"I hope it's not all jungle," Jaela mutters, heading on once more.
You go perhaps 5 minutes longer - the noise of the jungle rapidly begins to settle down, silence overtaking the two of you as you walk down the animal trail.
"I wonder who braved this challenge before us. Do you think it was Alicia herself?"
"I wonder-"
THUMP THUMP THUMP!
The ground shakes, quivering all over every second.
Jaela clears up enough space around them to be ready for whatever might be charging their way!
A 10ft radius, ideally.
Easy enough as Mirima stays on guard. You barely have time to do that as you see it - no hard trick to see something that large. It towers over the tree level, a massive tyrannosaurus. It's far bigger than ones you've seen before, charging you headlong.
Init. It's not a subtle opponent.
[20:52] <@Rin> roll 1d20+13
[20:53] <Serith> Rin roll for Serith < 23 > [d20=10]
> roll 1d20+11 Mirima
<Serith> Kokokokokokoko roll for Serith < 27 > [d20=16]
> roll 1d20+8 T-rex
<Serith> Kokokokokokoko roll for Serith < 27 > [d20=19]
Init is Mirima = T-Rex (27) > Jaela (23)
The T-Rex is currently 60ft away.
Mirima splits into many, mirror images springing up all around her.
> roll 1d4+4 mirror images
<Serith> Kokokokokokoko roll for Serith < 6 > [d4=2]
6 images.
The tyrannosaurus charges in, head going down at Mirima. It's maw is much bigger than her, racing down at the elf as...
A frightful presence ability is negated since you're both immune to fear.
> roll 1d20+62
<Serith> Kokokokokokoko roll for Serith < 74 > [d20=12]
> roll 1d7
<Serith> Kokokokokokoko roll for Serith < 5 > [d7=5]
> roll 1d20+62 cleave
<Serith> Kokokokokokoko roll for Serith < 69 > [d20=7]
> roll 1d6
<Serith> Kokokokokokoko roll for Serith < 5 > [d6=5]
4 images left.
Mirima is swallowed whole - or one of her images is, then another, but both wink out as the rest continue to dodge. The ground quakes beneath the two of you, branches and debris raining down as it plows through the jungle.
Go.
Mirima
HP: 307/307
Bonuses: +1 morale attacks/will, immunity to fear and poison
Golden Bracers (Hidden Dawn): Ranks are unlocked by using them in battles of the appropriate CR or higher. Multiple ranks can be unlocked in a particular battle if it meets the CR requirements and is particularly epic.
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane. <-- Current Rank
Jaela strikes at the beast with Gae Trocaire!
[21:20] <@Rin> roll 1d20+45
[21:20] <Serith> Rin roll for Serith < 57 > [d20=12]
[21:20] <Serith> Rin roll for Serith < 60 > [d20=15]
[21:20] <@Rin> roll 1d20+40
[21:20] <Serith> Rin roll for Serith < 46 > [d20=6]
[21:21] <@Rin> roll 1d20+35
[21:21] <Serith> Rin roll for Serith < 52 > [d20=17]
[21:21] <@Rin> roll 1d20+30
[21:21] <Serith> Rin roll for Serith < 32 > [d20=2]
[21:21] <@Rin> roll 5#1d8+36+4d6
[21:21] <Serith> Rin roll for Serith < 58, 56, 55, 54, 57 >
Jaela, it has 30ft reach as a colossal creature. I didn't explicit mention it's size, so you're free to change your action.
There's no other way, and Jaela springs off the ground as she launches herself at the creature's throat with Gae Dioltas!
[21:35] <@Rin> roll 1d20+43 charge
[21:35] <Serith> Rin roll for Serith < 57 > [d20=14]
[21:35] <@Rin> roll 4d8+116+4d6
[21:35] <Serith> Rin roll for Serith < 151 > [d8=8,8,4,2][d6=2,6,4,1]
You charge in, past the creature's reach and - your spear bounces off its flesh. It's incredibly hard and at the same time stretchy, giving but not breaking your spear. You're knocked back from ther ecoil, the beast unharmed by your attack.
"Tsch!" Mirima readies her blade, "The beast is resistant?" She steps back and chants, finishing in elven, "Burst!"
> roll 1d20 ranged touch against this sorta thing is a 1 check
<Serith> Kokokokokokoko roll for Serith < 13 > [d20=13]
> roll 10d6
<Serith> Kokokokokokoko roll for Serith < 42 > [d6=5,4,6,1,6,6,6,1,3,4]
An orb of force flies, smacking the beast right in the nose. It recoils from that, but quickly recovers to try and gulp you down in one big bite.
> roll 1d20+62
<Serith> Kokokokokokoko roll for Serith < 79 > [d20=17]
AC?
Mirima
HP: 307/307
Resources Used: 1 4th level spell
68. 20% miss chance. Also I'll AoO its face.
I didn't see you going into gambit there, is there something else you can AoO it for?
> roll 1d100 vs 20
<Serith> Kokokokokokoko roll for Serith < 63 > [d100=63]
> roll 10d6+30
<Serith> Kokokokokokoko roll for Serith < 69 > [d6=2,5,4,6,5,1,1,4,6,5]
Does not defeat your damage reduction. Gets a free grapple.
> roll 1d20+66 vs Jaela CMD
<Serith> Kokokokokokoko roll for Serith < 67 > [d20=1]
Ah, natural 1. Hi! Rest of this resolves once I know about the AoO.
You're correct, I forgot to list it so it won't be active.
