Jaela cheerfully proceeds along the path her powers guide her towards!
"C'mon, pick it up," Adrian says, "That made noise, let's not give them a chance to catch up."
Afina, make a quick Will save.
"You can't keep up if I go all out," Jaela needles him with a grin. "Then you'll just be stuck fighting the endless hordes of weaklings in the catacombs while I get to the good stuff."
[19:10] <@Ebiris> roll 1d20+69 moment of prescience
[19:10] <Serith> Ebiris roll for Serith < 76 > [d20=7]
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 6/9/10/10/7/9/3/8/8/8/7/2/3
2 moments of prescience left
Afina feels a faint buzz around her wings.
Adrian matches that grin back, "Yeah? Watch me? Faster than a cat and meaner than Ithea, too. C'mon!"
Jaela dutifully picks up the pace! If she goes too fast, her friends will let her know.
Movement speed brought up to 100ft.
[19:18] <@Ebiris> roll 1d20+47 spellcraft what's that
[19:18] <Serith> Ebiris roll for Serith < 57 > [d20=10]
Hm, some sort of spell just grazed your wings. It was trying to gather some of your pixie dust up. An odd little spell, working from afar and targeting your pixie dust. Definitely custom.
Can she determine more about the spell's range? Is it in the short/medium/long paradigm or is it X miles or 'same plane' or anywhere? What about the targeting, does it target her specifically or is it a 'nearest pixie' sort of thing? What sort of spells would foil it?
It's extremely long range, possibly plane encompassing but most probably several miles. You think it was targeted directly at you. It got around mind blank by not being an enchantment you think.
Do me a favor and list your current immunities, including those granted by spells. Matters for this.
immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, information-gathering divinations, critical hits, negative energy, & death effects
spell resistance 42, freedom of movement, 50% miss chance
The 50% miss chance applies to any spell that affects a target rather than an area, so it would apply here.
Oh, that's sneaky. What's it's doing is trying ti sip at your life force to do it. Protection from Constitution damage and drain should work.
Just wanted to make sure I hadn't overlooked you having that somehow.
'Jaela, do you have any spells that stop your stamina from being sapped?' Afina asks. 'Someone's using a long range spell to affect me, and it doesn't require them to be able to see me for it so I can't do anything about it.'
'Just Stone Body, but I'd prefer not to resort to it. Would Spell Turning do the trick, you think?'
'Should do,' Afina confirms. 'Cast it on me? If I detect it happening again I'll use iron body myself. Same again, spell I'd rather not resort to.'
