Since she doesn't have the ability to open the door outside of trying to brute force it open, Ithea casts Detect Magic and tries to examine the runes and possibly figure out a way to turn them off or set them to cool again.
ooc:
[20:25] <Merc-zzz> roll d20+40 spellcraft
[20:25] <Serith> Merc-zzz roll for Serith < 50 > [d20=10]
ooc: Is there a way to UMD the runes off? Dispel? Or is disable device the only way outside of finding an actual mechanism further in as far as I can tell?
*Follows after Ithea!*
OOC: Nondetection in effect, targeted one of the barbazu outside.
AC: 33, HP: 358
Damage reduction 10/cold iron, damage reduction 5/-,spell resistance 38, improved uncanny dodge, improved evasion
Ithea's study of the runes comes, but heat continues to blast the party.
> roll 10d6
<Serith> Kotono roll for Serith < 33 > [d6=1,3,1,3,2,6,2,4,6,5]
3 more fire damage to all but Muirfinn. This isn't enough to warrant a Concentration check, as you'll auto pass it.
But Ithea is able to work past the burning pain, ignoring the scorching of her skin, slowly progressing. She thinks the runes could be dispelled, but you'd need to find the source of them. Studying them, you can tell they're just extensions of the main source of the enchantment - which, interestingly, you can follow and tell it's somewhere past the door to the right. Once there, you could dispel it or perhaps UMD it or disable device, it'll depend on how exactly its set up.
"Look," Sylvie calls as she grimaces, skin reddening, "We need to move or fall back, before we end up baked alive."
Muirfinn nods along, eyeing the door. He shifts back to tortle form, raises a wand to the door on the right and speaks a command word.
Crumble on the door.
> roll 10d8 for Yuth
<Serith> Kotono roll for Serith < 52 > [d8=1,8,8,8,1,5,4,8,6,3]
HP: 300/300
AC: 70
Active Effects: Camouflage, Primal Instinct, Superior Resistance, Fast Healing 11, all spells Energized
"Maybe not. The source of the runic enchantment seems to be on the other side of the door on the right hallway. If we get to it, we can disable or dispel it. Failing that though, we definitely should retreat then," Ithea explains her findings as she starts backtracking to the other hallway, casting a disintegrate at the right door as it comes into view, deciding not to waste any time on it.
OOC: since int-based speed at the moment, should easily be able to reach the right door even going back down the left hall and then down the right hall.
[11:57] <Merc> roll d20+30 ranged touch
[11:57] <Serith> Merc roll for Serith < 41 > [d20=11]
[11:57] <Merc> roll 40d6
[11:57] <Serith> Merc roll for Serith < 140 > [d6=2,3,1,5,2,2,6,3,3,2,6,5,1,1,1,2,3,4,1,5,6,6,4,2,4,5,4,4,2,5,6,5,3,6,1,3,6,4,4,2]
Ithea's HP: 329/346
Few things. First of all, reroll since your damage is wrong. The version in the SC (which trumps the CD version) is 1d8 per level, to a max of 10d8. Secondly, just tell me the book next time instead of telling me to look in chat. Easier for me.
Just to keep things updated accurately:
-Everyone should have taken 4 damage from first fire burst. Muirfinn shapeshifted after that.
-Everyone else should have taken an additional 13 damage (total 17).
So HP should be:
-Ithea 329/346
-Lief 341/358
-Sylvie 273/290
-Muirfinn 296/300
"OOC: Ithea's Combat Stats": ShowHide
HP: 329/346
AC: 56 , 39 (Touch), 56 (Flat-footed), 77 (CMD)
Qualities: DR 10/silver, SR 34, Darkvision, Low-Light Vision, +4 CMD vs Trip/Overrun/Bullrush, Evasion, Uncanny Dodge
Abilities:
Racial: Healing Touch 0/1,
Rogue: Mimic 0/1,
Factotum: Inspiration 0/6, Nerveskitter 0/1, Heroics 0/1, Piety 0/9
Duskblade: Attunement 1/14, Quick Cast 1/4
Feats: Chaos Devotion 0/1
Gear: Counterstrike 0/2, Greatreach 0/3, Reciprocate 0/2, Haste 0/10 (rounds), Daylight 0/1, See Invis 0/1, +2d6 electric damage 0/3
Spells:
Lv 0 - 0/6
Lv 1 - 1/23
Lv 2 - 0/23
Lv 3 - 1/23
Lv 4 - 0/18
Lv 5 - 2/14
Thank you, that's correct. I'm keeping Sylvie's HP in my notes.
People, please remember to include the requested information in your posts. HP, armor class, ect.
Calling for a reroll of 10d8 please. Will edit post. Also, updating post to c/p for the future.
> roll 10d8 for Yuth
Work, so I'll post again when I get home.
Between Muirfinn's spell and Ithea's disintegration, the door disintegrates, even as the party is basted in heat. As you sizzle, you see ahead. Pure, pitch black darkness that Ithea and Lief can't see through. However, Muirfin's true seeing allows him to see through. This room is full of runes like the previous room, as well as silver orbs that hang in the air. They float a few feet off the ground and sizzle in the heat. But that's not the problem. The problem is that there are a dozen erinyes standing there, bows ready.
At the same time Sylvie's eyes widen, "Look-" she begins, before waves of greasy, sickening darkness envelope the party, save for Lief, who is still hanging back.
> roll 10d6
<Serith> Kotono roll for Serith < 31 > [d6=6,1,4,3,2,6,2,1,3,3]
1 more point of fire damage to all. Includes tortle this time, as he shifted to humanoid form.
> roll 1d20+13 caster level check
<Serith> Kotono roll for Serith < 29 > [d20=16]
This does not penetrate Ithea's spell resistance. Pick your benefit from the spellwarped template, Ithea. Muirfinn and Sylvie need to make Will saves, as they don't have spell resistance. As Yuth isn't here, I'll roll his Will save.
> roll 1d20+46 (+14 inspiration 11/12 left for encounter)
<Serith> Kotono roll for Serith < 63 > [d20=17]
> roll 1d20+31 Muirfinn Will
<Serith> Kotono roll for Serith < 34 > [d20=3]
> roll 20d8 halve this Sylvie
<Serith> Kotono roll for Serith < 89 > [d8=1,5,3,7,3,4,8,5,4,6,2,7,7,3,1,3,8,2,7,3]
> roll 40d6 halve this Muirfinn
<Serith> Kotono roll for Serith < 137 > [d6=2,5,6,1,2,2,3,4,6,5,1,2,5,6,2,5,3,3,2,2,4,5,5,3,3,3,4,3,4,4,5,3,6,1,1,3,2,4,4,3]
44 damage to Sylvie and 68 to Muirfinn.
Okay, time to roll initiative. Clearly the devils are letting you get (in theory) baked by the fire and battered down by defenses.
Gain temp HP, which is 5x spell level.
[20:54] <Kotono> Unholy blight is 4th, but the mass of them bumps it up to a 6th level spell.
Ithea gains 30 temp HP.
Ithea's at 328+30/346.
She uses Nerveskitter to gain +5 to init on top of Lief's +5.
[20:57] <Merc> roll d20+22+10 nerveskitter+Lief bonus to Ithea
[20:57] <Serith> Merc roll for Serith < 34 > [d20=2]
Muirfinn shifts quickly back to dragon form, shaking off the darkness and growling.
[23:04] <Muirfinn> roll 1d20+20 init
[23:04] <Serith> Muirfinn roll for Serith < 26 > [d20=6]
HP: 232/300
AC: 70
Active Effects: Camouflage, Primal Instinct, Superior Resistance, Fast Healing 11, immune to fire
> roll 1d20+21 Lief
<Serith> Kobrb roll for Serith < 23 > [d20=2]
> roll 1d20+29 Sylvie (+5 Lief's aura)
<Serith> Kobrb roll for Serith < 41 > [d20=12]
* Merc is now known as Merc-zzz
> roll 1d20+7 Erinyes squad
<Serith> Kobrb roll for Serith < 23 > [d20=16]
Init order is: Sylvie(41) > Ithea(34) > Muirfinn(26) > Lief=Erinyes Squad (23) > Environmental Damage (Heat) (0). Sylvie opens and she'll go first this time.
"Ugh," Sylvie grimaces in pain, diving forward and out of the darkness. She lands in a roll and on her knees, springing to her feet moments later. "Damn it, Ithea, your luck's spreading." She dives right into the enemy ranks, fists a flurry of blurred blows.
> roll 1d20+36
<Serith> Kobrb roll for Serith < 52 > [d20=16]
> roll 1d20+36
<Serith> Kobrb roll for Serith < 37 > [d20=1]
> roll 1d20+31
<Serith> Kobrb roll for Serith < 45 > [d20=14]
> roll 1d20+40 (+14 inspiration 10/12 left for encounter)
<Serith> Kobrb roll for Serith < 60 > [d20=20]
> roll 1d20+40 (+14 inspiration 10/12 left for encounter) crit?
<Serith> Kobrb roll for Serith < 55 > [d20=15]
> roll 1d20+35 (+14 inspiration 9/12 left for encounter)
<Serith> Kobrb roll for Serith < 52 > [d20=17]
> roll 3d10+28 hit 1
<Serith> Kobrb roll for Serith < 51 > [d10=8,7,8]
> roll 3d10+28 hit 2
<Serith> Kobrb roll for Serith < 38 > [d10=1,6,3]
> roll 6d10+56 hit 3 crit and gets 1/2 of the damage as temp HP
<Serith> Kobrb roll for Serith < 95 > [d10=8,9,3,5,5,9]
> roll 95/2
<Serith> Kobrb roll for Serith < 47 >
> roll 3d10+28 hit 4
<Serith> Kobrb roll for Serith < 42 > [d10=5,7,2]
One erinyes gets a jab to the throat, collapsing as it claws at its neck. Another is kicked in the head, a loud crack as her roundhouse snaps neck and skull equally. As she wades in, a burst of glowing white life-energy coming from the neck-broken erinyes and into her fists, "We need to finish this fast and keep going. Come on!"
Ithea, you're up.
