Wiped clean (Moore)
Started by Anastasia, August 22, 2016, 02:05:30 PM
Healing isn't hard, you sing and enable others. The wounded are relatively minimal, at least those you can heal. Kascha in phoenix form oversees it all, constantly healing with her phoenix cry. Once that's done, "Attention! We need those who can cast wish or miracle to come forward," She calls. "If you can, present yourself now."
Well, he can't cast those -exact- spells, but he can do something similar! He'll fly forward nonetheless.
Healers - Hanna, Balyss, Priest, the Jarl. They all step forward with you. "Good!" Kascha says, "You'll need to go to the infirmary, since our research suggests that's the most reliable way to cure Styx exposure." Kascha retakes human form, fiery feathers shrinking into her body and form shifting back. "I've worked with all of you before," The others get a nod, "What spell can you manage, Moore?"
"Ah, the more limited version of Wish. But I can also help augment the spells of others, if that would be more beneficial." Moore answers.
Kascha pauses in consideration, "Come along," she finally says, "Most of the healing's done anyway.'"
"I might be able to help with the memory loss, also. Well... mm, maybe not, but I can try, if you'd like." Moore says as he follows along.
"Another hand could help, even one that's only possible," Hanna agrees, "We'll be busy with this for days either way."
"Alright then," Kascha smiles brightly and leads you within.
Gonna briefly move you back into Jaela's new thread then probably back to this one after.
He's going to go back to his room and use Divination (the spell) to ask the following question: "Where should we seek answers to nullifying or protecting ourselves from the waters of Styx?" The chance should be 85% and I will post the expenditure.
"Seek the truth that cannot be taken away." is your answer.
Is it reasonable for him to believe that that's most likely referring to 21?
Hmm. Well, the best he can do with advice like that is go ask someone who might know, so he'll go look for Tepen!
Tepen is hectic. He's made a base of operations in the Entrance Hall, a single chair and desk having been moved there. Runners come and go as he talks to them, giving out orders. Sage Vul'lath's acolytes help him as he writes away. There's a line and you have to wait a good twenty minutes before you get to see him. "Moore?" he asks, looking up, "As you can see, I'm busy settling out the results of the battle and comprising a battle summary. What do you need?"
"It may not be the best time, but I'm trying to help find a solution to Styx. I was given the divination to 'seek the truth that cannot be taken away.' I know the explanation of 21 has something to do with that, but I wasn't sure if that's exactly what it might be referring to. Do you have an opinion? I... ah, well, if you think it'd be best to just seek the knowledge in the library, I can do that." He says, offering a small smile. "Or I can help with this, if you need."
