> roll 1d20+30
> roll 1d20+30
<Serith> Kotono roll for Serith < 43 > [d20=13]
<Serith> Kotono roll for Serith < 40 > [d20=10]
> roll 1d20+30
<Serith> Kotono roll for Serith < 31 > [d20=1]
GMW is gone, as is haste. Resist energy remains.
As magic crumbles aorund Ithea, she can dimly hear Sylvie call out. But her world is pain and collapsing sight, her vision bloody red and her breathing labored. Meanwhile, Legion points at Muirfinn next. "You will not escape again." Lixer intones, as suddenly all the magic around him goes into flux, attacking him rather than protecting him.
You're also getting dispelled. What spells do you have on you, tortle?
See Active Effects, also beat my puny SR for additional fun!
Stats: ShowHide
HP: 300/300
AC: 80
Active Effects: Camouflage (+10 circ to Hide), Primal Instinct (), Superior Resistance (+6 to all resistances), Owl's Wisdom (+10 Wis for 1 hour), Halo of Sand (+4 deflection bonus for 2 hours), Sheltered Vitality (Immune to ability damage/drain for 20 minutes), Death Ward (20 minutes)
Passive Effects: Fast Healing 11, immune to disease & poison, SR 27, Immune to cold
Form: Dragon
Thank you. Unfortunately, dispels don't check SR.
> roll 1d20+25 vs camouflage
<Serith> Kotono roll for Serith < 35 > [d20=10]
> roll 1d20+25 vs primal instinct
<Serith> Kotono roll for Serith < 42 > [d20=17]
> roll 1d20+25 vs superior resistance
<Serith> Kotono roll for Serith < 26 > [d20=1]
> roll 1d20+25 vs owl's wisdom
<Serith> Kotono roll for Serith < 38 > [d20=13]
> roll 1d20+25 vs halo of sand
<Serith> Kotono roll for Serith < 39 > [d20=14]
> roll 1d20+25 vs sheltered vitality
> roll 1d20+25 vs death ward
> roll 18d6 damage
<Serith> Kotono roll for Serith < 66 > [d6=5,1,1,5,6,3,4,6,3,4,6,5,6,2,1,3,1,4]
Everything but superior resistance is mulched.
As dozens of mouths on Legion silently howl invectives, the magic around Muirfinn explodes. It scalds and freezes him, ravaging his body as his woven protections succumb. Then dark mist begins to gather around the strange creature, thickening and growing heavier all around it.
Initiative is: Sylvie (43) > Ithea (42) > ??? (36) > Nessian 2 = Legion (34) > Lief (30) > Muirfinn (28) > Nessian 1 (27)
Go Lief.
Muirfinn looks around himself as magic goes insane. "Well, that was uncalled for."
#244
*sees things go badly for the others and focuses on the main cause, Lixer. He calls upon some of his innate magic to help guarantee his next shots hit, and draws arrows for his attack*
OOC: Using True Strike, Quickened
> roll d20+44+2+4+20 ATK 1, Greater Dispel CL 20
> roll d20+44+2+4 ATK 2, Sword of Conscience CL 20
> roll d20+39+2+4 ATK 3, Holy Smite CL 20
> roll d20+34+2+4 ATK 4, Holy Smite CL 20
> roll d20+29+2+4 ATK 5, Holy Smite CL 20
<Serith> Iddy roll for Serith < 75 > [d20=5]
<Serith> Iddy roll for Serith < 58 > [d20=8]
<Serith> Iddy roll for Serith < 53 > [d20=8]
<Serith> Iddy roll for Serith < 54 > [d20=14]
<Serith> Iddy roll for Serith < 49 > [d20=14]
> roll 5#1d6+23+8d6+2d6
> roll 3#10d6 Holy Smite
<Serith> Iddy roll for Serith < 52, 67, 62, 51, 62 >
<Serith> Iddy roll for Serith < 31, 40, 39 >
OOC: Nondetection in effect, targeted one of the barbazu outside, Death Ward, Greater Heroism
AC: 33, HP: 283(+20 Temp HP)/358, -3 Int (Damage)
Damage reduction 10/cold iron, damage reduction 5/-,spell resistance 38, improved uncanny dodge, improved evasion
Caster level check on the SoC and two of the smites.
> roll 1d20+20 CL: SoC
<Serith> Iddy roll for Serith < 36 > [d20=16]
> roll 1d20+20 CL: Holy Smite 1
> roll 1d20+20 CL: Holy Smite 2
<Serith> Iddy roll for Serith < 32 > [d20=12]
<Serith> Iddy roll for Serith < 40 > [d20=20]
Success on SoC and the second smite. Roll the Int/Wis damage, it's 2d8.
> roll 2d8 SoC Ability Damage
<Serith> Iddy roll for Serith < 5 > [d8=3,2]
Lief fires away, arrows peppering Legion as holy power bursts through it. The gestalt creature is knocked back, bits of flesh raining down like meaty dandruff. Bursts of blood follow, coming out in splattering gushes. But Legion isn't put down by Lief's barrage, "Pathetic," Lixer says coldly, as...
Muirfinn, you're up. Best make this one count.
"Well, if you want to play rough, we can start with this." Muirfinn shifts, abandoning his draconic form and whipping a staff from his back. A command word in Terran later causes the area next to the lead pit fiend to heave as a great monolith of earth and stone pulls itself from the aether and smashes into the pit fiend menacing Ithea, interposing itself between the two!
Elemental Monolith. Earth. He unhappy. If there are any protections against summoning, let me know and I will edit post. Otherwise, rolling to hit. Probably just going to be a meatshield until I get my motor running next round.
[23:11] <Yuthirin> roll 1d20+42 slam
[23:11] <Serith> Yuthirin roll for Serith < 45 >12 [d20=3]
[23:11] <Serith> Yuthirin roll for Serith < 53 >12 [d20=11]
Stats: ShowHide
Muirfinn
HP: 300/300
AC: 50
Active Effects: Superior Resistance (+6 to all resistances)
Form: Tortle
Earth Monolith
HP: 489
AC: 25
Active Effects: None
Passive Effects: Augment Summoning
1. Update your active effects after that dispel-o-thon.
2. The area next to the lead Nessian has a problem - Ithea's there and getting maimed after to death.
1. Updated.
2. We're still outside the building right? Just put the elemental in the nearest open space.
You're in the hall leading to the green spire, yes. The problem is that an elemental monolith is a gargantuan creature and you have Ithea up in the Nessian's face. There's not really room for it to cut in like that.
Oh, fair enough. Where IS there room? Between the two devils?
