They're side by side, so no. There's just not room there to summon a gargantuan elemental monolith. There is some room for something smaller between Ithea and then - nothing bigger than Medium. A horizontal wall could also work.
[20:04] <Yuthirin> how tall is the ceiling?
[20:04] <Yuthirin> And how wide is the distance between the walls?
The ceiling is 25ft tall. Plenty of room up there. There's 50ft of distance in the hall - quite wide, but as the Nessians show, building big makes sense on the planes.
"Well, if you want to play rough, we can start with this." Muirfinn shifts, abandoning his draconic form and speaking a word in Auran, like thunder. Abruptly behind the pit fiends appear a line of three living storms, each a towering whirlwind of lightning, wind, and chaos reaching from floor to ceiling and looming menacingly.
By my math, that means a Huge creature would fit nicely. Waiting to see if there are summoning defenses before having them act.
Stats: ShowHide
Muirfinn
HP: 300/300
AC: 50
Active Effects: Superior Resistance (+6 to all resistances)
Passive Effects: Fast Healing 11, immune to disease & poison
Form: Tortle
Greater Storm Elemental
HP: 262 HP
AC: 22
Active Effects: None
Passive Effects: Augment Summoning, Ashbound
HP: 262 HP
AC: 22
HP: 262 HP
AC: 22
There aren't anything that would directly interfere, so continue.
So, distance check. How many feet is it between Ithea/Muirfinn and the elementals?
As one, the elementals lash out with thin bolts of lightning. The bolts strike the pit fiend that attacked Ithea.
Three separate attacks, each dealing 10d4 non-lethal damage. Fort 28 halves each.
[21:12] <Yuthirin> roll 10d4
[21:12] <Serith> Yuthirin roll for Serith < 19 >12 [d4=1,3,2,1,3,2,3,1,1,2]
[21:12] <Serith> Yuthirin roll for Serith < 23 >12 [d4=3,4,2,3,3,4,1,1,1,1]
[21:12] <Serith> Yuthirin roll for Serith < 25 >12 [d4=4,1,3,1,2,3,2,4,4,1]
> roll 1d20+31 1-1
> roll 1d20+31 1-2
<Serith> Kotono roll for Serith < 35 > [d20=4]
<Serith> Kotono roll for Serith < 51 > [d20=20]
> roll 1d20+31 1-3
<Serith> Kotono roll for Serith < 38 > [d20=7]
> roll 1d20+31 2-1
<Serith> Kotono roll for Serith < 48 > [d20=17]
> roll 1d20+31 2-2
> roll 1d20+31 2-3
<Serith> Kotono roll for Serith < 45 > [d20=14]
The blasts of lightning hit the Nessian, who twitches slightly from the onslaught. It merely glances as the elementals as the magic around the violently shudders and breaks.
> roll 1d20+30 elemental 1
> roll 1d20+30 elemental 2
<Serith> Kotono roll for Serith < 46 > [d20=16]
<Serith> Kotono roll for Serith < 40 > [d20=10]
> roll 1d20+30 elemental 3
<Serith> Kotono roll for Serith < 38 > [d20=8]
What's the caster level of your spells, tortle? DC to dispell is 11 + that.
"Resistance is useless!" The second Nessian declares, a wave of stilling will washing over the party.
Will saves. This is paralysis and a mind affecting enchantment. If you're immune, post saying so instead of a save.
> roll 1d20+24 Will Save
<Serith> Iddy roll for Serith < 36 > [d20=12]
> roll 1d20 for Ithea, if it's a 1 it auto fails and otherwise it probably passes. I'll do the math if she rolls low enough where it's relevant
<Serith> Kotono roll for Serith < 11 > [d20=11]
For Ithea.
> roll 1d20+32 Sylvie
<Serith> Kotono roll for Serith < 46 > [d20=14]
Sylvie.
To finish, Muirfinn's immune.
Initiative is: Sylvie (43) > Ithea (42) > ??? (36) > Nessian 2 = Legion (34) > Lief (30) > Muirfinn (28) > Nessian 1 (27)
The wave of magic nearly sends the party to immobility, but Ithea shrugs it off with a force of will. Lief is next, clearing his head and body. Finally, Sylvie just stands her ground, letting it wash off of her. The blonde then explodes into action, flying behind Ithea, just a hair out of reach of the Nessian. Her hand goes out, restoring Ithea. "This may not be a battle we can win," she tersely whispers to Ithea, "We may need to get out of here before we're overwhelmed."
Heal x2 on Ithea for +300 hit points of healing.
Ithea's wounds reverse before your eyes, flesh becoming whole and wounds knitting back together. Ithea's vision clarifies, reality no longer a mishmash of pain and suffering. Meanwhile, Legion's mouths begin to silently sing, as Lixer's voice is heard. "Now, Taelfagn."
Ithea, go.
Given how well they're being countered, Ithea nods in agreement. At least they saw some of what to expect in a future encounter once they're a bit more prepared and Lixer a bit less so. Rubbing the bracelet that Sylvie had previously gifted her, she summons up a gate targeted to Ysgard, rather than Aurora. "We're leaving, everyone."
ooc: If it comes up, CL of the Gate is 17. I'll hold on my move action until I see others going through. If Muirfinn can drag Sylvie through, I'll move with Lief. If not I will wait for Sylvie. Can Sylvie cast gate or just Yuth in case it is dispelled?
Ooc edit: Also I will spend an inspiration for AC, and use inspiration as needed on saves during this round.
