Now where am I?! (Moore)
"Would you cut it out already?" Moore says. "Honestly, the water maze was impressive and so was the castle, but this is pretty silly."
He simply stays where he is with a sour look on his face. "This isn't even a good simulacrum."
The intact, normal Ilsenine turns to you, "Moore? Ah, this is not the only doppelganger wearing my face here?"
"It seems to be a common theme, Your Majesty." Moore says. "I haven't seen any of me yet, so I'm not really sure what that means. If anything."
"Ilsenine is fine," Ilsenine remarks with a hint of a smile, "I know not. Where are we?"
"We seem to still be in Limbo. I think this is just another part of the same maze, though, AS I MENTIONED, IT'S NOT A VERY GOOD MAZE!" Moore shouts upwards. "Ahem. I think we just have to continue on in a direction -- I tried to use a spell to mark any safe place but everything warped around it, so that sort of magic appears to not work. Ah - I also tried to use a Sending to you and it didn't seem to go through... which is odd, because we're on the same plane. This place must block all sorts of things."
"...Moore, are you arguing with the slaad?" Ilsenine says, "What good could that ever do?"
"Well, they need to have some sort of critic." Moore says with a gesture around him. "You can't be a better artist if you don't listen to people's feedback on your work, you know?"
"Regardless, now what?" Ilsenine asks.
"We continue on." Moore says as he begins to fly in the same direction he was originally. "It's weird, I think everything past a certain point is variable and in flux. So basically, we might come out of the forest into an ocean or something."
"Let's go," Ilsenine agrees.
> roll 1d100
<Rei-chan> Koaway rolled : 1d100 --> [ 1d100=56 ]{56}
> roll 1d100
<Rei-chan> Koaway rolled : 1d100 --> [ 1d100=88 ]{88}
Fortitude saves, both of you.
[14:41] <Nephrite> roll 1d20+41 fort
[14:41] <Rei-chan> Nephrite rolled : 1d20+41 fort --> [ 1d20=13 ]{54}
If it's getting cold again he will try and make the temperature warmer, for what that's worth.
Sure, anarch check it instead.
[14:49] <Nephrite> roll 1d20+10 (+3 if defending)
[14:49] <Rei-chan> Nephrite rolled : 1d20+10 (+3 if defending) --> [ 1d20=12 ]{22}
You're able to warm it right up as you fly along, fending off the cold. Ilsenine drifts close to you, "This is....mmmm," she murmurs, "Nice."
"Well, if we weren't effectively trapped in a slaad's demiplane or... whatever this is, it'd be nicer." Moore says with a bit of a sigh. "I wonder if time is even passing normally in here."
