Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
As you look around, you hear a roar from above. The dragon's plunging down at you like a mountain thrown by a furious titan, wreathed in flames like before and coming right down at your wall of force. The two meet in a tremendous book that causes cracks of glowing light to travel all around it. Little flecks of it fall away, disintegrating as they're knocked loose by the sheer force of the blow.
> roll 1d4+1 breath weapon recharge
<Serith> Space_Cat roll for Serith < 4 > [d4=3]
Yet it is not enough.
Your wall of force is crumbling before you, flames erupting around it from the meteoric impact. But it holds and keeps you safe, the dragon roaring so loud as to shake the air itself, sending vibrations throughout your body.
Act.
Surraruthru stares into the massive maw above him and simply begins casting, aiming to send his spell right down the dragon's throat!
Hellball, CL 26
> roll 10d6 fire
> roll 10d6 sonic
> roll 10d6 acid
> roll 10d6 electricity
<Serith> Iddy roll for Serith < 34 > [d6=4,1,1,1,3,2,6,5,5,6]
<Serith> Iddy roll for Serith < 29 > [d6=5,3,4,4,3,1,3,2,1,3]
<Serith> Iddy roll for Serith < 38 > [d6=5,3,3,6,4,2,5,6,1,3]
<Serith> Iddy roll for Serith < 44 > [d6=6,5,4,4,1,5,6,3,5,5]
Surraruthru
HP: 126/347
AC: 70=38+4+20+1+7 (Deflection/EMA/Dodge/MotP(NA))
Init: +13, Touch/Atk: 38/42+5
Active: Epic Mage Armor (CL26), Superior Mighty Wallop (CL26), Greater Heroism (CL26), Elemental Body: Fire (CL26), Might of the Planetar (CL26)
One flaw with that - you don't have line of effect to the dragon. You put holes on the side of your wall set up and it came from above.  However, the sheer bulk of the dragon spills over enough to make winging it with it possible, along with hellball being a radius spread.
> roll 1d20+25 regardless
<Serith> Space_Cat roll for Serith < 45 > [d20=20]
Your hellball grazes the leg of the dragon, freezing and shocking it. It growls even louder, as..
> roll 1d4+1
The dragon's gone? You're pretty sure that was another time stop spell, it was the exact same magic.
Go.
Surraruthru figures the Red Dragon is about to try and counter his cube of safe-space, and readies himself for it...
Casting Duelward, CL 26, Duration 26 rounds
While a duelward spell is in effect, counterspelling is an immediate action for you, allowing you to counterspell even when it is not your turn without having previously readied an action. You also gain a +4 competence bonus on Spellcraft checks made to identify spells being cast.
Surraruthru
HP: 126/347
I do indeed:
Hathren Mask of True Seeing, 75,000gp: Grants a constant True Seeing effect.
The dragon is silently descending from above, invisible and only revealed thanks to your mask. It's 40ft above you and coming to a quiet hover. It begins to gather power, arcane fire invisibly swirling around it as...
Your chance to use Duelward to counter, if you want.
Can I Spellcraft to tell if it's just regular fire or something that can overcome immunity?
> roll 1d20+37 Spellcraft
<Serith> Iddy roll for Serith < 41 > [d20=4]
Also a +4 to that; I forgot until after that Duelward gives a +4 bonus.
No, it's a side effect of his casting. He's about to drop a magic disjunction on you.
Definately counter spelling that.
Casting Superb Dispel, CL 33
Inquisition Domain: +4 on Dispel checks
Master Specialist: Minor Esoterica +5 on Dispel Checks
> roll 1d20+40 Superb Dispel
<Serith> Iddy roll for Serith < 58 > [d20=18]
No roll, he can't beat that.
You erupt with magic, calling on all your power to crush the spell before you. It shatters, the dragon glaring down at you in contempt as arcane fires sputter out around it.
Go.
Since I have Detect Magic, can I tell if he's got any spells on him?
Yes though this takes time and study. Usually it doesn't matter, but this is the middle of combat.
