#012: "ME THINK THIS IS BULLSHIIIIIIIT!" "Suck it, elf!"
Started by Merc, April 04, 2013, 11:45:10 PM
[18:47] <Kotono> -----
[18:48] <Kotono> OOC: The barrels are dealt with, there's a stairway going up.
[18:48] * Lehko heads up the stairway! Hopefully not to heaven.
[18:49] <Morrie> "Let's get moving, then."
[18:49] <Santos> "Hang on..." Santos mutters, as he checks himself over, noticing that outside of a little toastiness he's all there. "Okay, I'm good to go."
[18:49] <Kotono> Thus the party ascends. It comes up into a castle room. A few idle barrels are scattered about here, a dark and unremarkable room otherwise. A single door leads out of it.
[18:50] * Lehko checks the room for any hidden traps or enemies!
[18:50] <Lehko> roll 2d6+5 Awareness
[18:50] * Hatbot --> "Lehko rolls 2d6+5 Awareness and gets 10." [2d6=3, 2]
[18:51] <Kotono> That's odd. There's traces of gunpowder around the door leading out.
[18:51] <Lehko> "Gunpowder around the outdoor... I'm... worried that it'll be trapped and these barrels may be full of it..."
[18:51] * Lehko inspects the closest barrel...
[18:52] <Kotono> The barrel is indeed full of gunpowder.
[18:52] <Lehko> "Okay... These are gunpowder barrels... I suggest you all stand back in the stairway in case I can't.... deal with the trap."
[18:53] <Morrie> "Are these monsters really smart enough to make an explosive trap like that?"
[18:54] <Lehko> "No, but an elf probably is."
[18:55] <Santos> "Probably meant to work together with those bomb thingies we just blew up?"
[18:56] <Lehko> "Could be. Might be safer to check, just in case, though."
[18:56] * Lehko goes to inspect the door for traps...
[18:57] <Lehko> roll 2d6+5 Awareness
[18:57] * Hatbot --> "Lehko rolls 2d6+5 Awareness and gets 12." [2d6=5, 2]
[18:57] <Kotono> The door is indeed trapped.
[18:57] <Lehko> "Yep. There's a trap."
[18:57] * Lehko turns to the others.
[18:57] <Lehko> "You wanna stay, or go take cover? It'll be a big boom."
[19:00] <Kotono> OOC: Are you two moving or staying or what? Iddy, are you doing anything with the door?
[19:01] <Lehko> OOC: I'm waiting for them to decide if they want to take cover or not before I try to disarm it.
[19:02] * Morrie will just go back down the stairs.
[19:02] * Lehko turns back to the trapped door and opens his coat, which has all of his tools sewn in, and gets to work...
[19:02] <Lehko> OOC: Tinkering?
[19:04] <Kotono> OOC: What exactly are you trying?
[19:05] <Lehko> OOC: Well, trying to disarm the trap. I'd like to try and recover components, or the trap itself, if possible.
[19:06] <Kotono> OOC: Okay.
[19:06] <Morrie> Meanwhile, the mushroom continues to dance. Presumably.
[19:06] <Kotono> OOC: Go for it, Lehko.
[19:06] <Lehko> roll 2d6+7 Tinkering
[19:06] * Hatbot --> "Lehko rolls 2d6+7 Tinkering and gets 18." [2d6=5, 6]
[19:08] <Kotono> Click? Clack? BANG! THUD! WHUMP! BRRUUUUUUNNGGGG! HICHA! The sounds of work fill the room and filter back down the stairs. Soon enough Lehko has disarmed the trap. It's a mass of gun powder connected to a Bomb Fragment; Lehko is able to recover this intact! OOC: Loot post for the fragment.  Trap is disarmed.
[19:08] * Lehko stands up and calls out.
[19:08] <Lehko> "All clear!"
[19:12] <Santos> "Must have been some trap! That was a lot of noise for one trap, catman..." Santos notes with an impressed whistle.
[19:12] * Lehko holds up the bomb fragment.
[19:12] * Morrie walks back up the stairs.
[19:12] <Morrie> "Well, that was... um... anti-climactic..."
[19:13] <Lehko> "Well, it took some work, but I got the boom piece, too."
[19:13] * Lehko tosses it to Morrie.
[19:14] * Morrie catches it and puts it in THE BAG.
[19:14] * Lehko turns and kicks the door open, rifle at the ready!
[19:15] <Kotono> Ahead is a hall. It's a typical castle on first glance. To the left is a long hall with lots of doors on either wall. To the right is a single door on the opposite wall before it opens up into some sort of larger space. You can't tell from here. There's tapestries, lots of stone, that sort of thing. Very castle-esque. No sign of immediate opposition.
[19:15] <Morrie> "This just screams 'trap', doesn't it."
[19:16] <Lehko> "Yep. Hallway of doors or the single one first?"
[19:16] <Santos> "Whispers, more like it. And I say the single door!"
[19:18] * Lehko nods and heads towards the single door, being slightly paranoid and watching the area.
[19:19] * Morrie will follow, along with Mycol.
[19:19] <Kotono> As you step out into the hall...OOC: Make a force check, Lehko.
[19:20] <Lehko> roll 2d6+2 Force
[19:20] * Hatbot --> "Lehko rolls 2d6+2 Force and gets 11." [2d6=3, 6]
[19:20] <Kotono> GAH! The floor is slippery! Slippery like grease, but somehow he keeps his balance. He manages to stop himself before taking a nasty tumble!
[19:21] <Santos> ooc: Can we use athletics for balance?
[19:21] * Lehko steadies himself, tail slightly bushy and pupils dilated in surprise.
[19:21] <Kotono> OOC: If you're going to attempt to walk safely on it, sure.
[19:21] <Lehko> "Careful. Slippery as hell here..."
[19:21] <Kotono> OOC: This is difficult terrain for the sake of Morrie's ability.
[19:21] * Santos nods at Lehko's warning as he takes care stepping forward, slowly making his way towards the opposite door.
[19:21] * Lehko tries to make his way across the floor to the door...
[19:21] <Santos> roll 2d6+4 athletics for balance
[19:21] * Hatbot --> "Santos rolls 2d6+4 athletics for balance and gets 11." [2d6=4, 3]
[19:22] <Kotono> OOC: 2d6, Iddy.
[19:22] <Lehko> roll 2d6
[19:22] * Hatbot --> "Lehko rolls 2d6 and gets 9." [2d6=4, 5]
[19:23] <Kotono> Both slooowly and safely  make their way across the greased floor, reaching the single door. It's closed. Ahead in the hall, you can see it opens up into a formal hall. Suits of armor are on display and you can see flags hanging from the ceiling there.
[19:23] <Morrie> OOC: Making a check for Mycol.
[19:23] <Kotono> OOC: Okay.
[19:23] * Lehko inspects the door, wary of traps!
[19:23] <Morrie> roll 2d6 for icy pathness
[19:23] * Hatbot --> "Morrie rolls 2d6 for icy pathness and gets 8." [2d6=5, 3]
[19:24] <Kotono> Mycol manages to make it across the greased ground as well, like a fried mushroom sliding across the pan! OOC: Coming as well, Morrie?
[19:24] <Lehko> roll 2d6+5 Awareness
[19:24] * Hatbot --> "Lehko rolls 2d6+5 Awareness and gets 13." [2d6=5, 3]
[19:24] <Kotono> The door isn't trapped. Behind it you hear something mutter, "Time for boom?" it asks aloud. It sounds high pitched.
[19:25] * Lehko turns as quickly as he safely can and readies his rifle.
[19:25] <Lehko> "No! No boom!"
[19:25] * Morrie will simply walk gracefully across the floor, seemingly accustomed the ice by now.
[19:26] <Kotono> At that reply, there is a sudden gasp, followed by, "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!" from behind the door, getting louder and louder! OOC: Init with the unseen baddie.
[19:26] <Kotono> roll 2d6 ????
[19:26] * Hatbot --> "Kotono rolls 2d6 ???? and gets 7." [2d6=2, 5]
[19:26] <Lehko> roll 2d6 Init
[19:26] * Hatbot --> "Lehko rolls 2d6 Init and gets 10." [2d6=5, 5]
[19:26] <Santos> roll 2d6+0 ninja initiative!
[19:26] * Hatbot --> "Santos rolls 2d6+0 ninja initiative! and gets 5." [2d6=3, 2]
[19:26] <Santos> ooc: man, ninja init is always so lame.
[19:27] <Kotono> OOC That's because you're a warrior at heart.
[19:27] <Santos> ooc: true
[19:27] <Morrie> roll 2d6 Mycol
[19:27] * Hatbot --> "Morrie rolls 2d6 Mycol and gets 8." [2d6=5, 3]
[19:27] <Morrie> roll 2d6 Morrie
[19:27] * Hatbot --> "Morrie rolls 2d6 Morrie and gets 7." [2d6=1, 6]
[19:27] * Kotono changes topic to 'Santos: 51/51 Morrie: 64/64 Lehko 51/51 Mycol 46/46 (26/28 MP) | Difficult terrain: -2 AVD | Lehko(10)>Mycol(8)>Morrie>???(7)>Santos(5)'
[19:28] <Kotono> OOC: Lehko, you open.
[19:29] * Lehko steps back from the door, out of direct line with it and raises his rifle, holding his fire until he can see what exactly is screaming.
[19:30] <Kotono> OOC: Holding. Okay. Mycol. You can take this turn when you catch up or you can hold or let Morrie take this one while you log up. Your call.
[19:30] <Mycol> Hold, please.
[19:30] <Kotono> OOC: Okay, fair enough. Morrie.
[19:31] <Morrie> OOC: Nothing's actually... come out, right?
[19:31] <Kotono> OOC: Door's still closed, but you can hear that lovely screaming. Odds are something's about to.
[19:31] * Morrie will move one stage away to be at Medium Range, then.
[19:33] <Kotono> Morrie scurries back on the greased floor, going back the way he came! Then the door is thrown open! You see an imp! A great big barrel is on his back, the top off! It's full of black gunpowder! Several mini barrels are strapped all over his body, also full of gunpowder. It falls all over as he leaps up, a Bomb Fragment in hand as he dives towards the party! OOC: If either of you two wanna take your held actions, now's the time.
[19:34] <Lehko> OOC: what're the rules on an aimed shot? Like trying to shoot the fragment out of his hand?
[19:35] <Kotono> OOC: I don't see rules for it offhand, but I'd allow it as a -2 penalty.
[19:35] <Mycol> OOC: Shit, I was right. I gotta run for like, 5-10 minutes.
[19:35] * Lehko tries to aim carefully, hoping to shoot the fragment out of the imp's hand...
[19:36] <Lehko> roll 2d6+2-2
[19:36] * Hatbot --> "Lehko rolls 2d6+2-2 and gets 4." [2d6=2, 2]
[19:36] <Kotono> Lehko aims and fires, but narrowly misses the imp! OOC: Okay. Morrie, would you run Mycol's turn here then?
[19:37] <Morrie> OOC: Yahp. Can I try to use Telekinesis to remove the Bomb Fragment?
[19:39] <Kotono> OOC: Sure. I'd require an attack roll on it like Iddy's, though.
[19:40] <Morrie> OOC: Okay. minus anything?
[19:41] <Kotono> OOC: Same -2 as Iddy's shot.
[19:41] <Morrie> OOC: OK
19:41] <Morrie> roll 2d6
[19:41] * Hatbot --> "Morrie rolls 2d6 and gets 7." [2d6=6, 1]
[19:42] <Kotono> This time the Bomb Fragment is yanked out – a second before it plunges its hand towards a mini barrel full of gunpowder! It instead lands hard on the ground, groaning and without a Bomb Fragment to set it all off! OOC: Santos.
[19:44] <Santos> ooc: Can I pick him up and toss him? >_>
[19:44] <Kotono> OOC: I don't see why not.
[19:44] <Santos> ooc: what would that require?
[19:44] <Kotono> OOC: Quick and dirty, an opposed force check, I guess?
[19:45] <Santos> ooc: Can I include the bonus from the ability Throw? >_>
[19:45] <Kotono> OOC: Aahahahahaa. Sure, why not?
[19:45] <Santos> ooc: the ability that makes things go kersplut? <_<
[19:45] <Santos> roll 2d6+3+4 Throwing imps!
[19:45] * Hatbot --> "Santos rolls 2d6+3+4 Throwing imps! and gets 12." [2d6=4, 1]
[19:45] <Kotono> roll 2d6+2
[19:45] * Hatbot --> "Kotono rolls 2d6+2 and gets 6." [2d6=3, 1]
[19:46] <Kotono> OOC: Where exactly are you chucking him?
[19:46] <Santos> ooc: Toss him towards one of the suits of armor.
[19:47] <Kotono> With a mighty throw, Santos chucks the imp ahead! It flies end over end, like a shuriken! Gunpowder spills all over it as it collides with one of the armor sets! There's a tremendous din of crashing metal and breaking wood! At th end of it the imp likes in a pile of armor, wood and gunpowder. He's not getting up. OOC: Free act.
[19:47] <Kotono> OOC: Loot post.
[19:48] <Santos> "That worked better than I expected," Santos says with a pleased expression. "I really should make more of a habit of picking up and tossing around enemies."
[19:48] * Morrie will pick up the Bomb Fragment and put it also, in The Bag.
[19:49] <Lehko> "Huh. Don't suppose any of that armor is useable? Or do we want to go through the door?"
[19:49] <Santos> "I figured it was ornamental."
[19:49] * Lehko nods and heads through the door.
[19:50] <Kotono> Inside the door is a simple enough room. It has maps and a table. Hanging lamps provide illumination. In the corner is a red treasure chest.
[19:50] * Lehko checks the chest over for anything suspicious.
[19:50] <Lehko> roll 2d6+5 Awareness
[19:50] * Hatbot --> "Lehko rolls 2d6+5 Awareness and gets 9." [2d6=3, 1]
[19:51] <Kotono> Zounds! The treasure chest is trapped! It's full of nothing but gunpowder. Open it and this room will be getting redecorated Stalingrad style.
[19:52] <Morrie> "Find anything?"
[19:54] <Lehko> "Yeah. A trap. Looks like the whole thing is filled with gunpowder and set to go off. I can try and disarm it.. I'm sort of uncomfortable leaving it armed when we turn this place over to the guards outside."
[19:55] <Santos> "Let's empty the rest of the room's contents first? Like the maps and such? They're probably useful," Santos comments, moving towards one of the maps to view it.
[19:55] <Morrie> "We could also just come back after we take care of the Elf."
[19:55] <Kotono> It's a map of the Glacierwind Valley. Pins are dotted along the edge of the mountains and in the hills.
[19:55] * Santos looks at another map next!
[19:56] * Lehko nods.
[19:56] <Kotono> It's another map of Glacierwind Valley. This one is full of annotations. Looks like an analysis of crops and settlements.
[19:58] * Santos searches for a map that has annotations of treasure! Or one with notes of dangerous beasts to search for!
[19:58] <Kotono> No such luck. It looks to be largely economic in nature and not a how-to guide for adventurers.
[19:58] <Morrie> "What are you looking for?"
[19:59] <Lehko> "Santos wants to get the maps, I think."
[19:59] <Santos> "Treasure map, or monsters. It's all boring stuff though..." Santos says with a disappointed sigh. "Nothing that'd really be worth saving."
[19:59] * Lehko nods.
[19:59] <Lehko> "Get outside real quick while I do this. Shouldn't take me long."
[20:00] <Santos> "Blow it up or not, up to you," Santos says with a shake of his head as he goes wait outside.
[20:00] <Lehko> roll 2d6+7 Tinkering
[20:00] * Hatbot --> "Lehko rolls 2d6+7 Tinkering and gets 11." [2d6=3, 1]
[20:01] <Kotono> OOC: Trying to disarm it?
[20:01] <Lehko> OOC: Yeah.
[20:01] * Morrie will step out, along with the spinning maraca mushroom.
[20:02] <Kotono> CLICK! CLACK BANG! WRRIIRRR! Click. Wait, what was tha-BOOOOOOOM! As the rest of the party heads out, the door explodes off its hinges as the map room is now the room of huge fiery explosions! (More)
[20:02] <Kotono> roll 2d6+50
[20:02] * Hatbot --> "Kotono rolls 2d6+50 and gets 56." [2d6=3, 3]
[20:03] * Kotono changes topic to 'Santos: 51/51 Morrie: 64/64 Lehko 0/51 Mycol 46/46 (26/28 MP) | Difficult terrain: -2 AVD | Lehko(10)>Mycol(8)>Morrie>???(7)>Santos(5)'
[20:04] <Kotono> The din of the explosion is enough to leave the party momentarily stunned! When it clears, you see that the inside of the room is ruined. The walls have caved in, the entire thing in ruin. Lying amid it is a rather burnt Lehko! OOC: Act, y'all. Lehko, you're out cold until further notice.
[20:04] * Santos sticks a finger in his ear and rubs with a wince, as he tries to get his hearing back after the loud explosion. "You stupid cat! That wasn't me actually telling you to go ahead and blow your dumb ass up! That was me joking or something!" he exclaims, pauses and then asks. "...Are you still ALIVE?!?"
[20:04] * Lehko bleeds in response.
[20:04] * Morrie winces and frowns.
[20:05] <Kotono> Hard to tell from here. Lehko isn't clearing it up, being as he's lying there and most likely at least horribly maimed.
[20:05] <Morrie> "I'm not so sure I can fix this one, but... look after Mycol for a second, and shout if monsters come."
[20:05] * Morrie carefully steps in and will try and make his way to Lehko, the Explosives Expert.
[20:06] <Kotono> Coming closer, you can see he's in bad shape. Burns, cuts and generally broken. Morrie can tell he's fading fast. He needs something powerful!
[20:07] <Morrie> OOC: Can I do a heal check to try and stabilize him?
[20:07] <Kotono> OOC: Sure.
[20:07] <Morrie> roll 2d6+4 heal check
[20:07] * Hatbot --> "Morrie rolls 2d6+4 heal check and gets 9." [2d6=2, 3]
[20:08] <Kotono> Working hard and fast, Morrie is able to do a bit of emergency medicine! It's enough to stabilize Lehko for now, but he's still out.
[20:08] * Morrie will then attempt to call on the spirits outside to at least get him back to consciousness. If not, then it's time... for IT.
[20:09] <Kotono> No good. All the sunlight in the world isn't fixing this mess, looks like.
[20:10] <Morrie> "Santos! We need the Phoenix Down."
[20:11] <Santos> "The stupid ass blew himself up -that- bad? I was in a minor explosion just minutes ago! I came out fine!" Santos exclaims, but dutifully pulls out the item in question and hands it over.
[20:11] <Morrie> "Well, yes, but that was a magical explosion..."
[20:11] * Morrie will administer the Phoenix Down and THEN make with the Sunlight.
[20:12] <Kotono> The phoenix down glows like molten fire, seeping into Lehko's wounds! With that the sunlight quickly mends his body, Lehko awakening!
[20:12] * Kotono changes topic to 'Santos: 51/51 Morrie: 64/64 Lehko 51/51 Mycol 46/46 (26/28 MP) |'
[20:13] * Lehko coughs and gasps, bolting upright, tail fluffed up.
[20:13] * Lehko turns to the others with wide and dilated eyes.
[20:13] <Lehko> "Ow."
[20:14] <Morrie> "Let's just go straight forward from here on. We don't have the resources to muck around with everything -- we can just come back later."
[20:14] <Santos> "I suppose so," Santos says. "At the very least, Lehko's not allowed to disarm explosive traps anymore today."
[20:15] * Lehko stands up and nods.
[20:15] <Lehko> "Let's just be sure to note traps like that so the guards don't stumble on them."
[20:16] <Morrie> "Agreed."
[20:16] <Morrie> Mycol spins. Maybe shakes a maraca or two.
[20:17] <Morrie> "Well, let's get moving."
[20:18] * Lehko heads back out and down the formal hall, tail still bushy.
[20:19] <Kotono> Heading out to the main hall, you find it advances ahead to double doors that are ajar. Behind you also goes to double doors, which are closed.
[20:20] <Kotono> OOC: Behind you, as in there's double doors on either end of the room. Whoops.
[20:20] * Lehko heads through the first set of double doors and into the next room, stopping at the second set of doors.
[20:20] <Lehko> "Ready all?"
[20:22] <Lehko> OOC: Ahhh.. we came through the open ones?
[20:23] <Kotono> OOC: You came out from a feeder hall.
[20:24] <Lehko> "Open or closed, everyone?"
[20:24] <Morrie> "Closed."
[20:24] * Santos kicks open one of the closed doors, giving his own answer!
[20:25] * Lehko heads through the now open door, rifle ready!
[20:26] <Kotono> The closed door is kicked open! Within you find a throne room! Sitting on the throne is a loathsome creature. It has arms far too long for its body, its entire form gangling. Its skin is a silver-white like frosted snow and wrinkly. It wears a rough-spun robe. Its facial features are vicious, "YOU! YOU! YOUUUUUU!" It howls loud enough to echo, "ME SMASH YOU! ME HIT YOU! ME STOMP YOU! ME WATCH YOU DIE!"  OOC: Init here.
[20:26] <Lehko> roll 2d6 Init
[20:26] <Santos> roll 2d6-0 reverse psychology ninja init!
[20:26] * Hatbot --> "Lehko rolls 2d6 Init and gets 8." [2d6=2, 6]
[20:26] * Hatbot --> "Santos rolls 2d6-0 reverse psychology ninja init! and gets 10." [2d6=6, 4]
[20:27] <Santos> ooc: ...reverse psychology works well.
[20:27] <Morrie> roll 2d6 Init Morrie
[20:27] * Hatbot --> "Morrie rolls 2d6 Init Morrie and gets 2." [2d6=1, 1]
[20:27] <Morrie> roll 2d6 Init Mycol
[20:27] * Hatbot --> "Morrie rolls 2d6 Init Mycol and gets 8." [2d6=4, 4]
[20:27] <Kotono> roll 2d6 Dark Elf
[20:27] * Hatbot --> "Kotono rolls 2d6 Dark Elf and gets 9." [2d6=5, 4]
[20:27] <Kotono> roll 2d6 ???
[20:27] * Hatbot --> "Kotono rolls 2d6 ??? and gets 6." [2d6=5, 1]
[20:28] * Kotono changes topic to 'Santos: 51/51 Morrie: 64/64 Lehko 51/51 Mycol 46/46 (26/28 MP) | Santos(10)>Dark Elf(9)>Lehko=Mycol(8)>???(6)>MorrieMiko(2)'
[20:28] <Kotono> OOC: Act. He's medium range away, y'all, at the eother end of the throne room.
[20:28] <Santos> "Kiddo, yer the ugliest thing I've seen, and I've seen some daaammmmmnnnnnneeeeed ugly undead, and I didn't think things got uglier than them!" Santos declares.
[20:29] <Kotono> OOC: Santos, you're up. Go.
[20:30] * Santos draws his blades and starts rushing forward, side stepping from side to side as he rushes forward in quick steps, splitting into multiple copies of himself all moving towards one target, with a clear goal in mind. Destruction!
[20:30] <Santos> ooc: image+move action
[20:30] <Kotono> As Santos rushes ahead, "MINIONS!" The Dark Elf calls! From out of nowhere he suddenly has a Floateye and a Bomb at his side! (More)
[20:31] * Kotono changes topic to 'Santos: 51/51 Morrie: 64/64 Lehko 51/51 Mycol 46/46 (26/28 MP) | Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8)>???(6)>MorrieMiko(2)'
[20:31] <Morrie> "I might need help with the Bomb, but I'm going to aim for it."
[20:32] <Kotono> The float eye wastes no time, a great big gust of air gathering in its mouth as it bites down at Santos!
[20:32] <Kotono> roll 2d6+2 AVD?
[20:32] * Hatbot --> "Kotono rolls 2d6+2 AVD? and gets 4." [2d6=1, 1]
[20:32] <Santos> ooc: way more than 4
[20:33] <Kotono> But the bite misses cleanly, getting nothing but air! Meanwhile flames erupt from the bomb, soaring out at the three people still farther away! OOC: Note M.ARM and any fire res, everyone but Santos.
[20:33] <Morrie> OOC: 5, and I don't think I have any.
[20:33] <Mycol> 15, none.
[20:34] <Kotono> roll 2d6+5 Lehko, what's yours?
[20:34] * Hatbot --> "Kotono rolls 2d6+5 Lehko, what's yours? and gets 14." [2d6=4, 5]
[20:35] <Lehko> OOC: AVD is 6.
[20:35] <Lehko> OOC: M/ARM is 8.
[20:35] <Kotono> OOC: M.ARM, not AVD.
[20:35] * Kotono changes topic to 'Santos: 51/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (26/28 MP) | Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8)>???(6)>MorrieMiko(2)'
[20:36] <Kotono> The flames singe the party, sending heat and pain to all but Mycol, who laughs them off! OOC: Lehko.
[20:41] * Lehko takes aim at the Dark Elf and fires, activating his Chemical Spill ability and hoping to give it a vulnerability to fire!
[20:42] <Kotono> OOC: Make your opposed roll.
[20:42] <Lehko> roll 2d6+4 Force!
[20:42] * Hatbot --> "Lehko rolls 2d6+4 Force! and gets 8." [2d6=2, 2]
[20:42] <Kotono> roll 2d6+6 boss force is stupid
[20:42] * Hatbot --> "Kotono rolls 2d6+6 boss force is stupid and gets 12." [2d6=5, 1]
[20:42] <Kotono> Lehko shoots and fires - but the chemicals just roll off the hideous dark elf! OOC: Okay, Mycol.
[20:43] <Kotono> "WHERE ICE GIRL?!" The dark elf snaps, "ME BURN ICE GIRL!"
[20:43] * Mycol dances and throws his arms out impossibly fast, speeding up with the force of his Time Magic
[20:43] <Mycol> OOC:  Quick Cast Quickening
[20:43] <Kotono> OOC: Righto. ??? is up.
[20:43] * Kotono changes topic to 'Santos: 51/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened)>???(6)>MorrieMiko(2)'
[20:44] <Kotono> Whatever ??? does, the party is as unaware of it as his or her existence! OOC: Morrie.
[20:45] * Morrie calls on the spirits to strike at the Bomb!
[20:45] <Morrie> roll 2d6+2
[20:45] * Hatbot --> "Morrie rolls 2d6+2 and gets 14." [2d6=6, 6]
[20:45] <Morrie> OOC: HOLY
[20:45] <Morrie> OOC: HOLY MOLEY
[20:46] <Kotono> OOC: Which one was that? Plains?
[20:46] <Morrie> OOC: Correct.
[20:46] <Kotono> OOC: Gimme a sec since this one is complicated.
[20:48] * Kotono changes topic to 'Santos: 51/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Difficult terrain: Short range knockback each round, all enemies sealed Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened)>???(6)>MorrieMiko(2)'
[20:50] <Kotono> Above you at tremendous storm erupts! Lightning crashes down in the throne room as tornado winds begin to toss all but Morrie about! The dark elf and companions are sent back to the far wall, including an imp from behind the throne! OOC: Go Santos. You're being tossed around by the winds but can act.
[20:50] <Kotono> OOC: Round 1 of Maelstrom.
[20:51] * Kotono changes topic to 'Santos: 51/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Difficult terrain: Short range knockback each round, all enemies sealed Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened)>Imp(6)>MorrieMiko(2)'
[20:52] * Morrie was clearly trying to take the Bomb out, but... well, something happened and it seems he lost control.
[20:52] <Santos> ooc: Can I reach the dark elf since I moved to short range and the knockback is still a short range effect?
[20:53] <Kotono> "ME THINK THIS IS BULLSHIIIIIIIT!" The dark elf bellows, slammed hard against the wall! OOC: Sure.
[20:53] <Santos> "Suck it, elf!" Santos says, even if he himself dislikes the effect of Morrie's spell, but he isn't going to act like this wasn't all part of some plan! Instead he dives towards the dark elf and slashes at its pair of gangly arms, one with each blade!
[20:53] <Santos> roll 2d6+2
[20:53] * Hatbot --> "Santos rolls 2d6+2 and gets 10." [2d6=6, 2]
[20:54] <Santos> roll d6 reroll 2
[20:54] * Hatbot --> "Santos rolls d6 reroll 2 and gets 5." [d6=5]
[20:54] <Santos> ooc: 35 damage
[20:54] <Kotono> OOC: Hit.
[20:55] <Kotono> OOC: Damage?
[20:56] <Morrie> OOC: It's right there!
[20:56] <Santos> ooc: ^
[20:56] <Kotono> OOC: Oh. Whoops!
[20:56] * Kotono changes topic to 'Santos: 51/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened)>Imp(6)>Morrie(2) DE: 70'
[20:56] <Kotono> Santos finds the dark elf easy to slice into - no defenses at all! He draws plenty of blood as he swoops by, landing on the wall as he tears both arms open! A moment later he leaps off the wall, blowing with the wind! OOC: Dark elf.
[20:56] <Kotono> "ME HIT YOU!" The dark elf roars, swinging at Santos as he slashes him!
[20:57] <Kotono> roll 2d6+5 AVD?
[20:57] * Hatbot --> "Kotono rolls 2d6+5 AVD? and gets 12." [2d6=5, 2]
[20:58] <Kotono> OOC: ARM as well?
[21:00] <Santos> ooc: AVD 12
[21:00] <Santos> ooc: ARM 8
[21:00] <Lehko> OOC: His ARM is 8.
[21:00] * Kotono changes topic to 'Santos: 24/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened)>Imp(6)>Morrie(2) DE: 70'
[21:00] <Kotono> Thunder booms and winds howl as Santos is smacked upside the head! The blow sends him careening back, bouncing off the floor as his senses reel! OOC: Bomb and then Floateye are up.
[21:00] <Kotono> The bomb and floateye both bite at Santos as he's hurled back!
[21:00] <Kotono> roll 2d6+1 Bomb
[21:00] * Hatbot --> "Kotono rolls 2d6+1 Bomb and gets 8." [2d6=2, 5]
[21:01] <Kotono> roll 2d6+2 FE
[21:01] * Hatbot --> "Kotono rolls 2d6+2 FE and gets 13." [2d6=6, 5]
[21:01] <Santos> ooc: FE hits, bomb misses
[21:01] * Kotono changes topic to 'Santos: 15/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened)>Imp(6)>Morrie(2) DE: 70'
[21:01] <Kotono> Santos gets another painful CHOMP as he flies back, battered severely! Meanwhile...OOC: Lehko.
[21:02] * Lehko once again tries to use Chemical Spill against the elf, this time trying to weaken him against lightning!
[21:02] <Lehko> roll 2d6+4 Force
[21:02] * Hatbot --> "Lehko rolls 2d6+4 Force and gets 12." [2d6=5, 3]
[21:02] <Kotono> roll 2d6+6
[21:02] * Hatbot --> "Kotono rolls 2d6+6 and gets 16." [2d6=6, 4]
[21:03] <Kotono> Lehko fires, but the blast is lost in the howling winds, once again diverted! OOC: Mycol.
[21:04] * Mycol moves faster than the eye can track, spinning his Maracas toward the Float Eye (Telekinesis can hit Medium Range). He is now shimmering with his mana shield, as well.
[21:04] <Mycol> OOC:  attack, mana shield
[21:04] * Kotono changes topic to 'Santos: 15/51 Morrie: 55/64 Lehko 45/51 Mycol 46/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 70'
[21:04] <Mycol> 2d6+1 oops I never recalculated accuracy and avoid
[21:04] * Hatbot --> "Mycol rolls 2d6+1 oops I never recalculated accuracy and avoid and gets 11." [2d6=5, 5]
[21:05] <Kotono> OOC: Base 10 is gonna hit anyway. Damage and the damage to you for Quickening?
[21:06] <Mycol> OOC: 30 from my attack. 11.5 (Does it round down or up?) from quickening
[21:06] * Kotono changes topic to 'Santos: 15/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 130'
[21:06] <Morrie> "Santos! I'm going to take out the Bomb this time, use your items!"
[21:07] <Kotono> The dark elf is terrifically battered by maracas in the storm, giving a shaking counterpoint to the bass of the wind! Meanwhile the imp futilely flails, doing nothing! OOC: Morrie.
[21:07] <Mycol> OOC: I attacked the float eye, actually.
[21:07] * Mycol   moves faster than the eye can track, spinning his Maracas toward the Float Eye
[21:07] * Santos nods to Morrie, making plans to drink a potion as soon as he can.
[21:08] <Kotono> OOC: My bad.
[21:08] * Kotono changes topic to 'Santos: 15/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Bomb=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 70 FE: 27'
[21:08] * Morrie calls on the spirits outside to try and strike the Bomb again.
[21:08] <Morrie> roll 2d6+2
[21:08] * Hatbot --> "Morrie rolls 2d6+2 and gets 10." [2d6=2, 6]
[21:09] <Kotono> OOC: Hits like a one hit wonder band.
[21:09] <Morrie> OOC: 50 * whatever the weakness is.
[21:09] <Kotono> roll 50*1.5
[21:09] * Hatbot --> "Kotono rolls 50*1.5 and gets 75."
[21:09] <Kotono> roll 3#1d100
[21:09] * Hatbot --> "Kotono rolls 3#1d100 and gets 122." [3#1d100 = 68, 21, 33]
[21:09] * Kotono changes topic to 'Santos: 15/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 70 FE: 27'
[21:10] <Morrie> "I'll deal with the eye, the rest of you focus on the big guy!"
[21:10] <Kotono> The bomb is torn apart by the wind, popping and fading away in a rain of gil! With it falls another Flame Saber! OOC: Ow. Santos. Round 2 of Maelstrom shenanigans.
[21:10] <Kotono> "ME HATE HATE HATE HATE HATE HATE HATE HATE YOU! GRR!" The Dark Elf cries in vain!
[21:11] * Santos pulls out a hi-potion and drinks it.
[21:11] <Santos> ooc: +25 HP
[21:12] * Kotono changes topic to 'Santos: 40/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 70 FE: 27'
[21:12] <Kotono> Santos finds his wounds healing, the worst of his torment becoming nothing but a memory! Meanwhile the three victims are tossed around by the wind, taking the only target in close - Santos!
[21:13] <Kotono> roll 2d6+5 Dark Elf
[21:13] * Hatbot --> "Kotono rolls 2d6+5 Dark Elf and gets 13." [2d6=4, 4]
[21:13] <Kotono> roll 2d6+1 Bomb
[21:13] * Hatbot --> "Kotono rolls 2d6+1 Bomb and gets 5." [2d6=1, 3]
[21:13] <Kotono> roll 2d6+2 FE AVD and ARM?
[21:13] * Hatbot --> "Kotono rolls 2d6+2 FE AVD and ARM? and gets 12." [2d6=6, 4]
[21:13] <Morrie> OOC: ps the bomb is dead
[21:13] <Kotono> OOC: Strike that roll, thanks.
[21:14] <Morrie> OOC: Figures that was the only bad roll. :(
[21:14] <Santos> ooc: I say the Dark Elf misses just cause he hit last time! >.< (AVD 10 since I'd have lost two images, ARM 8)
[21:15] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 70 FE: 27'
[21:15] <Kotono> Santos is again brutalized, bitten, bloodied and chomped like a chew toy! But he's still up, spinning 'round the throne as the trio exchange blows! OOC: Lehko.
[21:16] * Lehko raises his rifle and takes a shot at the elf!
[21:16] <Morrie> "Santos, get away from there!"
[21:16] <Lehko> roll 2d6+2
[21:16] * Hatbot --> "Lehko rolls 2d6+2 and gets 11." [2d6=3, 6]
[21:16] <Kotono> OOC: Hit. James Hit.
[21:16] <Lehko> OOC: 31 dam.
[21:16] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 132 FE: 27'
[21:17] <Kotono> BLAM! The shot wavers through the wind, but the aim is true! A massive flash of lightning blinds you, but when it's passed, you can see a brand new hole in the stomach of the dark elf! OOC: Mycol.
[21:17] * Mycol spins his Maracas through the air, directly at the Dark Knight! They seem to dance by their own power
[21:18] <Mycol> 2d6+1
[21:18] * Hatbot --> "Mycol rolls 2d6+1 and gets 7." [2d6=1, 5]
[21:18] <Mycol> (Also I take 11 damage)
[21:18] <Mycol> OOC: Dark Elf, not Dark Knight
[21:19] <Morrie> OOC: Don't you get two actions?
[21:19] <Kotono> OOC: Yeah, you get a second if quickened.
[21:20] <Morrie> OOC: My suggestion might be to Quicken Santos so he can get away betterer.
[21:20] <Mycol> OOC: I do. I was doing my first attack first.
[21:20] <Morrie> OOC: Sprint, whatever.
[21:20] <Santos> ooc: he can't quicken. Sealed, remember?
[21:20] <Mycol> OOC: I thought only the enemies were sealed. Also, Santos wants to run?
[21:20] <Kotono> OOC: Miss. Go for your second move now.
[21:21] <Mycol> "Santos! Do you need to retreat?"
[21:21] <Santos> ooc: is it enemy only? that's actually useful
[21:21] <Santos> "If I'm just going to get battered each time I drink and heal, I might have to!"
[21:22] <Mycol> "Then be quick about it."
[21:22] * Mycol begins casting Sprint.
[21:23] <Kotono> OOC: Both sides get affected by short range knockback at the start of each turn. Knockback disrupts charging spells.
[21:23] <Mycol> OOC: Oh. Can I undo that, then?
[21:24] <Mycol> OOC: I already attacked, so I can't use Haste to quick-cast this round, but I suppose I can next round. In the meanwhile, try not to die.
[21:24] <Morrie> OOC: I think if he moves, they have to follow, since they can't do anything else anyway.
[21:25] <Kotono> OOC: Sure.
[21:25] <Mycol> OOC: Then I attack the DE again.
[21:25] <Mycol> 2d6+1
[21:25] * Hatbot --> "Mycol rolls 2d6+1 and gets 7." [2d6=5, 1]
[21:25] <Mycol> OOC: Ffffffffffffffffff-
[21:25] <Kotono> Maracas fly in the wind, but none of them hit as they dance amid storms and gales! OOC: Imp does nothing but flail and whimper. Morrie.
[21:26] * Morrie will take a moment to strike down the Float Eye with the power of the castle itself!
[21:26] <Morrie> roll 2d6+2
[21:26] * Hatbot --> "Morrie rolls 2d6+2 and gets 10." [2d6=2, 6]
[21:26] <Morrie> OOC: That's 50 damage due to the Lighting doohickey area, and I believe it's also weak.
[21:27] <Kotono> OOC: Yes it is. 1.5 so 75 base damage.
[21:27] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 35/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf=Floateye(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 132'
[21:27] <Kotono> roll 3#1d100
[21:27] * Hatbot --> "Kotono rolls 3#1d100 and gets 56." [3#1d100 = 4, 42, 10]
[21:28] <Kotono> The float eye is torn apart by a lightning bolt, dropping gil and a familiar package of eye drops! OOC: Kerzappy. Santos! Round 3 of Maelstrom shenanigans.
[21:28] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 24/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 132'
[21:29] <Santos> "Ah, screw it! Let's test my luck!" Santos exclaims as he goes for the dark elf again.
[21:29] <Santos> roll 2d6+2
[21:29] <Kotono> "ME WANT REFIGHT!" The Dark Elf wails, continuing to be tossed around!
[21:29] * Hatbot --> "Santos rolls 2d6+2 and gets 7." [2d6=2, 3]
[21:29] <Santos> roll d6 reroll 2
[21:29] * Hatbot --> "Santos rolls d6 reroll 2 and gets 6." [d6=6]
[21:29] <Santos> roll d6 reroll 3 reliable
[21:29] * Hatbot --> "Santos rolls d6 reroll 3 reliable and gets 6." [d6=6]
[21:29] <Santos> ooc: woo!
[21:29] <Kotono> OOC: Congratulations, that's a critical hit you lucky bastard.
[21:29] <Santos> ooc: 72 damage
[21:29] <Kotono> roll 132+144
[21:29] * Hatbot --> "Kotono rolls 132+144 and gets 276."
[21:29] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 24/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 276'
[21:30] <Kotono> Santos darts in fearlessly, ripping the chest of the dark elf open! It bleeds terrifically as he savages it, only a snarl of pain and hate as the elf takes a swing in return!
[21:30] <Kotono> roll 2d6+5
[21:30] * Hatbot --> "Kotono rolls 2d6+5 and gets 8." [2d6=1, 2]
[21:30] <Kotono> OOC: AVD?
[21:30] <Santos> ooc: avoided like a boss!
[21:31] <Santos> ooc: I'm out of images btw
[21:31] <Kotono> But Santos nimbly avoids the blows and continues to rip apart the dark elf! OOC: Ow. Noted. Lehko.
[21:31] * Lehko takes aim and fires at the elf again!
[21:31] <Lehko> roll 2d6+2
[21:31] * Hatbot --> "Lehko rolls 2d6+2 and gets 4." [2d6=1, 1]
[21:31] <Kotono> OOC: Hateboooot.
[21:32] <Mycol> OOC: Noooooooo
[21:32] <Kotono> But the shot is lost in the storm winds once more! OOC: Hatebot. Mycol.
[21:34] * Mycol wills the Maracas to fly from the maelstrom, concentrating on sending them at the blasted Elf...
[21:34] <Mycol> 2d6+1
[21:34] * Hatbot --> "Mycol rolls 2d6+1 and gets 10." [2d6=5, 4]
[21:34] <Kotono> OOC: Hits.
[21:34] <Mycol> 29
[21:34] <Kotono> roll 58+276
[21:34] * Hatbot --> "Kotono rolls 58+276 and gets 334."
[21:34] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 24/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 334'
[21:34] <Mycol> ...and again.
[21:34] * Hatbot --> "Mycol rolls 2d6+1 and gets 5." [2d6=2, 2]
[21:35] <Mycol> OOC: Nnnnnnnnnnnnnooooooooooooooooooooooope. Still not a fighter. Also I took 11 damage
[21:35] <Kotono> Shaking maracas fly! They land on the head of the dark elf, battering him like a drum! His head bobs up and down with the beat(ing), leaving him woozy and dizzy, "ME WANT TO GO HOME!" OOC: Imp whimpers and does nothing. Morrie.
[21:35] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 12/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 334'
[21:36] * Morrie will attempt to unleash the power of the Castle against the Elf, in the hopes that it will rid them of his foul presence!
[21:36] <Morrie> roll 2d6+2
[21:36] * Hatbot --> "Morrie rolls 2d6+2 and gets 11." [2d6=6, 3]
[21:36] <Kotono> OOC: Starts with an H and ends with its.
[21:37] <Morrie> OOC: That's... 49.
[21:37] * Kotono changes topic to 'Santos: 7/51 Morrie: 55/64 Lehko 45/51 Mycol 12/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 358'
[21:37] <Kotono> The dark elf is zapped hard, yet barely seems phased by it at all! No, the giant sucking chest wound he's working on is far more of a concern! OOC: Right. Last round of Maelstrom. Santos.
[21:38] <Santos> Hopefully things continue to work out! Santos once more attacks, this time attempting to just plain damn decapitate the dark elf!
[21:38] <Santos> roll 2d6+2
[21:38] * Hatbot --> "Santos rolls 2d6+2 and gets 5." [2d6=2, 1]
[21:38] <Santos> roll d6 reroll 1
[21:38] * Hatbot --> "Santos rolls d6 reroll 1 and gets 2." [d6=2]
[21:38] <Santos> roll d6 reroll either 2 reliable?
[21:38] * Hatbot --> "Santos rolls d6 reroll either 2 reliable? and gets 5." [d6=5]
[21:38] <Kotono> OOC: Total?
[21:38] <Santos> ooc: 8
[21:38] <Kotono> OOC: Ze WHIFF.
[21:39] <Santos> ooc: Alas!
[21:39] <Kotono> Santos closes in and swings for its head - but the dark elf falls back, winds sending him around the throne! He grabs it and spins back, a jump kick right for the head of the wily ninja!
[21:39] <Kotono> roll 2d6+5
[21:39] * Hatbot --> "Kotono rolls 2d6+5 and gets 11." [2d6=1, 5]
[21:39] <Kotono> OOC: AC and ARM?
[21:39] <Santos> ooc: ARM is 8. he hits
[21:39] * Kotono changes topic to 'Santos: 0/51 Morrie: 55/64 Lehko 45/51 Mycol 12/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 358'
[21:40] <Kotono> WHAM! The blow sends Santos into the darkness, his body skipping on the ground and landing in a battered heap  before the throne! A familiar position for him lately, really. OOC: Ow. Lehko.
[21:40] * Lehko tries to snap a round off at the floating elf.
[21:40] <Lehko> roll 2d6+2
[21:40] * Hatbot --> "Lehko rolls 2d6+2 and gets 10." [2d6=5, 3]
[21:40] <Kotono> OOC: Hiiiit.
[21:40] <Lehko> OOC: 32 Dam
[21:40] <Kotono> roll 358+64
[21:40] * Hatbot --> "Kotono rolls 358+64 and gets 422."
[21:40] * Kotono changes topic to 'Santos: 0/51 Morrie: 55/64 Lehko 45/51 Mycol 12/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 422'
[21:41] <Kotono> BLAM! The shot catches the dark elf right in the face! Oh sure, it's now missing most of its face, but it's still up! Barely, seemingly powered by pure hate and carried by the winds! OOC: Ow. Mycol.
[21:41] <Mycol> "Not much.... left in me"
[21:41] <Morrie> "I'll heal us! Just stay together! We'll help Santos after this!"
[21:41] <Mycol> (11 more damage..... I'm lucky this rounds down, apparently)
[21:41] * Kotono changes topic to 'Santos: 0/51 Morrie: 55/64 Lehko 45/51 Mycol 1/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, quickened, m shield)>Imp(6)>Morrie(2) DE: 422'
[21:42] * Mycol continues his ranged maraca barrage
[21:42] <Mycol> 2d6+1
[21:42] * Hatbot --> "Mycol rolls 2d6+1 and gets 7." [2d6=1, 5]
[21:42] <Kotono> OOC: M.I.S.S
[21:42] * Hatbot --> "Mycol rolls 2d6+1 and gets 9." [2d6=4, 4]
[21:42] <Kotono> OOC: HIT!
[21:42] <Mycol> OOC: Better. 28
[21:42] <Kotono> roll 5#1d100
[21:42] * Hatbot --> "Kotono rolls 5#1d100 and gets 322." [5#1d100 = 31, 50, 85, 67, 89]
[21:42] <Mycol> Oh, good it died. End quickening.
[21:43] * Kotono changes topic to 'Santos: 0/51 Morrie: 55/64 Lehko 45/51 Mycol 1/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Dark Elf(9)>Lehko=Mycol(8, m shield)>Imp(6)>Morrie(2) DE: 422'
[21:43] * Mycol slows down and promptly goes down in a near heap
[21:43] <Kotono> The elf is clubbed right in the face! It slumps over before exploding into a big pile of gil coins! With it you see potion, a hunk of metal and what looks to be a sheathed sword! OOC: Imp is up. Still whimpering. Literally has no non-special attack. Morrie.
[21:44] * Kotono changes topic to 'Santos: 0/51 Morrie: 55/64 Lehko 45/51 Mycol 1/46 (24/28 MP) | Difficult terrain: Maelstrom| Santos(10)>Lehko=Mycol(8, m shield)>Imp(6)>Morrie(2)'
[21:44] * Morrie will decide to take his frustration out on the last remaining Imp since it can't seem to do anything. Calling on the Castle again.
[21:44] <Morrie> roll 2d6+2
[21:44] * Hatbot --> "Morrie rolls 2d6+2 and gets 8." [2d6=3, 3]
[21:44] <Morrie> OOC: 48 if it hits.
[21:45] <Kotono> roll 5#1d100
[21:45] * Hatbot --> "Kotono rolls 5#1d100 and gets 231." [5#1d100 = 78, 76, 7, 34, 36]
[21:45] <Mycol> "G-.....got him."
[21:46] <Kotono> The imp is torn apart! Several potions fall from him, landing on the ground as the storm ends! OOC: Victory! Bestiary and loot posts. Free act!
[21:46] <Mycol> "Apologies. Maybe I should have let the giant out to play."
[21:46] * Morrie will begin the task of restoring those of them that are still there.
[21:46] <Morrie> OOC: I think Santos should be able to be healed, assuming he didn't die, die.
[21:47] <Santos> ooc: Ninjas don't die when they are killed!
[21:47] * Lehko helps Mycol stand.
[21:48] <Kotono> OOC: He can be.
[21:48] * Kotono changes topic to 'Santos: 51/51 Morrie: 64/64 Lehko 51/51 Mycol 46/46 (24/28 MP)'
[21:48] * Morrie will spend a great deal of time ensuring everyone's continued survival.
[21:49] * Morrie takes a breath after all of that and looks around. "Everyone all right?"
[21:49] <Kotono> As wounds are mended, the party can see the heap of gil and treasure left behind. The castle somehow seems brighter now, warmer.
[21:49] <Mycol> "I'm doing good, now. You could say I'm doing Better. Than. Fine."
[21:50] <Mycol> "We won! We won!" (music note)
[21:50] * Mycol dances.
[21:50] <Santos> "I'll live."
[21:50] * Lehko stands and moves to help Morrie with Santos.
[21:50] <Morrie> "Well, we probably have some time to make sure those other chests aren't trapped, if you all want to."
[21:50] <Morrie> "Or we can go report to the Icemaiden."
[21:51] <Lehko> "I doubt she would like us to keep her waiting."
[21:52] <Morrie> "Can one of you hold this Potion? I can fit the other things in here."
[21:52] <Morrie> "We can sort it out after we get out of here."
[21:53] <Santos> "I'll hold anything extra for the time being, Morrie. Let's go see Shiva."
[21:53] <Morrie> "All right."
[21:53] <Morrie> "Don't scare me like that anymore, Santos."
[21:54] <Santos> "Eh, don't worry about me. I'm immortal. Even explosions don't take me down for good, remember?"
[21:54] * Lehko heads off towards Shiva.
[21:54] <Morrie> "Still."
