Wrap up (Various)
No one ever shouts for Afina! But she's there for Mirajane anyway, moving ridiculously fast to catch up!
6th level slot sacced for one round of time stop, I'll fly up around the now stationary rocks to catch up with Mirajane.
Catching up with the beleaguered angel just as things start to move around her subjective pace once more, she grabs Mirajane and dimension doors her down to where Jaela and Hanna are.
[17:58] <@Ebiris> roll 1d20+35 concentration if it's needed
[17:58] <Serith> Ebiris roll for Serith < 48 > [d20=13]
Afina: 215+2/215, glaciante's spiteful ward (CL 24 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), planar tolerance (CL 7), epic mage armour (CL 24), moment of prescience (CL 24), fortunate fate (CL 24), control temperature (CL 24), good hope (CL 24)
AC 68, spell resistance 39, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear
Spell charges: 6/7/9/6/6/6/2/8/7/8/4/0
Init: +24
Attack: ice sword +41 (1d4+12 +5d6 skirmish +2d6 swift +1d6 sudden strike)
Saves: Fort: +19 (+23 vs poison), Ref: +31, Will: +27
Caster level check in this case, since the ice she's starting to sink into offers supernatural resistance, enough to possibly disrupt the teleport or come with it.
[18:19] <@Ebiris> roll 1d20+24 CL
[18:19] <Serith> Ebiris roll for Serith < 27 > [d20=3]
You teleport her - and the chunk of ice, which makes the spell violently crumble as you appear on the other side.
> roll 3d6 backlash to you and Mirajane
<Serith> Kotono roll for Serith < 10 > [d6=6,3,1]
DR doesn't apply.
Owwww. The aftermath leaves Afina just a bit dazed, and Mirajane's there. So's the block of ice, with Mirajane within. She's wide eyed and unmoving, her lights gone and captured in the ice like an insect in amber. The stress of the teleport is visible in it as well, as cracks run all around the ice chunk.
"Gwynharwyf damn it," Hanna cracks her knuckles, "C'mon, let's break her out of that."
Hanna http://www.soulriders.net/forum/index.php/topic,103876.msg1078446.html#msg1078446
HP: 378/378 regeneration 11
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Greater Mage Armor (CL5), Epic Mage Armor (CL24), Heroes Feast (CL20), Divine Insight (CL24), Freedom of Movement(CL24), Good Hope (CL24)
Bonuses: +20 armor bonus to armor class, +1 morale attack rolls and Will saves, immunity to fear and poison, +2 morale attack rolls, saving throws, ability checks, skill checks and weapon damage rolls.
Resources Used: 1 rage
Mirajane http://www.soulriders.net/forum/index.php/topic,103876.msg1078449.html#msg1078449
HP: 328/341
Spells Active: Mind Blank (CL15), Fortunate Fate (CL24), Planar Tolerance (CL7), Greater Mage Armor (CL5), Epic Mage Armor (CL24), Heroes Feast (CL20), Good Hope (CL24)
Resources Used: 1 rage, 1 turn
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
[/quote]
Taking hold of Afina's and Mirajane's shoulders with each hand Jaela heals the two of them, before studying the cracked block of ice.
Lay on hands to top them off, also might as well heal myself to max. Spellcraft 10 for 43 on the ice magic.
Sacrificing a 2nd level slot for spell shield to negate 10 damage
"Can you tell if she's entombed or merged?" Afina asks, since shattering it in the latter case would be unpleasant.
Spell charges: 6/7/8/6/6/6/2/8/7/8/4/0
Init: +24
You can't heal Mirajane by touch until she's out of that block of ice, Jaela.
Hanna leans in and studies...
Nothing relevant for her to roll.
"I don't know," she admits.
Jaela can tell she's entombed. Breaking her out will probably harm her, but it shouldn't kill her. Losing a limb is a decided possibility, though.
Taking 10 for K:A 51
Since spellcraft gave me information, is it an active spell? If so, can it be dispelled?
Is it a roll she failed that I can give her another chance at with Resurgence?
What if we tried teleporting her out of the cube? Is it even possible?
Will Control Water be of any use to get some of the ice right next to her skin and possibly more liquid than the rest of the block further away from Mirajane?
What if I cut very clearly and avoid her limbs?
In order:
1. No, any spell involved is done. It's not a spell, you can tell that by your previous spellcraft check. Most likely something supernatural instead barring elemental weirdness.
2. It could help with her failed Fort save.
3. Not at the level she's been merged with it.
4. No.
5. That would help and likely provide a circumstance bonus to any roll she has to make if you go that route.
Jaela squeezes Afina's shoulder in thanks before focusing on Mirajane. "We're going to have to cut at the ice very carefully to avoid her limbs," she says. "True Strike is my preference. Let's do it on three, when I'll give Mirajane a little magical boost."
She waits to see there is no opposition, before counting down from three!
I want to cut off the extraneous ice while avoiding harming Mirajane together with Afina, while using True Strike to guide my spear. I'll cast Resurgence on Mirajane at the same time.
Actually no, I'm sorry. Resurgence wouldn't apply, it's an ongoing effect and this one's finished. Same reason it doesn't help with instantaneous effects. Entirely my fault there, apologies.
"I could just disintegrate it," Afina offers. "Mirajane's resilient enough to shrug it off while the ice will be reduced to dust."
Jaela pauses at the offer, tilting her head. "If you made it much weaker, just in case?" she proposes.
"Easily done," Afina says, reducing the potency of her magic to the bare minimum as she fires a green beam of unmaking at the block of ice entombing Mirajane.
[18:58] <@Ebiris> roll 1d20+40 ranged touch
[18:58] <Serith> Ebiris roll for Serith < 45 > [d20=5]
[18:58] <@Ebiris> roll 1d20+12 CL 12 disintegrate vs Mirajane's SR
[18:58] <Serith> Ebiris roll for Serith < 14 > [d20=2]
Spell charges: 6/7/8/6/6/6/1/8/7/8/4/0
Init: +24
Attack: unarmed +35 (1d4+7 +5d6 skirmish +2d6 swift +1d6 sudden strike)
