Gar-Malleos
Okay, is anyone doing anything else while Moore stops and heals?
Canderella
HP: 383+52/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws
Mei
HP: 502+52/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
[/quote]
"Can't you use stronger healing magic, or get someone else to use it on you?" Afina asks as she spots Moore going for a second level one healing spell after the first. "We're under a lot of time pressure."
"Just catch up," Jaela declares, casting her spells on the go.
quickened grace, sign.
"I can just do it while we're moving." Moore says with a shrug. "It's overkill to use it on a few scrapes and burns."
Thus the party  moves along. Barely after Moore gets his second healing spell off, you see the slope ahead widening. No devils yet, but Afina's sharp eyes sees it again - rills of lava moving, twisting up just like it did before.
"Don't fall behind then," Afina says, closing her eyes a moment as she hastes everyone before hurrying onwards.
CL 27 haste as swift
Afina 383+52/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), shield (CL 27), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), haste (CL 27)
defences: AC 107 (touch 67), spell resistance 42, immunity to fire, water, earth, cold, acid, sonic, electricity, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, freedom of movement, 50% miss chance
spell slots: 6/9/10/9/7/9/9/8/8/7/7/5/3
Attack: +61 (1d4+28 + various)
"More lava animating, someone try a dispel?" Afina asks, pointing out where it's originating.
"Part!" Jaela commands the lava.
20:49 <Luisa> roll 1d20+41
20:49 <Rei-chan> Luisa rolled : 1d20+41 --> [ 1d20=3 ]{44}
The lava doesn't respond.
Mei's eyes widen at this, as...
Moore, going to try anything? Canderella may as well if you fail.
Canderella
HP: 383+52/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Haste (CL27)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws, +1 attack rolls haste, +1 attacks, movement speed bonus, +1 reflex saves haste.
Mei
HP: 502+52/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26), Haste (CL27)
Heavenly Grace
Epic; 9th
He can't reach the level of dispelling the others can.
However, the dragon can!
[13:54] <Nephrite> roll 1d20+39 Dispel (+1 if this is an evil spell or something)
[13:54] <Rei-chan> Nephrite rolled : 1d20+39 Dispel (+1 if this is an evil spell or something) --> [ 1d20=8 ]{47}
"Bullshit!" Jaela exclaims, calling upon her power once more.
I have two swift actions, so this is the second.
20:55 <Luisa> roll 1d20+41 if Surru failed
20:55 <Rei-chan> Luisa rolled : 1d20+41 if Surru failed --> [ 1d20=13 ]{54}
Surraruthru's power is not enough. The lava keeps coming -and stills at Jaela's second barrel. It's still, at least for the moment, no incoming attack.
"They must have had someone exceptionally powerful prepare these traps," Afina says worriedly at the fact it took two dispels from Jaela to do it. That just makes her hurry along all the more determinedly!
"Taelfagn himself?" Canderella wonders aloud as you hurry along. Ahead the path tightens again. It's about 10ft by 10ft, a long and narrow tunnel ahead. 30ft ahead the way is blocked off with shimmering fields of black ice, unmelting in the extreme heat. They go about 5ft up, wands and eyes seen beyond, dozens of both. It's barely a gap six inches tall, with another barrier of ice going from there to the ceiling.
Afina's sharp eyes can notice the lava below is starting to stir again as well, as...
Init. Time to see if you can break through an outer ring of defenses.
"Could've been a group effort," Jaela proposes. "We all have ways of getting better at this for a price. And with our lineup, I can afford to focus on defense."
