!!!! (Surraruthru, 88 days left)
Started by Anastasia, June 27, 2017, 10:58:26 PM
"Oghma's realm?"
You catch Kascha in the library, just settling in with a book and some parchment. She looks up as you explain the situation to her.
"I could go, certainly. I'm working on a spell but I'm not that time-pressed yet. Will it be an overlong trip?"
"Hopefully not. I'm going for the bigger crystal, so it'll mainly be a sight-seeing trip if you go. Unless something happens for you."
"I'll be ready," Kascha says, getting up quickly, hopping right up.
> roll 1d20+8
<Serith> Kotono roll for Serith < 21 > [d20=13]
"We can find all sorts of useful information there, though we are on a time limit."
Okay, cool. Should get you going tomorrow once Cor posts a bit.
Soon enough Sylvie joins the two of you, "I'm ready. You have the crystals?"
Surraruthru shades his haversack a bit.
"And the gold for the new one. Anything else I should prepare before we leave?"
Two headshakes follow.
Ready on your end?
Yep. I'll post my buffs block when I get home.
Tapestry:
Elemental Body (fire) CL 28, 28 hour duration
You have the benefits of the attune form spell (page 17) with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on waterdominant planes.
You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet.
Your creature type remains unchanged, so you are unaffected by spells that target elementals, but you gain the air, earth, fire, or water subtype depending on the elemental substance you chose.
Surraruthru's Stupendous Dragonskin, CL 28, 28 hour duration
Strength of the Dragon Princess, CL 28, 28 hour duration
Mind of the Dragon Princess, CL 28, 28 hour duration
Agility of the Dragon Princess, CL 28, 28 hour duration
Mind Blank, CL 28, 24 hour duration
Create Magic Tattoo, CL 24, 24 hour duration
+2 competence bonus on attack rolls.
Energy Immunity (x4) CL 26, 24 hour duration
Grants complete protection agianst: acid, cold, electricity, sonic
Quiescent Weaving: Haste, Retributive Enervation, Spell turning
Self:
Epic Mage Armor CL 28, 24 hour duration
An invisible but tangible field of force surrounds the subject of epic mage armor, providing a +20 armor bonus to Armor Class. Unlike mundane armor, epic mage armor entails no armor check penalty, arcane spell failure chance, or speed reduction. Because epic mage armor is made of force, incorporeal creatures can't bypass it the way they do normal armor.
Moment of Prescience CL 28, 28 hour duration
This spell grants you a powerful sixth sense in relation to yourself. Once during the spell's duration, you may choose to use its effect. This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check, or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed). Activating the effect doesn't take an action; you can even activate it on another character's turn if needed. You must choose to use the moment of prescience before you make the roll it is to modify. Once used, the spell ends.[/i]
Quick check, what level of spell can you add to your tapestry now?
Um, 5 from base, +2 Imp. Tapestry feats (21&24), +3 Advanced Tapestry= 10, which is higher than I thought. I thought I could only go up to 9. If only I had one more bonus feat ;_;
Impressive. Alrighty then.
You appear in a gentle, wind-teased grove. Trees are around you, well tended and with fruits hanging. No - not a grove, an orchard. Trees bearing apples are all about you, dozens lying on the ground. A few errant elves with baskets slowly gather them, talking in Elven more than gathering.
Surraruthru eyes a few of the apples and then slowly turns to stare at Sylvie.
"Sylvie. I want some apples. Are there rules for them or something?"
"Surraruthru! If you want some, remember your manners and ask," Kascha says, waggling a finger. Then in Elven, "Excuse me, sirs!" Kascha walks over to the elves, "Are the apples free for all, and if not, may we please buy a few?"
Sylvie smirks a bit and adds quietly, "So does she tuck you into bed at night too, because seriously that reminded me of my mother trying to scold me."
