Now where am I?! (Moore)
"...This is really embarrassing, I'm going to just get that out of the way." Moore says as he analyzes all three daggers before putting two away and holding onto the third in case they get into another pickle.
"I think I've got some ideas on what to do about it, though." He takes a deep breath. "At least we can be sure now -- you have to activate all the stones at once. the triangles are enemies and the pentagons are treasure. I'm not sure what the difference between the line and the square is, though..."
They are: dagger+1, fiendbane, dagger+1, aberration bane and a dagger+1, human bane.
"We'll pin it down the more we work with them," Ilsenine says, "And likely have to make choices if a particular stone set is worth activating."
"Well, we have a new path to explore either way." Moore says as he starts to go up.
Is there any reasonable way to figure out if Summon Monster spells would work here? Moore is guessing since teleportation is blocked that summoning would likewise not work -- is that a fair guess to make, or is there any way he could be sure other than just trying?
Try Spellcraft if there's magic auras here, otherwise not.
Should be okay, you think. More advanced calling not so much, but a simple summon spell should be okay.
"I think summoning magic should work." Moore says as he goes up. "If we run into one with multiple triangles again, we could probably summon something before we touch them."
"That's a good idea," Ilsenine agrees, "Choose a direction and let us continue."
As you fly up, you hear a distinct splashing down beneath you.
Moore blinks and looks down to see what that was.
You look down and see the waters have split apart, a flying metal guillotine blade racing up at the two of you.
> roll 1d20+30 (+20 ???) vs Moore's AC
<Rei-chan> Kotono rolled : 1d20+30 (+20 ???) vs Moore's AC --> [ 1d20=13 ]{43}
AC?
