back armor ise nough, as it's body falls apart into the icy ground below! OOC: Wolf 1.
Sep 14 21:22:05 <Kotono>   The first wolf steps aside and back, going to the side of the white wrapped horror before Kamvakua! OOC: Yulia's still holding for a shout or anyone in trouble. Mari, go. Field's clear except for Kam who's stepping out of range and Knight who's out of range.
Sep 14 21:22:25 <Knight>   "Yulia! Cover me!" yells Knight!
Sep 14 21:23:38 <Kotono>   OOC: Yulia'll go too with Mari.
Sep 14 21:23:54 <Kotono>   "On it!" Yulia calls, flying ahead! She gets in sight of the impaled creature, making a disgusted face as magic missiles fly!
Sep 14 21:23:57 <Kotono>   roll 3d4+3
Sep 14 21:23:57 <Hatbot>   ACTION --> "Kotono rolls 3d4+3 and gets 13." [3d4=2, 4, 4]
Sep 14 21:24:05 *   Kotono has changed the topic to: Mari(28)>Nikkolai(24)>Kamvakua(22)>Adail(20)>????1(19)>Knight(17)>Serith=Yulia>Wolf 1(13)
Sep 14 21:24:33 <Kotono>   That final volley is enough, making the creature's wrappings fall away! A cloud of gas is just before Knight, hovering in the air!
Sep 14 21:25:34 *   Kotono has changed the topic to: Nikkolai(24)>Kamvakua(22)>Adail(20)>Mari>????1(19)>Knight(17)>Serith=Yulia>Wolf 1(13)
Sep 14 21:25:45 <Kotono>   OOC: Nik's up. Go Nik. Nothing's visible to your right now, just carnage.
Sep 14 21:26:32 *   Nikkolai dashes forward to where he last saw Knight and Kamvakua disappear to, hoping he can help!
Sep 14 21:26:58 <Kotono>   OOC: Kam went one way, Knight the opposite. Choose one.
Sep 14 21:27:27 *   Nikkolai decides to head after Knight!
Sep 14 21:28:32 <Kotono>   Nikkolai heads forward! He finds this end of the battle clear, save for a mist before Knight! OOC: Going to do anything or just hold?
Sep 14 21:28:48 <Knight>   "Nikkolai!" blurts out Knight, waving her lance around. "What is this? It turned to gas!"
Sep 14 21:29:26 <Nikkolai>   "Wha--what did?" Nikkolai eyes the gas cloud suspiciously, watching it for any sign of movement. "Back away from it, then!"
Sep 14 21:29:36 <Nikkolai>   OOC: Holding, I suppose
Sep 14 21:29:55 <Kotono>   OOC: Okay. Kam.
Sep 14 21:31:26 *   Kamvakua strides past the wolf, heading toward the ghostly creature.
Sep 14 21:31:49 <Kotono>   OOC: Okay. Adail.
Sep 14 21:34:09 *   Adail looks around, and seeing no immediate threats, moves over towards where Kam went!
Sep 14 21:34:56 <Kotono>   Adail moves forward! He can see Kamvakua standing before the white wrapped thing, a winter wolf at it's side! OOC: Going to do anything?
Sep 14 21:35:15 <Adail>   OOC: Can I get a good enough look at the wrapped thing to K:R it?
Sep 14 21:35:30 <Kotono>   OOC: Yeah, but you'll need to double move if you want to.
Sep 14 21:36:07 *   Adail throws a Hunting Fang at the wolf as soon as he sees it, and moves in more calling out, "Mari, there's more over here!"
Sep 14 21:36:16 <Adail>   roll 4d4+4 Hunting Fang~
Sep 14 21:36:16 <Hatbot>   ACTION --> "Adail rolls 4d4+4 Hunting Fang~ and gets 15." [4d4=3, 3, 4, 1]
Sep 14 21:37:03 <Adail>   (OOC: Single move, 40ft move rate. Not getting close enough to K:R this round.)
Sep 14 21:37:27 <Kotono>   The wolf is stricken, the white robed creature glancing at Adail! At last it speaks, "Now stay..." It says to Kamvakua, it's hand rising to impale his neck! OOC: Okay Adail. Kam, this gives you enough to make a second save throw against the domination.
Sep 14 21:38:00 <Kotono>   OOC: Also Adail, you can roll sense motive here.
Sep 14 21:38:11 <Kamvakua>   roll 1d20+11+2 (Possible also the saving bonus against being bound)
Sep 14 21:38:12 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+11+2 (Possible also the saving bonus against being bound) and gets 27." [1d20=14]
Sep 14 21:38:59 <Kotono>   This is enough to stir Kam to his senses! He can't fully dodge the blow, but it is enough to give him a moment to avoid being slain outright! OOC: Treating this as a normal attack against flatfooted, rolling.
Sep 14 21:39:05 <Kotono>   roll 1d20+18 flatfooted AC kam?
Sep 14 21:39:06 <Hatbot>   ACTION --> "Kotono rolls 1d20+18 flatfooted AC kam? and gets 27." [1d20=9]
Sep 14 21:39:14 <Kamvakua>   OOC: hits.  25.
Sep 14 21:39:20 <Kamvakua>   OOC: 23 right now actually
Sep 14 21:39:23 <Kotono>   roll 1d6+6 and one negative level.
Sep 14 21:39:23 <Hatbot>   ACTION --> "Kotono rolls 1d6+6 and one negative level. and gets 7." [1d6=1]
Sep 14 21:39:56 <Kotono>   Kamvakua's throat is grazed by the hand, an inch away from severing his throat! The wound leaves him shaken and dazed, weakened - but alive! OOC: Mari, you're up.
Sep 14 21:41:59 *   Mari heads after the sound of Adail's voice, out into the storm--and charges at the monster she sees once she reaches him! (OOC: 80 feet enough range for me to get over to the vamp and stab him? I figure Mari could probably see it as she's following Adail's directions)
Sep 14 21:43:36 <Kotono>   OOC: Sure.
Sep 14 21:43:50 <Mari>   roll 1d20+12+2+1 charge/haste
Sep 14 21:43:51 <Hatbot>   ACTION --> "Mari rolls 1d20+12+2+1 charge/haste and gets 16." [1d20=1]
Sep 14 21:44:11 <Kotono>   But Mari's charge is in vain, leaving her open and exposed instead of successful! OOC: Knight.
Sep 14 21:44:32 <Knight>   OOC: Am I able to charge him, or can I only move and attack due to visibility issues?
Sep 14 21:44:54 <Kotono>   OOC: You can charge.
Sep 14 21:45:52 <Knight>   Knight isn't quite sure where she's going, but towards the sound of carnage is often a good bet! She's soon rewarded for her intuition, and she lashes out with another vicious blow towards the one who would opposes her! "What are you?!" she demands, as she skids to a halt on his opposite side!
Sep 14 21:46:00 <Knight>   roll 1d20+20 PA -5
Sep 14 21:46:00 <Hatbot>   ACTION --> "Knight rolls 1d20+20 PA -5 and gets 24." [1d20=4]
Sep 14 21:46:04 <Kotono>   OOC: Zee whiff.
Sep 14 21:47:46 <Kotono>   The creature is a hair too fast, dodging! It's voice is a smooth, compelling drawl of death, "Your lives are forfeit for opposing the Lady of the Green Kirtle. She has found a lovely new ally in this realm, one who will ensure your defiance ends here!" OOC: Serith and Yulia.
Sep 14 21:48:41 <Kotono>   Seirth comes bounding across the tundra, going for the last wolf with a fury!
Sep 14 21:48:43 <Kotono>   roll 1d20+20
Sep 14 21:48:43 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 and gets 29." [1d20=9]
Sep 14 21:48:44 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 and gets 33." [1d20=13]
Sep 14 21:48:44 <Kotono>   roll 1d20+20
Sep 14 21:48:44 <Hatbot>   ACTION --> "Kotono rolls 1d20+20 and gets 35." [1d20=15]
Sep 14 21:49:03 <Kotono>   roll 4d4+20+2d6+6
Sep 14 21:49:03 <Hatbot>   ACTION --> "Kotono rolls 4d4+20+2d6+6 and gets 41." [4d4=2, 3, 2, 2][2d6=5, 1]
Sep 14 21:49:11 *   Kotono has changed the topic to: Nikkolai(24)>Kamvakua(22)>Adail(20)>Mari>????1(19)>Knight(17)>Serith=Yulia
Sep 14 21:49:32 <Kotono>   That wolf is torn apart as Yulia flies closer, "Hey, leave them alone!" she calls, more magic missiles flying! "You..creepy...thing!"
Sep 14 21:49:34 <Kotono>   roll 3d4+3
Sep 14 21:49:35 <Hatbot>   ACTION --> "Kotono rolls 3d4+3 and gets 11." [3d4=3, 1, 4]
Sep 14 21:49:49 <Kotono>   The missles hit it, drawing attention and wrath, but not seriously injuring it! It's body only rocks with them! OOC: Nikko
Sep 14 21:49:50 <Kotono>   .
Sep 14 21:51:04 *   Nikkolai hares off after Knight, vaguely hearing voices and the sounds of battle! (Don't suppose I arrived in time to catch any of what the thing said? And act on it?)
Sep 14 21:51:14 <Kotono>   OOC: No, but you can see it now if you wanna go burnin'.
Sep 14 21:52:09 <Nikkolai>   Without hesitation, Nikkolai draws upon his inner flame and manifests it into two bolts and sends them flying toward the creature!
Sep 14 21:52:14 <Nikkolai>   roll 1d20+9 TA
Sep 14 21:52:14 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 20." [1d20=11]
Sep 14 21:52:17 <Nikkolai>   roll 1d20+9 TA
Sep 14 21:52:18 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+9 TA and gets 13." [1d20=4]
Sep 14 21:52:22 <Kotono>   OOC: One hit.
Sep 14 21:52:31 <Nikkolai>   roll 4d6*1.5 damage
Sep 14 21:52:31 <Hatbot>   ACTION --> "Nikkolai rolls 4d6*1.5 damage and gets 25.5." [4d6=6, 4, 4, 3]
Sep 14 21:52:59 <Kotono>   The flaming shot impales the wrapped creature's shoulder, making it recoil and hiss! It staggers, not downed yet but it's cloth is burning! OOC: Kamvakua.
Sep 14 21:53:35 *   Kamvakua steps a bit to the side to line up a flank, his rage clear in his eyes as his glowing spear lashed out in a dangerous series of strikes.
Sep 14 21:53:45 <Kamvakua>   roll 1d20+23 Touch Attack trip
Sep 14 21:53:48 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+23 Touch Attack trip and gets 33." [1d20=10]
Sep 14 21:53:51 <Kotono>   OOC: Hit.
Sep 14 21:53:57 <Kotono>   roll 1d20+8
Sep 14 21:53:57 <Kamvakua>   roll 1d20+17 Trip
Sep 14 21:53:58 <Hatbot>   ACTION --> "Kotono rolls 1d20+8 and gets 10." [1d20=2]
Sep 14 21:53:59 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+17 Trip and gets 30." [1d20=13]
Sep 14 21:54:05 <Kotono>   OOC: Tripped, followup.
Sep 14 21:54:05 <Kamvakua>   roll 1d20+23 Attack 1
Sep 14 21:54:06 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+23 Attack 1 and gets 33." [1d20=10]
Sep 14 21:54:10 <Kamvakua>   roll 1d20+23 Attack 2
Sep 14 21:54:10 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+23 Attack 2 and gets 35." [1d20=12]
Sep 14 21:54:14 <Kotono>   OOC: Bot hit.
Sep 14 21:54:17 <Kamvakua>   roll 1d20+18 Attack 3
Sep 14 21:54:17 <Hatbot>   ACTION --> "Kamvakua rolls 1d20+18 Attack 3 and gets 35." [1d20=17]
Sep 14 21:54:25 <Kotono>   OOC: 3 times the pain. Owwies.
Sep 14 21:54:39 <Kamvakua>   roll 9d6+48+6d6 (holy)
Sep 14 21:54:40 <Hatbot>   ACTION --> "Kamvakua rolls 9d6+48+6d6 (holy) and gets 104." [9d6=6, 6, 4, 3, 6, 5, 1, 2, 2][6d6=5, 2, 3, 4, 1, 6]
Sep 14 21:55:02 <Kotono>   With that the last abomination is rpped apart! It's body turns to mist and it's bandages are left behind, the mist slowl floating up anda way! OOC: Free act, they're beat.
Sep 14 21:55:22 <Knight>   "What are these things?" demands Knight, swiping after the mist ineffectually. "Have they truly been defeated?"
Sep 14 21:56:11 *   Nikkolai frowns. "It was like...they were waiting for us. What business would these creatures have out here on the frozen plains in the middle of nowhere?"
Sep 14 21:56:24 *   Adail thinks as he gets closer...(OOC: did I get a good enough look or anything to K:R? Prolly not, I suspect.)
Sep 14 21:56:35 <Kotono>   OOC: ith the mist, yes. Go fo rit.
Sep 14 21:56:39 <Knight>   "They were dispatched by your nemesis," replies Knight, frowning. "She's made her alliances here, as well."
Sep 14 21:56:44 <Mari>   "They were looking for us. Said your girlfriend sent 'e, Nik."
Sep 14 21:56:53 <Adail>   roll 1d20+13 K:R
Sep 14 21:56:53 <Hatbot>   ACTION --> "Adail rolls 1d20+13 K:R and gets 22." [1d20=9]
Sep 14 21:57:25 <Kamvakua>   "They were dead.  I think they won't be bothering us again...but there will likely be more of them."
Sep 14 21:57:52 *   Adail narrows his eyes at the mist, "Vampires. Lovely. Just bloody lovely."
Sep 14 21:58:16 <Nikkolai>   Nikkolai's mouth draws into a thin line and his eyes go cold. "The longer I wait to confront her...the farther she extends her reach. There can be no more delays. After we dispose of this Ice Queen of ours...I *must* confront her."
Sep 14 21:58:25 <Knight>   "Vampires?!" blurts out Knight. "Mari, the garlic! Did you bring garlic?"
Sep 14 21:58:36 <Knight>   "Or did we only pack onions?"
Sep 14 21:58:57 <Mari>   "Why would I bring that? I didn't look after the food! Just the drinks!"
Sep 14 21:59:55 <Kotono>   "Terrible," Yulia settles on Knight's head, then looks at her, "Hey listen, can a card be turned into a vampire?"
Sep 14 22:00:28 <Nikkolai>   "Be grateful she only sent *two*, Adail." Nikkolai gazed off into the distance. "I don't understand why she simply hasn't sent a small army to murder me in my bed by now."
Sep 14 22:00:49 <Knight>   "Um... I think a vampire drew me once," replies Knight, blinking. "That was different, that was."
Sep 14 22:01:08 <Adail>   "Even she cannot have limitless resources." Adail responds, "And many of the things she has influance over, don't play well with others. It's not so strange as all that."
Sep 14 22:01:23 <Kamvakua>   "She has sent a small army after you before." Kamvakua simply had more memory for getting skewered by wyverns it seemed.
Sep 14 22:01:53 <Knight>   Knight nods. "The logistics of such activities are rather daunting," replies Knight. "Small bands are easier to manage and more difficult to see coming than a large force. We could evade an army... but an ambush party?"
Sep 14 22:02:07 <Kamvakua>   "I don't feel so good though...I think that creature drained some of my life,"  Kamvakua eyed about. "We should get walking."
Sep 14 22:02:41 <Adail>   "Vampires tend to do that, yes." Adail nods, "I'm afraid I can't cast anything powerful enough to restore that as of yet either."
Sep 14 22:03:00 <Mari>   "Sooo, this new ally they mentioned. Think it's our ice queen? It'd be the right kind of company."
Sep 14 22:03:12 <Knight>   "Ordinary healing will have to do for now," replies Knight, starting to shiver. "It would seem logical. The enemy of my enemy is my friend, after all."
Sep 14 22:03:27 <Kamvakua>   "Probably, it would be smart of her."
Sep 14 22:03:48 <Nikkolai>   "Indeed." Nikkolai sees the sense in the others' words. "We do need to rest once more before we set out to eliminate the Ice Queen. If you're right, Mari...we need to move fast. She can only grow stronger with the more allies she collects."
Sep 14 22:04:35 *   Adail snickers, "Or the more entities can grow irritated at her as thier minions die to us for her cause."
Sep 14 22:04:37 <Knight>   "No, that is why we must move at once," replies Knight, shuddering. "I am not significantly impaired, and we must give them no more time to plot or ambush us once more. Our disadvantage grows as we linger."
Sep 14 22:05:13 *   Adail hops back up on Serith's back, and pats her on the neck, "Lead the way then."
Sep 14 22:05:21 <Mari>   "Serith said we were close, right? Let's finish our business here and get back to civilization. It's harder to attack us there."
Sep 14 22:05:57 <Kotono>   OOC: Continuing on then?
Sep 14 22:06:03 <Knight>   OOC: I'd like some healing first?
Sep 14 22:06:06 <Knight>   OOC: Clerical dudes? >_>
Sep 14 22:06:13 <Mari>   OOC: healz and move, sure.
Sep 14 22:06:19 <Kotono>   Yulia comes over and casts Lesser Vigor on Knight!
Sep 14 22:06:52 <Kotono>   roll 1d100
Sep 14 22:06:53 <Hatbot>   ACTION --> "Kotono rolls 1d100 and gets 59." [1d100=59]
Sep 14 22:06:56 <Kotono>   roll 1d100
Sep 14 22:06:56 <Hatbot>   ACTION --> "Kotono rolls 1d100 and gets 79." [1d100=79]
Sep 14 22:07:03 <Kotono>   roll 1d100 just to see if it gets a 99.
Sep 14 22:07:04 <Hatbot>   ACTION --> "Kotono rolls 1d100 just to see if it gets a 99. and gets 21." [1d100=21]
Sep 14 22:10:27 <Kotono>   The party advances on! After a few more hours you see it ahead! The storms...stop? A few hundred feet ahead you see the rising monoliths of the Ice Queen's lair. The eternals torm has paused...a faint rippling plays over the faraway monuments.
Sep 14 22:11:14 <Kotono>   Yulia takes a moment for another Lesser Vigor on Knight and Kamvakua both.
Sep 14 22:13:04 <Mari>   "Could be she's ready for us, after what's happened," Mari says, looking out on the icy monuments. "We should be prepared. Any spells anyone's got to protect everyone from the cold, now's the time to use them, I figure. It's probably going to be a fight as soon as we step in. And I'd watch for traps."
Sep 14 22:13:29 <Kamvakua>   "Thanks, Yulia," Kamvakua smiled at the little courre, much appreciating her regular aid.
Sep 14 22:13:37 <Kotono>   As the party watches the clearing, a single note of a great horn can be heard.
Sep 14 22:14:03 <Knight>   "I concur," replies Knight, limbering up her lance arm. "Our presence is known. Nikkolai, I beg you to fortify us."
Sep 14 22:14:12 <Mari>   "That can't be good for us. Call to arms, I'd guess."
Sep 14 22:14:57 <Nikkolai>   roll 1d20+14 Will oh gods
Sep 14 22:14:57 <Hatbot>   ACTION --> "Nikkolai rolls 1d20+14 Will oh gods and gets 29." [1d20=15]
