Where am I now?! (Moore)
Started by Anastasia, December 09, 2016, 03:40:03 PM
The way ahead gets faintly glossy and jelly-like - huh, some sort of ooze is filling the passage entirely.
K:D check if you have ranks.
I have ranks in everything, you know that. Take 10 for 32.
It's a gelatinous ooze. They catch things and dissolve them.
They're fairly iconic so I'm not going into details, as I assume you know them. If not, say so and I'll give you more.
Any general idea of how tough these sorts of things tend to be? Immunities, that sort of thing? I.e. would sonic attacks work, or probably not because they're oozes?
#34
Well, it's bound to get the spider's attention, but it can't be helped. A burst of sonic energy fills the hallway with the ooze!
[23:19]Cacophonic Burst
<Nephrite> roll 15d6 Reflex DC 27 half
[23:19] <Kobot> Nephrite rolled 15d6 Reflex DC 27 half --> [ 15d6=47 ]{47}
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Tyche's Touch (+4) (CL 24)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements
HP: 277+5
AC: 47, 27 touch
24/24 Bardic music uses (1/3 left from Refrain)
Spells:
0th - 4/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 5/6
6th - 5/5
7th - 5/5
8th - 1/1
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 7/8
5th - 8/8
6th - 6/6
Pre-loading Resist Energy to Tapestry: Fire/Cold/Acid/Sonic
Casting the following into the Tapestry (everyone gets these):
Create Magic Tattoo, CL 25, 24 Hour Duration.
+1 Luck Bonus on Attack Rolls.
+2 Competence Bonus on Attack Rolls.
Mighty Wallop, Greater, CL 25, 25 Hour Duration.
+2 Size Category to Bludgeoning/Unarmed Weapons.
Mage Armor, Greater, CL 25, 25 Hour Duration.
+6 armor bonus to Armor Class.
Energy Absorption, CL 28, 28 Hour Duration.
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic.
As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack), and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
> roll 1d20+6 ref gelatinous cube
<Kobot> Sunshine_Ko rolled 1d20+6 ref gelatinous cube --> [ 1d20=17 ]{23}
The burst of sound hits the ooze quite hard, enough to where it shakes all over, hunks of it falling away. Unfortunately, you also have its attention now as it begins to advance towards you.
Init.
[12:13] <Nephrite> roll 1d20+31
[12:13] <Kobot> Nephrite rolled 1d20+31 --> [ 1d20=11 ]{42}
> roll 1d20-5 Ooze init
<Kobot> Sunshine_Ko rolled 1d20-5 Ooze init --> [ 1d20=3 ]{-2}
Init is Moore (42) > Ooze (Queen Miko)
Go Moore.
Well, the sonic attacked seemed to work, so Moore just tries again! He makes a mental note to himself to have an item or two created that give him other options...
[12:32]Cacophonic Burst again, DC 27 Reflex
[12:32] <Kobot> Nephrite rolled 15d6 --> [ 15d6=42 ]{42}
<Kobot> Sunshine_Ko rolled 1d20+6 ref gelatinous cube --> [ 1d20=8 ]{14}
A second blast makes the ooze break apart, nothing but slime before you now.
In the distance you also hear the sound of glass breaking, back by the throne room.
Free act.
Hm. He'd better go investigate that... He turns invisible again just to be on the safe side and heads back towards the spiders.
Okay, short pause pending an Iddy post.
Moving you back to the main thread.
