Where am I now?! (Moore)
Started by Anastasia, December 09, 2016, 03:40:03 PM
You have a sensation of falling and moving. Then you stand in a small throne room of a crumbling castle. The throne is rotted wood and decaying red cloth, while a few crumbling pillars hold up the ceiling. There's a door to the south.
"There certainly is an emphasis on crumbling around here..." He remarks, taking a look around before he heads to the door to the south.
Take 10 on Spot for 42. He does have True Seeing on it if makes a difference.
You look around and note there's a lever behind the throne.
He's already in enough trouble, so he may as well try it.
The lever is pulled. A section of the wall behind the throne swings open, revealing a hidden passage.
Listen check.
You can hear glass breaking down the secret passage.
Huh. Did opening the door cause something to fall? He'll go investigate the passage, either way. He can see perfectly fine, so if the need arises he can run away!
It's a dark, dusty passage. Looking within, you see spiders everywhere. Small spiders made of spun glass, catching the light that's spilling into the tunnel and glittering from it. A few lie on the ground, broken completely. The rest are looking to you as one.
Moore tries turning invisible to see if they still seem to notice him.
They start to look around for you, showing no signs of seeing you.
Worst case scenario, they're glass, so they might just explode...
Moore will venture into the hallway!
You slip by the spiders uneventfully. Past them is a few turns before the passage comes to an intersection. There's a way ahead that leads to metal grating blocking the way. There's a passage to the right that leads on, as well as a passage to the left. The passage to the left has a turn with the glow of light from around the turn.
