"Let's," Dana says, "Fuck scouting, let's just GO!" She says, marching right down that way.
"Slow down, you might walk right into a trap!" Kascha calls, stepping forward after her.
Calleigh is faster than Dana, and zips ahead of her to look about!
Ahead lies a larger chamber, an open space. Here old tables full of dusty bottles and books lie about. The floor has odd, mostly fading markings all over it and there's several scales large enough to weigh Hanna on. Bones - far larger than human if of the same basic design - are mounted on the walls, all sorts of bones. There's a door deeper on in the back.
Canderella walks in, "Finally, something interesting. I wonder what it was for?"
Kascha follows, "Hmmm, some of the books should tell us," she says, drifting to table with several.
Reminder that True Seeing and Detect Psionics are up.
Calleigh checks that table out before Kascha can!
"Indeed. Check what you can, take everything."
Surraruthru flies around shoving books and whatever loose materials look interesting into his haversack, checking them over for magic with his Detect Magic and True Seeing, before going to the bones on the wall with the intent of pulling them into his portable hole.
I assume both of you are taking the action to scan for magic/psionics.
No magic, though Surraruthru....
K:A check here for what you grab, Surru.
As Surru busies himself with casual looting, you see a magic circle flare to life. It glows a faint purple-red, radiating faint magic. Simple enough to understand for either of you, if you care to spend the time on Spellcraft.
It usually doesn't matter that DM + Spellcraft takes actions, but it might here.
Going to spellcraft it also.
K:A [blockquote]Rolled 1d20+58 : 11 + 58, total 69[/blockquote]
Spellcraft [blockquote]Rolled 1d20+57 : 7 + 57, total 64[/blockquote]
It is a summoning circle, activated by living creatures with magical talent being within the laboratory. Within 3 rounds it is going to summon creatures.
You also grab the best things you can, knowing which is good and which isn't.
Is there a way I can thread my own magic into the circle to take control of it? If not can I spellcraft the CL of it for a dispel?
Possibly with a really high Spellcraft check.
Yes, it's caster level 12th.
Gonna try it.
Spellcrafting
[blockquote]Rolled 1d20+57 : 19 + 57, total 76[/blockquote]
You concentrate and subtly adjust the Weave around it. The magic is not so overwhelming resilient or study and you manage to assert some control. You could turn it off or cause the summon to happen immediately.
If I trigger it, would the creature be under my control?
