Boots on the ground (Moore)
0 Members and 13 Guests are viewing this topic.
Alas, that is Divine Oracle 4, so I do not.
> roll 1d20+74 (+2 ???)
<Serith> Kotono roll for Serith < 91 > [d20=17]
> roll 1d20+69 (+2 ???)
<Serith> Kotono roll for Serith < 78 > [d20=9]
> roll 1d20+64 (+2 ???)
<Serith> Kotono roll for Serith < 84 > [d20=20]
> roll 1d20+59 (+2 ???)
<Serith> Kotono roll for Serith < 71 > [d20=12]
Flatfooted AC since no spoiler block is handy?
51. I doubt it matters, but he'd also cast Greater Mirror Image in response to this.
Sorry, it was actually 56 because of Surraruthru's armor, but it still doesn't matter yet!
You're flatfooted so no immediates unless GMI says you can cast it flatfooted. I don't think it does, say so if I'm wrong.
> roll 1d8+30+3d6 and 1 negative level 1
> roll 1d8+30+3d6 and 1 negative level 2
<Serith> Kotono roll for Serith < 51 > [d8=4][d6=6,6,5]
> roll 1d8+30+3d6 and 1 negative level 3
<Serith> Kotono roll for Serith < 43 > [d8=5][d6=3,4,1]
<Serith> Kotono roll for Serith < 43 > [d8=4][d6=4,3,2]
> roll 1d8+30+3d6 and 1 negative level 4
<Serith> Kotono roll for Serith < 49 > [d8=7][d6=5,3,4]
Make two Fortitude saves (poison, stunning, note if immune to either in lieu of a save).
#202
No, you are correct on that.
Moore's immune to poison via Hero's Feast.
[15:19] <Nephrite> roll 1d20+47 mettle
[15:19] <Serith> Nephrite roll for Serith < 67 > [d20=20]
Does DR apply to the attacks?
Apparently elemental body just makes you immune too, so please just remember the 20 for how much this thing got owned by a pixie.
Also Moore's armor protects against the negative levels, so that's an extra fuck you to this guy.
I've got either 10/cold iron, 10/adamantine or 10/magic, I think adamantine is the best of those?
It applies then.
Moore is suddenly slashed all over, blood drawn from half a dozen slices. He bleeds as there's the faintest blur around him and...
Init.
#206
[22:01] <Nephrite> roll 1d20+34+4
[22:01] <Serith> Nephrite roll for Serith < 43 > [d20=5]
Active Spells:  fortunate fate (CL15), planar tolerance (CL7), Superior Resistance (CL 24), Conviction (+4 saving throw), Tyche's Touch (+4 sacred saving throw), Haste (+1 ac, dodge, reflex, 30 move), surge of hope
HP: 165/311
AC: 61, 32 touch
21/25 Bardic music uses, Refrain 0/3
Spells:
0th - 7/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 4/6
4th - 6/6
5th - 3/6
6th - 5/5
7th - 5/5
8th - 2/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 7/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 6/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
> roll 1d20+25 Adrian
<Serith> Kotono roll for Serith < 39 > [d20=14]
> roll 1d20+27 ???
<Serith> Kotono roll for Serith < 42 > [d20=15]
Hell of an init string.
Init is Moore (43) > ??? (42) > Adrian (39)
#208
"Ah, so you must be the one we've heard about." Moore says, trying to muster confidence in the face of his bleeding. Then he just smiles as suddenly, time stops entirely.
If this jerk has something to counter time stop he's going to be really mad...
Time Stop Round 1: Fly about 30 ft away from Adrian, putting Adrian in front of him in the dogai's path. Casting Harmonize. Then he casts Inspire Heroics on himself via Harmonize.
Time Stop Round 2: Cast Inspire Greatness on himself via Harmonize. Cast Heal on himself.
End of Time Stop: Invisibility Purge, (this reaches 70 ft.) Inspire Courage
I did not roll the nonlethal damage from the two inspire songs since he's just healing himself at the end of all of it.
Adrian gets +14 to attack and weapon damage rolls and all that other great stuff.
HP: 305+48/311
AC: 61 (+12 for 73), 32 touch +12 to saves
Spells:
0th - 7/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 4/6
4th - 6/6
5th - 3/6
6th - 5/5
7th - 5/5
8th - 2/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 7/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 6/7
7th - 4/4
That all looks good since Harmonize lets you move actions power bardic music.
Moore empowers himself with bardic music, moving as reality comes to a crawl. Power and inspiration fills him as he throws everything he has, just before reality resumes. Adrian whirls on the assassin as your invisibility purge sweeps out from you. For a moment it's visible, a dark humanoid-ish thing with a longsword. It's hard to look at for long, your eyes crossing and your vision going hazy.
It's already fading from view, but you see it hurl a small glass sphere at Adrian.
> roll 1d20 an easy touch AC roll, only misses if he 1s it
<Serith> Kotono roll for Serith < 15 > [d20=15]
It cracks, a purple-red gas expanding over him.
Fortitude save. Note that this isn't poison so heroes' feast doesn't help.
> roll 1d20+31
<Serith> Kotono roll for Serith < 51 > [d20=20]
I hit enter prematurely, before checking and tallying any bonuses he had going. The 20 makes it moot.
Whatever it is has Adrian cough and hack, waving Gaelach to parry the smoke. He lowers his head and charges right out at it, taking a run right at your fading opponent.
> roll 1d20+61 (+14 bardic music, testing attack so no PA, he knows this isn't an ordinary dogai)
<Serith> Kotono roll for Serith < 67 > [d20=6]
Miss.
Yet the assassin's already faded away, gone from sight despite your spell.
Go.
Adrian
HP: 358/358 (fast healing 1)
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Surge of Hope (CL25)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +4 morale to attack rolls, saving throws, ability checks and skill checks, immunity to fear
