Jaela: getting stuff done (Jaela)
Started by Anastasia, September 29, 2016, 05:04:15 PM
7, between chatting and then flying to the next ship.
Jaela is a blur as she thrusts down, spear impaling the helm. She opens a hole in it as antimagic field manifests within it. Metal tears loudly as you punch through several inches of steel with one blow. Efreet all around scream and prepare counters, magic already flowing. Some of it is stopped by the antimagic field, the one closest to it having his spell simply fail.
Then your world becomes fire and brimstone, the wrath of the efreet exploding around you.
> roll 1d20+24 Jaela SR
<Kobot> Kotono rolled 1d20+24 Jaela SR --> [ 1d20=10 ]{34}
Beat it on the number. Reflex.
"I'm here to wreck your shit!" Jaela announces with a happy grin. "You can still surrender!"
15:22 <Tohsaka> roll 1d20+53 evasion
15:22 <Kobot> Tohsaka rolled 1d20+53 evasion --> [ 1d20=11 ]{64}
HP adjusted from healing.
Hit Dice 20+429/497hp [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Init: +17 (Sign precast)
Detection: Blindsight 60ft, Darkvision 60ft, Listen +10, Spot +14 (+15 with Divine Insight)
Speed: 40ft (land)/120ft (flight, perfect maneuverability) [10ft enhancement from Longstrider]
Armor Class: 59 touch, 71 vs incorporeal, 77 normal, 20% miss chance. [21 from dex and cha/-21 when flat footed, 10 armor from Millennial Chainmail/Magic Vestment (Ethereal armor), light armor, 6 from natural armor, 7 shield from animated shield/Magic Vestment (5/enhancement bonus to touch AC), 2 from Foresight, +3 luck from Recitation, 20 force from epic mage armor, +5 sacred with Shield of Warding, +3 luck from Recitation, +1 from Haste, +4 from Celestial Valor]
BAB/CMB/CMD: +22/+31/73
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +51/+51/+46/+41/+36, 2d8+40+10d6, x3/20, 10ft [+2 damage vs DR/silver, +2d6 vs undead, +1d6 vs incorporeal/gauntlets, +14 Divine Might, +3 luck from Recitation; silver+good+anarchic+epic]
Full Attack (Gae Trocaire, GMW, Haste, HW): +42/+42/+37/+32/+27, 1d8+31+1d6 non-lethal, x3/20, 10ft [+2 damage vs DR/silver, +1d6 vs incorporeal/gauntlets, +2d6 from celestial brilliance, +14 Divine Might, +3 luck from Recitation; piercing/bludgeoning/slashing/silver/bypasses any DR next round after successful hit for 10 rounds]
Ray Attack: +35
[+2 attack/damage Good Hope not counted, +3 Recitation not counted, +4 Celestial Valor not counted, +4 Greater Heroism not counted, +5 Holy Warrior not counted]
Resistances and Immunities: Fire Resistance 10, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 10, Damage Reduction 20/Epic and Evil and Cold Iron, Spell Resistance 34 (43 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Foresight/not surprised or flat-footed.
Saves: Fort +55, Ref +49, Will +55 [Counted: Conviction +5 to each save, Foresight +2 to Ref; Not counted: Good Hope +2 to each save, Celesial Valor +4 to each save, Greater Heroism +4 to each save, Recitation +3 to each save]
Precast/Bead of Karma: Contingency/Righteous Might when Jaela casts Holy Transformation CL30, Energy Immunity/Cold CL30, Permanency/Greater Blindsight CL30 [Blindsight for 60ft], Permanency/Mantle of Good CL31, Permanency/Prestidigitation CL30, Extended Lore of the Gods CL30 (10hr duration), Righteous Halo CL30, Longstrider CL25, Moment of Prescience CL25
Precast: Energy Immunity/Fire CL26, Epic Mage Armor CL24, Fortunate Fate CL24, Conviction CL24, Sign CL24, Divine Insight CL24, Spell Turning CL24, Heroes's Feast CL20, Control Water CL18, Mind Blank CL17, Planar Tolerance CL7, GMW CL26/Gae Bolg, GMW CL26/Gae Trocaire, GMW CL26/Gae Dioltas, MV CL27/Millenial Armor, MV CL27/Shield, Foresight CL23, Good Hope CL26, Greater Heroism CL26, Haste CL21.
Favored Soul slots left, 01-11: 9/1/0/0/6/0/1/5/6/1/3
CL 26 Favored Soul, CL 21 Divine Crusader [+2CL untyped War domain, +1CL competence Force, +1CL untyped Protection domain, +1CL untyped Abjuration]
Spell/SLA DC: 24 + spell level
Antimagic Field channeled into Gae Dioltas
11/17 Turning left
-1 smite
-57 LoH
Jaela is surrounded on all sides. Fire that she can't dodge, blanketed in the inferno. There's no hope to avoid it, so instead she casts a quick spell. A benediction to the Triune, responded to with a cool breeze. This breeze puts out the fires around you, leaving you in a safe bubble as searing flames rage all around you.
The ship's course doesn't seem affected as the smoke clears, though the helm is well and truly smashed. A new hole right in it tends to do that, after all.
You're up, Jaela. You asked about the Master's attack, and all you can see are distant flashes of fire. Things are a bit too busy and smoky at the moment to see anything more than that.
Jaela crouches before taking off into the air with a massive leap! A barrel roll brings her underneath the rear of the ship near the rudder, as gunners see nothing but her trailing cloak. Rather than stopping here, Jaela tries slamming into it from the side with all her momentum to see whether she could divert the ship from here!
Assuming it's something along these lines and I can push it with sufficient strength. Would it be an attack or a bullrush? Since the helm's destroyed the efreet probably can't counter me so it'd be a matter of moving the movable block of wood/metal.
I'll take the AoOs I need to rise into the air and fly, no Gambit this time.
Hit Dice 20+432/497hp [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Ray Attack: +35
11/17 Turning left
-1 smite
-57 LoH
> roll 1d20+24
<Kobot> Kotono rolled 1d20+24 --> [ 1d20=8 ]{32}
> roll 1d20+24
> roll 1d20+24
<Kobot> Kotono rolled 1d20+24 --> [ 1d20=17 ]{41}
<Kobot> Kotono rolled 1d20+24 --> [ 1d20=1 ]{25}
Jaela flies out and avoids all the attacks as she does, slamming into the rudder.
I'll call it a pure Strength check. You're not attacking it ot damage it, so it's not an attack roll. A bull rush doesn't really qualify, it's not a creature or anything like that. So straight feat of Strength it is.
16:07 <Tohsaka> roll 1d20+9+2 str
16:07 <Kobot> Tohsaka rolled 1d20+9+2 str --> [ 1d20=3 ]{14}
Can Moment of Prescience be applied to this check?
No, it's not an opposed check.
You hit the rudder dead on with your shoulder. You move it a bit, making the ship change direction, turning from going south to south-southwest.
Jaela circles around for another pass, hitting the rudder in the same direction!
16:46 <Tohsaka> roll 1d20+9+2 str Kobot
16:46 <Kobot> Tohsaka rolled 1d20+9+2 str Kobot --> [ 1d20=1 ]{12}
It moves just a little more - south-southwest still. You can barely budge the damn thing.
Meanwhile, you hear a loud explosion from the direction of the Master's ship, followed by a wave of pressure that sends you flying away from the rudder, along with a blast of light.
Jaela trusts in her competent companion, using the opened-up distance to go for a third and final pass! If that works, she'll replicate the same approach for the third ship. Otherwise, she'd really need to reconsider it. After all, didn't the Master simply take one over by landing on the deck?
16:51 <Tohsaka> roll 1d20+9+2 str Kobot
16:51 <Kobot> Tohsaka rolled 1d20+9+2 str Kobot --> [ 1d20=18 ]{29}
I presume this takes up 3 rounds, for healing purposes.
[spoiler][/Hit Dice 20+441/497hp [+24hp with Righteous Might, +48hp with Holy Transformation, +24temp hp with Divine Power]
Ray Attack: +35
11/17 Turning left
-1 smite
-57 LoHspoiler]
WHAM!
That last blow firmly turns it to the west, the ship starting to turn away to your movement. Got it!
Full trust remaining in the Master, Jaela zooms up into the air and observes the remaining two ships to pick her next target. If one is fleeing, she will pursue to destroy its rudder outright. Otherwise, Jaela will pick the ship closer to the one the Master went after.
My spot, just in case it's not automatic.
17:28 <Tohsaka> roll 1d20+18 can I see?
17:28 <Kobot> Tohsaka rolled 1d20+18 can I see? --> [ 1d20=9 ]{27}
The ships are still going ahead.
You can also note that the ship the Master was on is exploding, tearing itself apart. The Master's flying away from it rather rapidly, heading in your general direction. A few efreet are following him but falling behind him rapidly. You also notice several efreet coming from the ship you diverted, heading in your direction as well.
No init yet, pending what you're going to do.
"Together!" Jaela calls out, heading for the third ship on a course that intercepts the Master. With the ships slightly ahead, the rudder is left exposed and she seeks to slam into it from the side to send the ship sailing east! They'll push it together, and if it turns enough that it wouldn't continue on a reciprocal course to their seized ship, she'll break it off while the Master defends her long enough from the chasing efreet.
