Wrap up (Various)
"Thank you, Jaela," Afina says, sure to find a good use for that spell. As they come out onto the platform she peers down into the chasm and then looks at the tunnel their current path takes them on. "We all have wings, there's no reason to stick to the obvious path," she decides, veering into open air and starting to descend into the chasm alongside the falling unfrozen water.
Afina: 215+22/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), shield (CL 24), greater heroism (CL 24), fortunate fate (CL 24), haste (CL 24), lion's roar (CL 24), divine insight (CL 24)
AC 77, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/7/9/8/8/6/4/8/7/8/5/0
Init: +24
Attack: ice sword +44 (1d4+10 +5d6 skirmish +2d6 swift +1d6 sudden strike)
Saves: Fort: +21 (+25 vs poison), Ref: +34, Will: +29
Jaela follows after Afina, leaving an eye on Mirajane to prioritize her daughter's safety should anything happen.
Hanna and Mirajane follow. The latter says, "They have to know that, so this may be more difficult than anticipated," she warns.
"Naturally," Hanna agrees, "Stay close to Jaela and I case something goes wrong," Hanna says, mimicking Jaela.
Hanna http://www.soulriders.net/forum/index.php/topic,103876.msg1078446.html#msg1078446
HP: 378/378 regeneration 11
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Greater Mage Armor (CL5), Epic Mage Armor (CL24), Heroes Feast (CL20), Divine Insight (CL24)
Bonuses: +20 armor bonus to armor class, +1 morale attack rolls and Will saves, immunity to fear and poison
Resources Used: 1 rage
Mirajane http://www.soulriders.net/forum/index.php/topic,103876.msg1078449.html#msg1078449
HP: 341+1/341
Resources Used: 1 rage, 1 turn
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
"Is that your seer's opinion?" Afina asks Mirajane as they descend. Personally she was thinking there might be something nice down here to reward those who think beyond the obvious.
"No, just my common sense," Mirajane quips as you fly on down. As you do, cold mists from the plunging waters begin to obscure things. It's chilly and clings to your skin, as well as starting to reduce your range of vision.
Afina's senses are sharp enough not to be bothered by a little mist, though she slows down her descent enough to properly take advantage of them.
Slowing to 30 feet per round so I don't blunder into anything beyond blindsense range
#396
Jaela doesn't rely on her sight that much to begin with! But she does try to keep everyone around, and will call out if one of them is drifting too far away.
Hit Dice 401+22hp [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Init: +7
Speed: 40ft (land)/120ft (flight, perfect maneuverability) [10ft enhancement from Longstrider]
Armor Class: 23 touch AC, 44 normal AC with no gear/19 normal AC under antimagic [12 from dex and cha/-12 when flat footed, 1 from natural armor, 20 force from epic mage armor, +5 sacred with Shield of Warding, +3 luck from Recitation, 1 from Haste]
BAB/CMB/CMD: +22/+27/49
Magical Ice Spear Attack: +36 = +22bab+5str+1weapon focus+2melee weapon mastery+5GMW+1haste
Magical Ice Spear Damage = +25 = +7strx1.5+2weapon specialization+2melee weapon mastery+9holy warrior+5GMW
Ray Attack: +26 = +22bab+3dex+1weapon focus
[Knowledge Devotion not counted]
Resistances and Immunities: Fire Resistance 10, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 10, Damage Reduction 20/Epic and Evil and Cold Iron, Spell Resistance 34 (43 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated.
Saves: Fort +36, Ref +28, Will +36 [Antimagic: -2 to each save, Conviction: +5 to each save]
Precast/Bead of Karma: Contingency/Righteous Might when Jaela casts Holy Transformation CL30, Energy Immunity/Cold CL30, Permanency/Greater Blindsight CL30 [Blindsight for 60ft], Permanency/Mantle of Good CL31, Permanency/Prestidigitation CL30, Celestial Brilliance CL30, Extended Lore of the Gods CL30 (10hr duration), Righteous Halo CL30, Longstrider CL25, Moment of Prescience CL25
Precast: Epic Mage Armor CL24, Fortunate Fate CL24, Conviction CL24, Sign CL24, Divine Insight CL24, Spell Turning CL24, GMW CL24, Haste CL24, Heroes's Feast CL20, Mind Blank CL17, Planar Tolerance CL7
Favored Soul slots left, 01-11: 8/1/8/3/8/7/3/6/6/5/3
CL 24 Favored Soul, CL 18 Divine Crusader [CL boosters for War and Force active, for Abjuration and Protection gone]
Spell/SLA DC: 19 + spell level
-1 Turning
Spot checks, y'all. Note if you have blindsight/sense or other unusual perceptions as well.
[20:22] <Rin> roll 1d20+10+15
[20:22] <Serith> Rin roll for Serith < 37 > [d20=12]
Blindsight 60ft, Darkvision 60ft
[18:24] <@Ebiris> roll 1d20+39 spot
[18:24] <Serith> Ebiris roll for Serith < 45 > [d20=6]
Blindsense 30, low-light, darkvision 60
> roll 1d20+33 Hanna
<Serith> Kotono roll for Serith < 38 > [d20=5]
> roll 1d20+52 Mirajane (+15 divine insight, she'll tap that)
<Serith> Kotono roll for Serith < 72 > [d20=20]
> roll 1d20+72 could be relevant
<Serith> Kotono roll for Serith < 89 > [d20=17]
Both of you can feel it, sense it. Ice is gathering around all of you in a coating, something Mirajane seems to notice as well, since her eyes go wide. Tiny bits, barely perceptible under the best circumstances, but in a steady manner. Stealthily covering you, working almost perfectly unseen.
"Mother," Mirajane says, "Can you fly if your wings freeze up and lock into place?"
"Ye-- fuck, no, I lost the spell with my fancy circlet! But I bet I could glide," Jaela responds. "Can you see how far we are from the bottom?"
She spreads her wings all the way to create the largest drag, and then decides to form another pair of wings from yellow light. Magical light can cut through things and stop gases, depending on coloration, so maybe it could slow her down if the need occurs and she hits on the right color?
And also recasting Divine Insight
She could try summoning some air elementals which wouldn't be bothered by frost, but the actual cold of the plane itself would kill them fairly quickly. "Hanna, you're really strong aren't you?" she flies over and lands atop the planetar's head, imbuing her with the power to walk on air. "Carry us!"
CL 24 Air Walk sla on Hanna. Thank you Bubbles for reminding me I have it!
"All of you," Hanna fires back quickly.
"You have two big strong arms for your delicate elfin little daughter and granddaughter, don't you? And I won't hear any complaints about my weight," Afina says from her perch atop Hanna's head.
