Now where am I?! (Moore)
[13:36] <Nephrite> roll 1d20+10 (+3 more if considered defending)
[13:36] <Serith> Nephrite roll for Serith < 21 > [d20=11]
The air around you warms up. It's like a day in early spring now. Not truly warm, but far nicer than winter's icy heart. Bearable, though you're still wet and shivering.
Prestidigitation can fix that sort of thing! Well, the wetness, anyway.
He will just soldier on and continue following the stream -- if this place is as wildly chaotic as it seems then there may be no other surefire thing to do at all.
> roll 1d100
<Serith> Kotono roll for Serith < 34 > [d100=34]
Fort again.
Another half hour passes before you see a craggy hill rise out of the ground. The stream goes into there, a cave with enough space for you to fly in and explore if you want.
[13:54] <Nephrite> roll 1d20+41 fort
[13:54] <Serith> Nephrite roll for Serith < 54 > [d20=13]
Moore will follow the stream into the craggy hill! He really hopes Ilsenine is all right, though...
Oh, he's going to be in so much trouble when people find out about this...
Far in the cave, you can see a tiny little body lying on the ground, in a pool of dark liquid.
Moore flies over in that direction as quickly as he can!
Maybe it's trap -- but he can't risk it not being one!
In that case it would then be 36.
As you fly closer, you can see something creeping out from under Ilsenine's body. Tentacles or something similar to them, spotted when you're 40ft away.
Not on his watch!
Moore will fly in to try and reach what he assumes is Ilsenine, anyway -- then get back and out with her!
Intent is to fly in, grab her (or it, or whatever) and then Dimension Door with her back and away from the tentacles. Say 150 ft.
As you come in to grab her, tentacles fly out to grab you.
> roll 1d20+31
<Serith> Kotono roll for Serith < 50 > [d20=19]
> roll 1d20+31 crit check if hit
<Serith> Kotono roll for Serith < 44 > [d20=13]
AC?
