Afina and Jaela's planning session (Afina, Jaela)
Started by Anastasia, May 16, 2017, 02:49:23 PM
> roll 1d20+24
<Serith> Space_Cat roll for Serith < 30 > [d20=6]
> roll 1d20+24
<Serith> Space_Cat roll for Serith < 25 > [d20=1]
> roll 1d20+24
<Serith> Space_Cat roll for Serith < 32 > [d20=8]
> roll 1d20+24
> roll 1d20+24
<Serith> Space_Cat roll for Serith < 29 > [d20=5]
> roll 1d20+24
> roll 1d20+24
<Serith> Space_Cat roll for Serith < 39 > [d20=15]
Fortune is with the party. The prismatic walls begin to crack much slower this time, giving you vital time that's needed. With superhuman speed, magic and work, you evacuate approximately 60% of them. However, you're running out of time. The walls are getting close to cracking again, while the ground shakes. It quivers anew, another echo going through all the natives of Lifasa.
Lifasa is screaming in agony. It is calling to its children.
"I can replace the walls one more time," Afina calls to Jaela. "We have to be prepared to leave after that." She wishes she could quell those screams, that she could end the devil presence on her world at a stroke, but she can't. Not today. All she can is bring a few more of Lifasa's children to a place of safety and healing in readiness for the day they do take their world back.
Surraruthru inspects the prismatic walls, looking for a way to reinforce them and help Afina... Maybe something with a Time Stop threaded into the wall to slow the break-down of the spell? Or maybe threading reaving dispels through the walls to cannibalize the magical power of the incoming spells to strengthen the walls?
Surraruthru begins running magical formulas through his mind, hoping to figure out a way to make it work...
"Let me try something, first," Jaela says curtly, and then time speeds up around her!
It is unfortunate that her Gate will fade away a few seconds later, but plenty have sprung open and hers had done its job. She shoots up and keeps on going, traveling a truly ridiculous distance up before appearing, winded but not defeated to cast her spell of dimensional interdiction! It was designed to keep enemies from escaping her grasp, but should do just fine here, for this.
Boots-based Time Stop for 2 rounds, the run action at base speed 170ft for those two rounds and then a move action further still bring me 1530ft away. I then cast my Teleport Block spell with a radius of 1540ft that covers the entire rift in the sky and reaches all the way back to my original position (which was flying and ferrying people to my Gate). It should leave the other Gates untouched.
> roll 1d20+37 Spellcraft
<Serith> Iddy roll for Serith < 46 > [d20=9]
I'm sorry, that was meant to be K:A, I had a brainfart. What's the total with your K:A mod instead?
Two problems: Time Stop is inner focused, so you can't simply shift it into another spell.
Putting reaving dispels in the walls wouldn't help much, either, unfortunately. At worst it would speed up the collapse of the walls, but most likely the wall would simply block it.
"I can't think of a way to strengthen your walls at the moment.. Maybe simply channeling raw arcane power into it? Hmm..."
Jaela freezes time and flies forward. When it resumes...
Basically casting it and waiting for the walls to come down again so it affects it?
Basically. If it doesn't work Afina can put fresh walls.
Opposed caster level check time. Make yours first.
[20:01] <@Rin> roll 1d20+29
[20:01] <Serith> Rin roll for Serith < 48 > [d20=19]
> roll 1d20+22
<Serith> Space_Cat roll for Serith < 23 > [d20=1]
There is a tremendous CRACK that echos horizon to horizon. The sky itself cracks as the bleeding portal vanishes, a dully glowing white scar in the air. Droplets of blood bead on it but don't fall, slowly turning the white light blood red.
That worked out superbly for you all. Act again.
