Liber (Jaela, Moore)
Started by Anastasia, February 09, 2017, 02:33:24 PM
"Let's finish this quickly, then!" Moore calls, offering inspiration to everyone!
14 morale bonus on saving throws against charm and fear effects and the same bonus on attack and weapon damage rolls for everyone.
Active Spells:  fortunate fate (CL15), planar tolerance (CL7), Superior Resistance (CL 24), Conviction (+4 saving throw), Tyche's Touch (+3 sacred saving throw), Harmonize (CL25), Greater Improvisation (CL25), Share Talents (CL25)
HP: (7)311/311
AC: 61, 32 touch
18/25 Bardic music uses, Refrain 0/3
Spells:
0th - 7/7 (DC 21)
1st - 4/7
2nd - 7/7
3rd - 3/6
4th - 6/6
5th - 2/6
6th - 3/5
7th - 5/5
8th - 1/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 6/9
3rd - 7/8
4th - 8/8
5th - 8/8
6th - 6/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
[/spoiler]
Mirajane will let you go first in case there's a trap or danger, Jaela. Go. She's not risking it after the last few incidents.
#47
Jaela plunges down as a comet, seeking to destroy the wounded pit fiend and absolutely terrify any mortals in its presence! Shock and awe!
[21:39] <@Annerose> roll 1d20+43+5+1+2+4+2+14 divine might, diving charge, not smiting
[21:39] <Serith> Annerose roll for Serith < 90 > [d20=19]
[21:41] <@Annerose> roll 5d8+145+25+15+70+70+4d6 KD+SotDP+DM+Aura+goldenfire
[21:41] <Serith> Annerose roll for Serith < 348 > [d8=1,8,1,3,2][d6=1,3,2,2]
If I need to roll Intimidate after this, I'll take 10 for 60. Recasting Moment of Prescience as swift.
-4 to attack for 86 and -20 to damage for 328.
Divine Might 14/14 rounds left.
Aura: +14 morale to attack/damage/saves from charm and fear
Aura: +14 circumstantial to dex-based checks and init
HP: 490+20/490
AC: 68 =65base+1AotDP(armor max dex +8)+2Foresight, 20% miss chance (airborne creatures take a -1 penalty on attack rolls and damage rolls against you).
Full Attack (Gae Bolg, GMW, HW, K:D +5, CMT +1luck, CMT +2competence, HF +1morale/GH +4 morale, SofDP +2 attack/+3 damage, DM, vs devils only): +57/+52/+47/+42 or +61 AoO, 2d8+56+8d6+4d6 last is goldenfire
Spells Active: Energy Absorption CL 26, Create Magic Tattoo x2 CL 26, Elemental Body/Air CL 26, Surraruthru's Stupendous Dragonskin CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Stoneskin CL 26, Spell Turning CL 26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Conviction CL29, Longstrider CL23, Divine Insight CL28, Lore of the Gods CL28, Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Righteous Halo CL28, Greater Heroism CL28, Tyche's Touch CL14 (+4 sacred to next save), Share Talents CL14 (+2 untyped to skills), Moment of Prescience CL23.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron (10/Adamantium from Stoneskin), Spell Resistance 35 (45 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Never surprised or flat-footed/Foresight, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body (Air).
Spells Left (1-9): 8/9/9/2/9/5/8/2/7
Spells Left (10-11): 6/2
Saves: Fort +61, Ref +57, Will +61
-True Strike x3
-Turning x3
-Teleport x1
-Greater Teleport x1
-Moment of Prescience x2
-3 smite
-True Seeing component x1
-Stoneskin 120/150
You impale the pit fiend.
A simple sentence to describe a monumental event.
You thrust your spear through its skull down to its groina nd beyond, the creature exploding into goldenfire. It is utterly vanquished, slaughtered as the collaborators throw down their arms and surrender at sight of you. Your own troops surge in now, advancing further towards the ships now tha tthe barrier's gone.
"With General Jaela, we're invincible," a few call, as Mirajane flies down next to you.
"That was inspired, mother."
"Sylvie's opening was the perfect setting," she says with a grin. "Let's go sink those ships. If any of you see another bottleneck like this, let me know and I'll send in the Rapid Response Force."
Moore will take a look around as he flies down to see if there's anything else in the immediate vicinity of his vision.
Take 10 for 48.
Nothing immediately, but you can see devils and collaborators rising on the ships.
Plan here, Jaela? Go ahead and do your thing, you two.
Moore will gesture and point out the rising devils.
I'll take a moment to cast Shield of Warding and Crown of Flames on myself, while Mirajane casts Mass Death Ward on the four of us.
Then I'll cast Good Hope CL28 on all of us. We should arrive to our destination by then!
"Sylvie, Mirajane, pick a ship each," Jaela commands. "Pick out the command vessels. Moore, do your thing. We'll sink this fleet!"
Then, she shoots down at the largest and most imposing of the ships!
Divine Might 10/14 rounds left.
Init +13
HP: 490+20/490
AC: 73 =65base+1AotDP(armor max dex +8)+2Foresight+5SoW, 20% miss chance (airborne creatures take a -1 penalty on attack rolls and damage rolls against you).
Full Attack (Gae Bolg, GMW, HW, K:D +5, CMT +1luck, CMT +2competence, HF +1morale/GH +4 morale, SofDP +2 attack/+3 damage, DM, vs devils only): +59/+54/+49/+44 or +63 AoO, 2d8+56+8d6+4d6 last is goldenfire
Spells Active: Energy Absorption CL 26, Create Magic Tattoo x2 CL 26, Elemental Body/Air CL 26, Surraruthru's Stupendous Dragonskin CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Stoneskin CL 26, Spell Turning CL 26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Conviction CL29, Longstrider CL23, Divine Insight CL28, Lore of the Gods CL28, Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Righteous Halo CL28, Greater Heroism CL28, Tyche's Touch CL14 (+4 sacred to next save), Share Talents CL14 (+2 untyped to skills), Moment of Prescience CL23, Good Hope CL28, Shield of Warding CL28, Crown of Flames CL28, Mass Death Ward CL24.
Spells Left (1-9): 8/9/8/1/8/5/8/2/7
Saves: Fort +61, Ref +62, Will +61
-True Strike x3
-Turning x3
-Teleport x1
-3 smite
-Stoneskin 120/150
Chain Dispel -> Gae Dioltas
Do your thing so we can factor in bonuses properly, Moore.
6 nonlethal damage to Moore.
+14 morale bonus to attack and weapon damage rolls and the same bonus against charm and fear saves to everyone. This lasts for 10 rounds after they stop hearing Moore --  YMMV on how long that actually is since they're all splitting up.
I think by the time everyone's in position they'll be out of range of his aura and his other bonuses. He'll go with Jaela either way, so she'll keep the aura bonuses -- so she gets an extra +3 to attack rolls. +2 is untyped and +1 is circumstance.
Moore hover sin position and sings for now as the other three split up. Jaela races to a ship - a big, flat barge full of soldiers. She's approaching as devils mobilize on it, collaborators getting bows and cultlasses ready.
Go ahead, attack is yours.
"Not today, devils!" she cries out, spearing through the ship's decks one after the other!
[19:53] <@Annerose> roll 1d20+43+1+5+1+2+14+2+3-22 diving charge~
[19:53] <Rei-chan> Annerose rolled : 1d20+43+1+5+1+2+14+2+3-22 diving charge~ --> [ 1d20=6 ]{55}
[19:54] <@Annerose> roll 5d8+145+25+70+70+15+110 KD+DM+Moore+SotDP+PA
[19:54] <Rei-chan> Annerose rolled : 5d8+145+25+70+70+15+110 KD+DM+Moore+SotDP+PA --> [ 5d8=17 ]{452}
Init +13
HP: 490+20/490
-True Strike x3
-Turning x3
-Teleport x1
-3 smite
-Stoneskin 120/150
You plunge down through the deck and a then another, into the chilly-dark waters below. Everything becomes muffled as you are underwater, the world wet and slower.
Go ahead, no enemy's in position to make a meaningful immediate counter to that.
Jaela propels herself towards the water's surface, steam rising all around her as her Crown of Flames burns any devils unfortunate enough to end up in her presence.
"Surrender while you still can!" she announces to the crews of the other ships.
[20:04] <@Annerose> roll 2d6
[20:04] <Rei-chan> Annerose rolled : 2d6 --> [ 2d6=9 ]{9}
[20:04] <@Annerose> roll 1d20+28
[20:04] <Rei-chan> Annerose rolled : 1d20+28 --> [ 1d20=12 ]{40}
