[20:18] <@Rin> roll 1d20+44
[20:18] <Serith> Rin roll for Serith < 54 > [d20=10]
[20:18] <@Rin> roll 1d20+39
[20:18] <Serith> Rin roll for Serith < 41 > [d20=2]
[20:18] <@Rin> roll 1d20+34
[20:18] <Serith> Rin roll for Serith < 42 > [d20=8]
[20:18] <@Rin> roll 1d20+29
[20:18] <Serith> Rin roll for Serith < 45 > [d20=16]
[20:19] <@Rin> roll 1d8+36
[20:19] <Serith> Rin roll for Serith < 40 > [d8=4]
[20:19] <Serith> Rin roll for Serith < 37 > [d8=1]
[20:19] <Serith> Rin roll for Serith < 38 > [d8=2]
An attack roll, singular. Doesn't matter much in this case, though.
You slice out, vines cut as suddenly over a dozen more rise up. Each is topped with a pale green flower, closed shut.
"Ah, a test already," Mirima says, "Come and burn yourself against me!"
Init. You saved yourself a nasty back attack.
[20:28] <@Rin> roll 1d20+17
[20:28] <Serith> Rin roll for Serith < 28 > [d20=11]
> roll 1d20+11 Mirima
<Serith> Kokokokokokoko roll for Serith < 17 > [d20=6]
> roll 1d20+10 vines
<Serith> Kokokokokokoko roll for Serith < 26 > [d20=16]
Init is Jaela (28) > Vines (26) > Mirima (17)
Open Jaela.
The vines die!
1 haste round via boots.
[20:42] <@Rin> roll 1d20+45
[20:42] <@Rin> roll 1d20+40
[20:42] <Serith> Rin roll for Serith < 61 > [d20=16]
[20:42] <Serith> Rin roll for Serith < 59 > [d20=14]
[20:42] <Serith> Rin roll for Serith < 50 > [d20=10]
[20:42] <@Rin> roll 1d20+35
[20:42] <Serith> Rin roll for Serith < 55 > [d20=20]
[20:42] <@Rin> roll 1d20+30
[20:42] <Serith> Rin roll for Serith < 44 > [d20=14]
[20:43] <@Rin> roll 1d20+35 crit?
[20:43] <Serith> Rin roll for Serith < 53 > [d20=18]
[20:43] <@Rin> roll 1d8+36+4d6 last is goldenfire
[20:43] <Serith> Rin roll for Serith < 58 > [d8=7][d6=5,3,2,5]
[20:43] <Serith> Rin roll for Serith < 53 > [d8=2][d6=3,5,2,5]
[20:43] <Serith> Rin roll for Serith < 53 > [d8=3][d6=1,4,6,3]
[20:43] <Serith> Rin roll for Serith < 50 > [d8=1][d6=2,3,5,3]
[20:44] <@Rin> roll 3d8+108+4d6 last is goldenfire
[20:44] <Serith> Rin roll for Serith < 127 > [d8=2,3,1][d6=1,5,2,5]
Jaela is a dynamo, slicing and stabbing through the vines. The touch of goldenfire consumes them to the last, traveling from vine to vine and not even leaving behind ash. Over half of them are gone from that, as from the fallen ones, a burst of sickly green pollen comes forth from the flowers.
Ref save.
[20:58] <@Rin> roll 1d20+50 evasion
[20:58] <Serith> Rin roll for Serith < 62 > [d20=12]
> roll 1d20+37 Mirima
<Serith> Kokokokokokoko roll for Serith < 55 > [d20=18]
Yet a swipe of Mirima's blade sets the pollen alight with goldenfire, burning it to the last.
The vines snake out, striking both of you dead on.
> roll 1d20+35 Jaela
<Serith> Kokokokokokoko roll for Serith < 53 > [d20=18]
> roll 1d20+35 Mirima
<Serith> Kokokokokokoko roll for Serith < 47 > [d20=12]
AC?
Yet the vines strike in vain, as Mirima smirks and slashes about, severing vines all around her.
> roll 1d20+51 (+1 heroes feast)
<Serith> Kokokokokokoko roll for Serith < 64 > [d20=13]
> roll 1d20+46 (+1 heroes feast)
<Serith> Kokokokokokoko roll for Serith < 62 > [d20=16]
> roll 1d20+4` (+1 heroes feast)
<Serith> Kokokokokokoko roll for Serith < 23 > [d20=19]
> OOC: 41, so basically it's a crit threat, ignoring my typo.
> roll 1d20+36
<Serith> Kokokokokokoko roll for Serith < 53 > [d20=17]
> roll 1d20+41 crit threat
<Serith> Kokokokokokoko roll for Serith < 42 > [d20=1]
> roll 1d10+39
> roll 1d10+39
> roll 1d10+39
> roll 1d10+39
<Serith> Kokokokokokoko roll for Serith < 47 > [d10=8]
<Serith> Kokokokokokoko roll for Serith < 45 > [d10=6]
<Serith> Kokokokokokoko roll for Serith < 43 > [d10=4]
<Serith> Kokokokokokoko roll for Serith < 42 > [d10=3]
> roll 4d6
> roll 4d6
> roll 4d6
> roll 4d6
<Serith> Kokokokokokoko roll for Serith < 13 > [d6=2,4,2,5]
<Serith> Kokokokokokoko roll for Serith < 17 > [d6=5,5,2,5]
<Serith> Kokokokokokoko roll for Serith < 11 > [d6=1,2,3,5]
<Serith> Kokokokokokoko roll for Serith < 16 > [d6=3,4,3,6]
The second wave of vines goes the way of the first - into goldenfire, incinerated. As the last of them fall, more pollen erupts out.
Ref.
Mirima
HP: 307/307
Bonuses: +1 morale attacks/will, immunity to fear and poison
Golden Bracers (Hidden Dawn): Ranks are unlocked by using them in battles of the appropriate CR or higher. Multiple ranks can be unlocked in a particular battle if it meets the CR requirements and is particularly epic.
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane. <-- Current Rank
[21:19] <@Rin> roll 1d20+52 evasion
[21:19] <Serith> Rin roll for Serith < 61 > [d20=9]
> roll 1d20+37 Mirima
<Serith> Kokokokokokoko roll for Serith < 47 > [d20=10]
The pollen soon clears, leaving naught but your victory.
Free act.
"Right. A challenge," Jaela muses, this time picking her route better.
10 for Survival 27, 10 for K:Nature 37, let's avoid dangers and pitfalls as we carve our way towards an animal path and then follow it.
> roll 1d100 random
<Serith> Kokokokokokoko roll for Serith < 95 > [d100=95]
> roll 1d100 random
<Serith> Kokokokokokoko roll for Serith < 18 > [d100=18]
You soon find an animal path and spend several minutes following it. As you do, you pass by shrubbery laden with bright blue and red berries. Mirima lingers by them, kneeling down next to one.
"Don't tell me you're hungry," Jaela says in amusement, observing the berries.
10 for Survival 27, 10 for K:Nature 37 to ID them.
