Tryll will hold another wall in reserve, in case the water does not lower as it comes. I'm assuming that the big lizard dude won't continue to send waves once we start punching him in the throat.
"Incoming!" Bubbles calls, diving into the unpleasant waters and swimming. The wall collapses and waters come.
I'm going to rule the wave gives 20% miss chance from firing through it.
> roll 1d100 vs 20
<Serith> Kotono roll for Serith < 42 > [d100=42]
It didn't come through, good for you.
Water gushes ahead as Surraruthru fires, the result lost as the wave comes on him. He just can't see what happened, but he thinks itw as a good shot. Then another wall comes up, this one checking the waves once more.
'Calleigh, if you would.' Tryll says.
"Yep!" Calleigh darts forward and vanished into the stone wall. She slides upward until she's inside the ceiling of the tunnel and starts looking for pockets of air near the center chamber.
There is one - looks like a higher up tunnel, half full of water but with air in the upper half of it.
That is where Calleigh goes. She peeks out and looks around, being very sneaky.
I'm assuming the parable about people not looking up applies here. Do I need to roll a Hide check, or am I safe?
No one's immediately around in that upper tunnel, so no need.
This is not the chamber where the waves are coming from? Cause that's where she was headed.
Oh, I thought you were going well above it. There's some space in the roof there, yes, it arches up a bit. Not much but a bit.
Alright then.
Calleigh eases her way out of the stonework carefully, and looks around.
Below is a great, scaly creature. It's large as Hanna and gathers water to it, a great mass of it preparing to surge ahead towards the army. This room's about 50ft in diameter and the water looks deep. Ledges line the walls, where collaborators stand, bows at the ready.
Calleigh focuses, and a very large form abruptly does not appear in between two of the collaborators. It immediately sets about cheerfully trying to turn them into paste.
It's a huge astral construct. It's naturally invisible and has blindsight. Keep in mind he's invisible and therefore ignores dex bonuses and such unless they can see him!
[blockquote]Rolled 1d20+28 : 9 + 28, total 37[/blockquote][blockquote]Rolled 1d20+28 : 9 + 28, total 37[/blockquote]
Both hit. Note something of that size will be noticed, simply because of displaced water and space limits. Okay with that?
Well, that and clawing two people apart. Y'know, little things.
It's fine. Next one won't need to be invisible. This is just to sow panic and discord.
[blockquote]Rolled 2d6+16 : 1, 1 + 16, total 18[/blockquote][blockquote]Rolled 2d6+16 : 2, 1 + 16, total 19[/blockquote]
As this happens, another wave gushes up and flies towards the walled off party, which they can see coming. Meanwhile two collaborators are attacked from nowhere, stunned and un even dodging as they're ripped into.
Init here. Party is 40ft down the tunnel with a wall 10ft ahead of them. Enemy is 60ft away in total.
