When the world goes boom (Calleigh)
Started by Anastasia, December 16, 2015, 09:23:11 PM
[15:26] <Kobot> Muirfinn rolled 1d20+26 --> [ 1d20=20 ]{46}
The woman above you is a valkyrie.
You passed the result by a ton, so I'll just link you to the generic valkyrie sheet. It's likely she's an advanced specimen and thus has greater abilities than the norm.
http://www.soulriders.net/forum/index.php/topic,103072.msg1059418.html#msg1059418
Calleigh uses Detect Magic and passes along everything she can see to Tryll, who acts accordingly!
Also since she can use my skills,
[10:57] <Kobot> Muirfinn rolled 1d20 --> [ 1d20=11 ]{11}
Plus Tryll's ranks in Psicraft and Calleigh's Int mod: 11+26+3=40
The swords around the valkyrie? Magic. Her armor? Magic. Herself? Oh, several different enchantments. She's prepared for war, but it would take more time of studying to get more than that.
Tryll.
Discordant reality lashes out across the intervening space at the woman!
Dispel Psionics, augmented
PP Cost: 10
Allows up to +20 to dispel.
Hitting her and the area around her.
[11:15] <Kobot> Muirfinn rolled 1d20+20 Dispel --> [ 1d20=7 ]{27}
Tryll
HP: 183
AC: 43
Touch AC: 28
Flatfooted AC: 39
Active Effects: Inertial Armor
PP: 450
Calleigh
HP: 91
AC: 45
Touch AC: 25
Flatfooted AC: 36
Passive Effects: Magic Circle Against Evil, Tongues
Psicrystal
HP: 61
AC: 29
Touch AC: 14
Flatfooted AC: 29
The magic around the valkyrie is assaulted - but like soldiers against a great wall, they hit it and fail, becoming little more than a dashed memory against it.
"Is that it?" The valkyrie asks, descending to 50ft down. She imperiously gestures at Calleigh and Dana, her blades all flying from her to assail the both of them.
> roll 1d20+32 vs Calleigh
<Kobot> Ko-NitorisImpossibleDemand rolled 1d20+32 vs Calleigh --> [ 1d20=2 ]{34}
> roll 1d20+33 vs Calleigh
<Kobot> Ko-NitorisImpossibleDemand rolled 1d20+33 vs Calleigh --> [ 1d20=19 ]{52}
> roll 1d20+33 vs Calleigh crit?
<Kobot> Ko-NitorisImpossibleDemand rolled 1d20+33 vs Calleigh crit? --> [ 1d20=6 ]{39}
> roll 1d20+31 vs Dana
<Kobot> Ko-NitorisImpossibleDemand rolled 1d20+31 vs Dana --> [ 1d20=10 ]{41}
> roll 1d20+35 vs Dana
<Kobot> Ko-NitorisImpossibleDemand rolled 1d20+35 vs Dana --> [ 1d20=15 ]{50}
> roll 2d6+20+1d6+1d6 (first 1d6 is fire and the second is cold in case she has resistances)
<Kobot> Ko-NitorisImpossibleDemand rolled 2d6+20+1d6+1d6 (first 1d6 is fire and the second is cold in case she has resistances) --> [ 2d6=11 1d6=3 1d6=5 ]{39}
The blades soar down and out, two clanging against Dana's shield. She blocks both of them quickly, all while Calleigh tries to dodge. She manages to avoid one, only for the other to graze her. Unfortunately, it's a greatsword, so a graze is akin to a deep slice to the tiny little courre. It cuts deep into her side, blood welling out from the wound.
Dana's up.
"Oh fuck you," Dana calls up. "Fuck you and the unicorn you fucked on the way over here!"
On second thought, she'll hold a sec to give Tryll and Calleigh a chance to act before she tries something. Go you two. Psicrystal too if he's going to do anything.
A translucent sphere of force appears around the group, but is ignored by the swords.
"Agh!" Calleigh shrieks as she is sliced by the falling blade.
Intellect Fortress manifested for 5 rounds. Immediate action. I know this will ignore it but this is just in case she decides to start blasting too.
PP Cost: 11
Tryll
HP: 183
AC: 43
Touch AC: 28
Flatfooted AC: 39
Active Effects: Inertial Armor, Intellect Fortress
PP: 439
Calleigh
HP: 57
AC: 45
Touch AC: 25
Flatfooted AC: 36
Psicrystal
HP: 61
AC: 29
Touch AC: 14
Flatfooted AC: 29
Okay then. Dana'll take her held action.
Intiative order is Tryll = Calleigh (26) > Dana (18) > Valkyrie (17) > Psicrystal (3)
"Hey bitch," Dana cries, her head shifting into a black scaled, draconic visage. Her voice turns into a guttural roar, "FUCK YOU!"
Breath of the black dragon on the dancing weapons around her, augmented to 22 PP for 22d6 damage. Reflex half.
> roll 1d20+20 reflex vs DC 23
<Serith> Kotono roll for Serith < 28 > [d20=8]
> roll 22d6
<Serith> Kotono roll for Serith < 92 > [d6=3,3,6,6,6,1,4,4,5,5,1,5,5,1,1,2,4,6,6,6,6,6]
46 acid damage to each weapon before any hardness.
The swords are grazed by her acid breath, splashes of it sizzling against the bare metal. Foul steam rises up from the two, but neither is down yet. Indeed, the valkyrie looks down with a scowl, "An ill tempered cur, eh?" she mutters to herself, descending down to the ground and gesturing with her free hand. "Come at me, you crazed bitch!" She then settles into a ready stance.
Meanwhile her weapons keep striking, two on Calleigh and two on Dana.
She's in some sort of offensive stance, ready to strike. Psicrystal and then Tryll and Calleigh are up.
<Serith> Kotono roll for Serith < 45 > [d20=13]
<Serith> Kotono roll for Serith < 37 > [d20=4]
<Serith> Kotono roll for Serith < 47 > [d20=16]
<Serith> Kotono roll for Serith < 42 > [d20=7]
> roll 1d8+20 and 1 Con damage Calleigh
<Serith> Kotono roll for Serith < 27 > [d8=7]
A direct hit. Calleigh is skewered on the side, wobbling in the air as she bleeds profusely. She can barely stay aloft, the dancing weapons devastating her.
Go, psycrystal and the two of you. Dana's after and then valkyrie again.
Dana: 313/313 Power Points: 195/239
"Who cuts up a courre!? THAT'S SO MEAN!" Calleigh shouts.
Psicrystal holding action until after Tryll's.
Time slows...or the three speed up. One of the two. Either way, vigor is bestowed, and wounds rapidly close.
As time resumes its normal flow, the mist spreads, thinning as Calleigh pales a bit. Abruptly, six blooms of explosive noise detonate in a tight circle around the valkyrie.
Manifesting Temporal Acceleration, Vigor, True Metabolism, Inconstant Location, Twinned Energy Barrage
PP Cost: 23
Lasts 3 rounds
Shaken for 1 round
Vigor
PP Cost: 20
Lasts 24 minutes
100 temp HP for Tryll, Callegh, Psicrystal
True Metabolism
PP Cost: 15
Lasts 24 minutes
Fast healing 10
Inconstant Location
PP Cost: 11
Lasts 1 minute
Swift teleport at will, max distance equal to move speed.
Energy Barrage, Twinned (sonic)
PP Cost: 21
Expending Psionic Focus
DC 27 Reflex to halve. Per text, save for each explosion individually.
[20:29] <Serith> Muirfinn roll for Serith < 23 >12 [d6=1,5,4,5,5,3]
[20:29] <Serith> Muirfinn roll for Serith < 16 >12 [d6=1,1,5,1,2,6]
[20:29] <Serith> Muirfinn roll for Serith < 30 >12 [d6=2,6,6,4,6,6]
[20:29] <Serith> Muirfinn roll for Serith < 20 >12 [d6=2,5,4,5,1,3]
[20:29] <Serith> Muirfinn roll for Serith < 24 >12 [d6=5,6,4,6,1,2]
[20:30] <Serith> Muirfinn roll for Serith < 16 >12 [d6=3,2,1,5,1,4]
Calleigh blinks away from the blades, appearing 60 feet away to her right!
Before Psicrystal and Calleigh finish acting, how far away is the Valkyrie, and is she in Melee range of Dana?
Tryll
HP: 183+100
AC: 43
Touch AC: 28
Flatfooted AC: 39
Active Effects: Inertial Armor, Intellect Fortress, Vigor, True Metabolism, Inconstant Location, Shaken 1 round
PP: 349
Calleigh
HP: 7+100
AC: 45
Touch AC: 25
Flatfooted AC: 36
Psicrystal
HP: 61+100
AC: 29
Touch AC: 14
Flatfooted AC: 29
The valkyrie is 40ft away from you. She's not in melee range of Dana yet, though Dana looks about ready to change that.
Saves rolled and ready for when you're done, I'll hash it all out then.
> roll 1d20+20 reflex vs DC 27
<Serith> Kotono roll for Serith < 27 > [d20=7]
<Serith> Kotono roll for Serith < 40 > [d20=20]
<Serith> Kotono roll for Serith < 36 > [d20=16]
<Serith> Kotono roll for Serith < 24 > [d20=4]
<Serith> Kotono roll for Serith < 33 > [d20=13]
Calleigh pulls a wand from her pack, pointing it at herself. "SHAZAM!" And she vanishes.
Greater Invis, 7 rounds.
The Psicrystal will hold until Dana's turn is over.
Dana bulls right on ahead as Calleigh vanishes, a wordless shout of challenge as she comes in shield first, bashing her back before trying to skewer her with her rapier. A chain of bright white ectoplasm forms over her arms and legs, her armor pushed out as her muscles bulge.
Using chain of personal superiority+4 for +4 insight to Strength and Constitution for 1 minute. That's a free action.
> roll 1d20+41 (+2 charge, +2 chain of personal superiority, -4 PA)
<Kobot> Ko-NitoriSolvesProblems rolled 1d20+41 (+2 charge, +2 chain of personal superiority, -4 PA) --> [ 1d20=16 ]{57}
> roll 1d20+41 (+2 charge, +2 chain of personal superiority, -4 PA) crit?
<Kobot> Ko-NitoriSolvesProblems rolled 1d20+41 (+2 charge, +2 chain of personal superiority, -4 PA) crit? --> [ 1d20=19 ]{60}
> roll 2d6+64 (+7 offensive prescience, +4 PA)
<Kobot> Ko-NitoriSolvesProblems rolled 2d6+64 (+7 offensive prescience, +4 PA) --> [ 2d6=5 ]{69}
Dana charges right into the valkyrie's personal space, managing to skewer her in the outer shoulder. The two come face to face for one moment, a smirk on Dana's face. Then the valkyrie rears back and headbutts her back, rapier and all tearing out. A moment later she materializes a huge lump of iron in her hands. It's a cudgel of sorts, as much a hunk of iron that was once half melted and then cooled. She steps back and swings, right for Dana's middle.
Valkyrie is using her counterattack ability.
> roll 1d20+46 (+4 ???, +2 ????)
<Kobot> Ko-NitoriSolvesProblems rolled 1d20+46 (+4 ???, +2 ????) --> [ 1d20=2 ]{48}
But Dana brings her shield up, the silver scaled shield holding up under the impact. Freezing mist is sent gushing out in all directions from the blow, akin to hot steel being quenched in water.
Psycrystal was holding. Do you want to go now as desired?
[spoiler]Dana: 313/313 (357/357) Power Points: 195/239 Buffs: Offensive Prescience (+7 insight damage), Chain of Personal Superiority (+4 insight Strength/Constitution)
Behind and just overlapping the valkyrie, a many-tentacled mass of translucent ectoplasm forms. Its shapeless, undulating, and rugose form enveloping the area and jostling everything nearby with uncomfortable pressure.
Manifesting Ectoplasmic Shambler, edge just overlapping the valkyrie. Covers a 30x30ft area up to 10 feet high. 20 ft high in the center. Immediate 12 physical damage.
All spells/powers/etc require a concentration check of 15 + power's or spell's level.
It looks sort of like this guy!
