Hammer (Ithea, Moore)
Started by Anastasia, March 19, 2016, 06:07:23 PM
First post is setup. Don't reply until after the next post.
Hammer
Command: Ithea (Strike Force)
Officers: Baleruk, Moore, Crystal, Misalea, Arrel, Stille, Origin
Forces:
Lathander's Adamantine Golem Squad
1 Battle Horror
98 Ysgardian warriors. They range from 2 to 5 hd, having levels in fighter and barbarian. Several have lycanthropy, blessed by Selune to be able to control it. Alignment: Chaotic Good. Morale: 100/100 (Devoted)
131 female students of the Graceful Blow. They range from 4 to 10 hd, having levels in sorcerer, fighter and swashbuckler. Alignment: Chaotic Good, Neutral Good, Neutral and Chaotic Neutral. Morale: 100/100 (Devoted)
40 pixies from Lifasa. They range from 3 to 6 hd, having levels in rogue, sorcerer, ranger and scout. Alignment: Neutral Good. Morale: 70/100 (Good)
205 air elementals of small, medium and large size. They range from 3 to 10 hd, having levels in fighter and aerial avenger. Alignment: Neutral. Morale: 82/100 (Fanatic)
500 Ysgardian Regulars of medium size. They range from 3 to 12 hd, having levels in fighter, paladin of freedom, ranger and barbarian. Alignment: Chaotic Good, Chaotic Neutral. Morale: 95/100 (Fanatic)
50 Sylican regulars of medium size. They range from 3 to 12 hd, having levels in many different classes. Alignment: Lawful Good, Neutral Good, Chaotic Good. Morale: 70/100 (Fair)
20 knights of the wise convent. They range from 6 to 12 hd, having levels in fighter, rogue and knight of the wise convent. Alignment: Lawful Good, Neutral Good, Chaotic Good. Morale: 77/100 (Good).
28 air elementals of shinear. They range from 3 to 10 hd, having levels in dragon shaman. Alignment: Neutral, Neutral Good. Morale: 80/100 (Good)
50 elven detachment of the confederation of liberators. They range from 5 to 12 hd, having levels in many different classes. Alignment: Chaotic Good. Morale: 77/100 (Good)
100 triune courre. They range from 3 to 5 hd, having levels in cleric, healer and favored soul.  Alignment: Chaotic Good. Morale: 87/100 (Fanatic)
84 pixies of the purple pixie brigade. They range from 5 to 10 hd, having levels in rogue, fighter and scout Alignment: Chaotic Good, Chaotic Neutral, Neutral. Morale: 70/100 (Good)
50 freed eidolons of rimefire. They range from 12 to 13 hd, having levels in sorcerer and frost mage. Alignment: Chaotic Good. Morale: 60/100 (Fair)
30 ladies of the butterfly kinship. They range from 7 to 10 hd, having levels in druid. Alignment: Neutral Good, Neutral, Chaotic Neutral. Morale: 74/100 (Good)
100 lantern archons. They range from 3 to 4 hd, having levels in scout. Alignment: Lawful Good. Morale: 60/100 (Fair)
210 lillend. They range from 8 to 14 hd and have levels in bard. Alignment: Chaotic Good. Morale: 70/100 (Fair)
Quick question, Ithea. What officers are you keeping around you and which ones are dealing with the troops? I assume you're keeping at least one near you for obvious reasons.
Let's keep Moore with me, since he's more of a buffer than combat guy. Plus that way you don't have to worry about potential second thread for him.
Fantastic.
The strike force strides in immediately. The very front of the spherical area here is calm. Celestials patrol about, flying amid open air, walking where earth is and swimming when needed. Fire is extinguished and paths are made. The zone of control extends perhaps half a mile, your forces getting cheers as you go in.
"Everyone be careful, and warn others if someone gets past! Try to minimize that, but don't worry too heavily either! Jaela and her group can handle a few incursions that get past us!" Ithea says. "Good luck, be safe, win your fights!"
Can we assume we had time for Heroes' Feast lunch? And if so, would Baleruk be able to fit at our cafeteria?
I assumed yes for myself anyway. You can handle the other officers feasting or not, and Moore can do himself~
[17:21] <Merc> roll d8+10 heroes feast Ithea
[17:21] <Rei-chan> Merc rolled : d8+10 heroes feast Ithea --> [ 1d8=8 ]{18}
[17:21] <Merc> yay
Yes and Baleruk can manage to get food, sure.
The strike force leads on. The first choice is ahead, at the edge of the celestial's zone of control. A large rock face of stone blocks the way directly ahead, extending up and down for several hundred feet in both directions.
"Sir," A lillend approaches Ithea, "Inspire us - should we go around this mountain or attempt to obliterate it?"
Do I feel like I can use anarch abilities to split a path open?
You're not sure. One way to find out.
Ithea adopts a pensive look briefly as she attempts to control and split open a path forward through the rock with her mind, hoping they're close enough for it to work.
Someone roll a wisdom check for Ithea, please!
Roll d20+8+8 Wisdom check + Anarch bonus (assuming bonus applies)
[14:28] <Nephrite> roll 1d20+8+8 Anarchy Roll
[14:28] <Rei-chan> Nephrite rolled : 1d20+8+8 Anarchy Roll --> [ 1d20=9 ]{25}
It's...sort of chaotic here? It's possible but harder. Ithea works her mind as much as it can - until the rock ahead of them cracks loudly and breaks in two, the mountain falling away and revealing empty space within - save for one thing that floats there. A single building of black obsidian, an oversized hut.
Moore opens his mouth and then shuts it again, only to open it again once more.
"Does that normally happen?" He asks.
"The hut? Probably not. The mountain splitting? That was Afina being right about my anarch abilities being of use here. Harder than Limbo, but still doable. Not sure how well that trick will work in combat," Ithea answers Moore first before turning to the lilend. "Through it seems like it'll work this time."
