Now where am I?! (Moore)
"Hmm." Moore rubs his chin. He will turn around, go back the way he came to the other hole that went down that wasn't this room. "Even though we're going back, we didn't come up this way, right?"
So back into the room with two squares and the pentagon?
This leads back to the first floor, as expected.
This is a small room with no passages out of it, save the tunnel back to the second floor. On the floor is a stone pentagon and a stone dot.
"I think the dot may indicate a fight for something." Moore says. "Shall we?"
Ilsenine nods, "What a curious place."
Moore reaches out for the dot!
The dot glows and crumbles away, as the passage back up begins to glow as well.
A moment later, the pentagon crumbles. Another dagger emerges from the waters as it does.
Moore makes a sour face. "So the dots are... hmm, maybe they seal off certain passages...?"
Moore will analyze the dagger like usual and put it away before he travels back up!
It is a dagger+1, fey bane.
You return up without incident. There is a passage back down, a passage to the north that leads back the way you came and unexpored passages to the south and the west.
Moore wrinkles his nose at that dagger.
"Let's try... south." Moore says as he heads that way!
This room is rather wavy - literally. The walls gently ripple and form waves rather than solid lines.
You hear the sound of wind blowing. It sounds quite close now.
There's passages to the south, east and west here, as well as the passage north that took you here.
Embedded into the floor in the center of the room are two stone triangles, a stone pentagon and a stone square.
"Be ready for something." Moore says as he goes over to touch the.. hmm. Does this mean two enemies, a treasure and something will change a direction? Hmm. He will touch the triangle first.
You touch the triangle. Both triangles crumble at once and glow, and behind you two shapes appear. One is a vague human shape, a sword of water in hand. The other is a twisted, alien thing, a tentacle of water with eyes all over it.
As they advance on you, right at your flank, the square grows and falls apart. The passage south closes up, while a passage up opens up.
The pentagon crumbles away, a dagger rising out of the waters for you to claim.
Init.
[21:57] <Nephrite> roll 1d20+32
[21:57] <Serith> Nephrite roll for Serith < 43 > [d20=11]
