Tryll, Surraruthru, Bubbles
Shredstorm
77 courre scouts
50 earth elementals of medium size
50 water elementals of medium size
12 earth elementals of large size
50 phase spiders of large size
46 mineral quasi-elementals
While the vanguard attacks in force at devil strongholds, the infiltrators will attack from below using a mixture of earth movement abilities and aquatic movement through the city sewers so as to cut off hidden lines of reinforcement and supply while undermining structures that the vanguard are having trouble dislodging. Predominantly made of those with special movement modes.
Okay. Surraruthru and Tryll, anything to add to this before we begin? Yours is fairly straightforward, just a chance to speak up to add any notes or clarifications before we begin.
I've nothing to add.
Tryll
HP: 246
AC: 47
Touch AC: 30
Flatfooted AC: 39
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 26), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 25), Create Magic Tattoo (+1 luck bonus to attack rolls, CL 26), Create Magic Tattoo (+2 competence bonus to attack rolls, CL 26), Energy Absorption (CL 26), Elemental Body (CL 26), Surraruthru's Stupendous Dragonskin, (+10 armor bonus & DR 10/magic CL 26), Agility of the Dragon Princess (+4 insight to dexterity, CL 26), Strength of the Dragon Princess (+4 insight to strength, CL 26), Mind of the Dragon Princess (+4 insight to intelligence, CL 26), Stoneskin (DR 10/adamantine, CL 26), Spell Turning (CL 26)
PP: 648
Calleigh
HP: 123
AC: 49
Touch AC: 27
Flatfooted AC: 36
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 26), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Create Magic Tattoo (+1 luck bonus to attack rolls, CL 26), Create Magic Tattoo (+2 competence bonus to attack rolls, CL 26), Energy Absorption (CL 26), Elemental Body (CL 26), Surraruthru's Stupendous Dragonskin, (+10 armor bonus & DR 10/magic CL 26), Agility of the Dragon Princess (+4 insight to dexterity, CL 26), Strength of the Dragon Princess (+4 insight to strength, CL 26), Mind of the Dragon Princess (+4 insight to intelligence, CL 26), Stoneskin (DR 10/adamantine, CL 26), Spell Turning (CL 26)
Psicrystal
HP: 123
AC: 31
Touch AC: 14
Flatfooted AC: 29
Active Effects: Inertial Armor (Extended, Overchanneled, CL 26), Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Magic Circle Against Evil (CL 25)
Cool, waiting for Iddy, shouldn't be too terribly long.
No notes, but haven't had a chance to redo my spells due to work. I get off early-ish tonight, so I'll do it then, but until then, I don't have anything to really add, other than asking what the sq. milage of the city/underground is and the relation of our entry point to the big targets.
Speaking of, did anyone ever figure out a priority target list? Like what areas/buildings we want to gain control of the fastest? Also, we need to figure out some kind of long range comms for talking to the other groups in case they need reinforcements or we need to redeploy in response to an unexpected threat.
We'll wait on spells, since this is a situation where it may well matter.
It's several compact, messy miles of tunnels, roughly.
Priority targets will largely be taken care of by NPCs and directing due to the way PC rolls worked out, so don't worry too much about it, more on that as needed.
Telepathic bond is being used to connect basically everyone as needed, so that handles that.
So basically just pick targets of opportunity and be stealthy. Gotcha.
If possible, we'd like to send a few water elementals hiding in the waters and/or earth elementals hiding in the walls out to scout the tunnels. We want to make sure they don't have civilians down there doing whatever before we wreck the place.
Easily enough done and will be factored in.
Cool, I can connect up to 9 additional individuals to the Tapestry. Tyrll, Calleigh, and bubbles are 3, unless the Tyrll/Calleigh combo counts as 1. 7 others, likely PCs in case we have to come together for a big battle. Which 7 is up to whoever wants them.
For the sake of expedience, let's include Jaela, Afina, Moore, and one other. Preferably someone tanky, like Hanna.
#9
Casting these before we leave Aurora, so everyone connected to the tapestry gains them, the minutes/level duration spells will be cast last in order to make them extend the longest, listed at the end:
+1 Luck Bonus on Attack Rolls
Subject gains Resistance 10 against all five energy types: Acid, Cold, Electricity, Fire, and Sonic.
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
These spells are personal buffs for Surraruthru:
Moment of Precscience, CL 26, Duration 26 hours/discharged
This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check, or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed). Activating the effect doesn't take an action; you can even activate it on another character's turn if needed.
Superior Mighty Wallop, CL 26, Duration 24 hours
As greater mighty wallop, except the bludgeoning melee weapon damage increases by four size categories.
Epic Mage Armor, CL 26, Duration 26 hours
This spell is identical to mage armor, except that it grants a +20 armor bonus to armor class.
Cool. Okay, are your spells all in order?
Unless has any special requests for buffs or spells, yep.
The waters are cold and dark.
You proceed in an underground river, towards the sewer accesses and in. Earth elementals glide in the earth around as you approach the entrance - an old metal grate, rusted and affixed. It's a large, circular opening with gaps for water to flow through. The smell of mold and the sewers comes from it, a rich miasma that does nothing for your sense of smell or mood.
"Well darlings, it's time to earn our pay," Bubbles says as she swims through the waves with unnatural ease, moving through it as easily as an air elemental travels through the air. "We get in here and we can get to business."
Go ahead and set yourselves up.
Bubbles
HP: 279+13/279
Spells Active: Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Create Magic Tattoo (CL26), Create Magic Tattoo (CL26), Energy Absorption (CL26), Elemental Body (CL26), Surraruthru's Stupendous Dragonskin (CL26), Agility of the Dragon Princess (CL26), Strength of the Dragon Princess (CL26), Mind of the Dragon Princess (CL26), Stoneskin (CL26), Spell Turning (CL26)
Bonuses: +1 morale attack rolls, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, resistance 10 to all elements, +10 armor bonus to armor class, damage reduction 10/magic, water mastery, drench, +4 insight Dex, Str, Int, damage reduction 10/adamantine
Surraruthru swims through the water next to Bubbles, sliding through it and dipping under as easily as Bubbles and a bit more naturally; he is a Fairy Dragon, after all. He sniffs the air a bit, the Adaptation effect on his necklace protecting him from the foul air.
"I can only imagine that there will be only the most foul and disgusting devils down here. The retching inducing kind. But yes, let us get to it. Shall we have the elementals erode away the earth around the grate?"
How big are the gaps in the bars here? Can Surraruthru slip through them?
Surraruthru
HP: 347/347, Speed: 100 ft, 140 ft fly, 100 ft swim.
AC: 64 = 38+20(EMA)+4(Deflection)+2(Stat)
Touch AC: 21, Flat Footed: 24, SR: 35, CMB: 29, CMD: 45
Init: +13, Touch Atk: 38, ATK: 38/35/28/23
Active: DR 10/magic, 10/adamantine, +2 Init, +5 ATK, +2 AC, Resistance 10 Acid/Cold/Elec/Sonic, Immunity to poison/sleep/paralysis/stunning/crits/flanking, +1 ATK in water, Drench
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Energy Absorption CL 26, Elemental Body: Water CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Mind Blank CL 26, Stoneskin CL 26 (260 min), Spell Turning CL 26 (260 min), Moment of Prescience CL 26, Superior Mighty Wallop CL 26, Epic Mage Armor CL 26
Magic Items
Gauntlets of Fell the Greatest Foe: +1d6 damage to target for every size category larger than you it is
Boots of Swift Passage: 20-foot teleportation as a move action 5/day.
Headband of Conscious Effort +15: +15 Competence bonus to Concentration checks, 1/day make a Concentration check in place of Fort save.
Wounding Amulet of Natural Attacks and Adaptation +8: +8 to Natural Attacks (Bite, Claw, Claw), all attacks deal 1 Constitution Damage, immune to all harmful vapors and gases (such as cloudkill and stinking cloud effects, as well as inhaled poisons) and allowing him to breathe, even underwater or in a vacuum.
