The footsteps slowly get louder as you go on - a fairly long path, and ahead you see a problem as you turn a corner.
Ahead the way has been barricaded, barrels and loose stones used to form a defensive wall. Erinyes man it with bows and arrows ready, a half dozen of them with a hamatula behind them. They're about 100ft away from you.
Init.
[19:58] <@Jessica> roll 1d20+22
[19:58] <Serith> Jessica roll for Serith < 33 > [d20=11]
[18:03] <@Ebiris> roll 1d20+34
[18:03] <Serith> Ebiris roll for Serith < 54 > [d20=20]
> roll 1d20+13 Adrian
<Serith> Kotono roll for Serith < 19 > [d20=6]
> roll 1d20+9 Dana
<Serith> Kotono roll for Serith < 14 > [d20=5]
> roll 1d20+6 devils
<Serith> Kotono roll for Serith < 18 > [d20=12]
Init is Afina (54) > Jaela (33) > Adrian (19) > Devils (18) > Dana (14)
Afina opens.
"Just like Benfal," Adrian says, "Break through and rout 'em!"
Afina flies right past the barricade and into the midst of the devils before detonating in a consuming fireball!
[18:22] <@Ebiris> roll 1d20+33 SR
[18:22] <Serith> Ebiris roll for Serith < 35 > [d20=2]
[18:22] <@Ebiris> roll 26d10 greater fireburst, searing
[18:22] <Serith> Ebiris roll for Serith < 152 > [d10=5,7,4,10,10,8,5,2,3,6,4,7,4,7,8,2,10,7,7,7,6,3,5,1,6,8]
DC 33 ref half
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 6/9/10/10/7/9/3/8/8/8/7/2/3
> roll 1d20+16
<Serith> Kotono roll for Serith < 26 > [d20=10]
Fire erupts around the erinyes, walls scorched and devils burning. The barricade is ablaze as they stand there, burnt but intact, burning away as...
Jaela.
Jaela promptly smashes into that barricade with Gae Dioltas!
[20:37] <@Jessica> roll 1d20+51+7-26
[20:37] <Serith> Jessica roll for Serith < 34 > [d20=2]
[20:38] <@Jessica> roll 12d8+108+156+6+4d6
[20:38] <Serith> Jessica roll for Serith < 338 > [d8=5,5,1,1,2,8,6,3,1,7,5,8][d6=3,2,6,5]
You're attacking the burning barricade itself?
Jaela charges in like a furious dragon, the barrier shattering and flying about, the center of it blown out. The center line of erinyes are hurled back and to the ground, a clear breakthrough in the lines.
Any of your swifts or is that it?
Then Jaela sets everything on even more fire!
[20:50] <@Jessica> roll 1d20+27
[20:50] <Serith> Jessica roll for Serith < 30 > [d20=3]
[20:51] <@Jessica> roll 15d6+4d6 Ref DC29 half
[20:51] <Serith> Jessica roll for Serith < 67 > [d6=6,3,6,5,3,4,5,2,4,1,1,1,1,4,5,5,6,2,3]
[20:51] <@Jessica> roll 1d20+27
[20:51] <Serith> Jessica roll for Serith < 44 > [d20=17]
[20:51] <Serith> Jessica roll for Serith < 48 > [d6=4,1,1,3,2,1,3,2,1,1,6,1,5,2,2,2,2,4,5]
Twinned spells, so 134 and 96.
> roll 1d20+16
> roll 1d20+16
<Serith> Kotono roll for Serith < 17 > [d20=1]
<Serith> Kotono roll for Serith < 27 > [d20=11]
Fried erinyes, coming up, quick to order.
The erinyes are consumed in goldenfire, barrier remnants and erinyes burning with equal ferver. They are consumed in the aftermath of Jaela's charge, leaving behind only ruin. Victory!
"Damn, weaklings," Dana scowls, "Come on and give us some fucking worthwhile opposition, you dickless traitor!"
Free act.
