"Yes," Strength of Light says, "You're free to leave the valley anytime, but doing so is construed as conceding and admitting your failure."
"Understood."
Let's do this thing! Also, since Mirima and I left Aurora on our own, I'm reminding that we're using the Golden Bracers at Rank 10 (unless the Kras challenge was of CR35 or higher).
Golden Bracers (Hidden Dawn): Ranks are unlocked by using them in battles of the appropriate CR or higher. Multiple ranks can be unlocked in a particular battle if it meets the CR requirements and is particularly epic.
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane. <-- Current Rank
Rank 11: CR 35, sunburst at will as an SLA.
Rank 12: CR 40, goldenfire damage rises to +6d6, gain goldenfire spell as a bonus feat.
You're lead outside of Sylica, then up a bit and to a cliff. Here Strength of Light takes out a metal hoop and places it in the air. It expands into a portal, "This will take you there. There's watchers who keep an eye on the perimeter, they'll make contact when you leave and get you back here, if you can't manage it yourself."
Mirima
HP: 307/307
Bonuses: +1 morale attacks/will, immunity to fear and poison
"Got it." Jaela takes Mirima's hand, and flies through the portal!
It's hot and humid. You can feel moist sweat beginning all over your body, joined by the buzz of insects and various animal noises.
You stand in a thick and trackless jungle, greenery all around you.
"What do you think?" Jaela asks, heading for a path she can make in the greenery. "Wing it or use magic to find a ruin?"
Sign and Foresight cast, GMW and Keen Edge on Gae Trocaire (from bracers). Survival 10 for 27 to find an animal path leading in we could follow.
Mirima sniffs the air and frowns, "It's like the worst day of summer here. The heat is one thing, the wetness is another. Bothersome. I say we wing it, the point of this is proving ourselves."
There's a pause as you struggle to find a path. There's no one immediately nearby, but your woodsland lore tells you there should be one fairly soon. Animal paths are a thing. You'll just have to bull through and hack through to find one.
Jaela relies on her augmented gauntlets and the blades in her boots to carve their path through nature!
That's a dagger+2 or so and what's your gauntlet?
> roll 1d100
<Serith> Kokokokokokoko roll for Serith < 90 > [d100=90]
> roll 1d100 subtable times
<Serith> Kokokokokokoko roll for Serith < 47 > [d100=47]
You barely get a few feet in before your blindsight notices ground-based vines are moving, looping around you and going behind you to flank.
"Duck," Jaela tells Mirima, before clearing a circle around them with her close-range weapons! Then, with enough of a space to move, Gae Trocaire goes to work on reducing the vines all around them in a greater range still.
This'll require an attack roll, they're creatures. Make one real quick.
