"Our arrogance is our power."
Gar-Malleos
> roll 15#1d20+40 batch 1
<Rei-chan> Kotono rolled : 15#1d20+40 batch 1 --> [ 1d20=10 ]{50}, [ 1d20=5 ]{45}, [ 1d20=9 ]{49}, [ 1d20=15 ]{55}, [ 1d20=4 ]{44}, [ 1d20=18 ]{58}, [ 1d20=16 ]{56}, [ 1d20=17 ]{57}, [ 1d20=14 ]{54}, [ 1d20=14 ]{54}, [ 1d20=6 ]{46}, [ 1d20=14 ]{54}, [ 1d20=8 ]{48}, [ 1d20=18
<Rei-chan> ]{58}, [ 1d20=9 ]{49}
> roll 9#1d20+40 batch 2
<Rei-chan> Kotono rolled : 9#1d20+40 batch 2 --> [ 1d20=15 ]{55}, [ 1d20=18 ]{58}, [ 1d20=7 ]{47}, [ 1d20=6 ]{46}, [ 1d20=4 ]{44}, [ 1d20=5 ]{45}, [ 1d20=9 ]{49}, [ 1d20=12 ]{52}, [ 1d20=20 ]{60}
All your spells go kablooey, Afina. Rolling for the spiteful ward now.
> roll 1d20+66 mettle dragon will 1 fishing, sure, why not
<Rei-chan> Kotono rolled : 1d20+66 mettle dragon will 1 fishing, sure, why not --> [ 1d20=2 ]{68}
So close and yet so, so, so far.
Magic collapses. It is gone, destroyed. The enchantments protecting Jaela and Afina are torn asunder as suddenly...
Dragon's casting time stop now. If both of you can and still threaten, you can AoO him.
No AoOs, but I'll still tag along for his time stop.
Afina 329/329
active spells: glaciante's spiteful ward (CL 29 attached to nothing), haste (CL 27)
defences: AC 73 (touch 61), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, darkvision 60, spot +41, listen +41
spell slots: 6/9/8/9/4/7/1/6/2/6/7/2/3
Jaela stabs out with Gae Buidhe, deciding to try and counter his spell altogether if that's not enough!
Swapping to goldenfire spear, reactivating haste via boots.
[20:30] <@Lisa> roll 1d20+51+6+3
[20:30] <Rei-chan> Lisa rolled : 1d20+51+6+3 --> [ 1d20=12 ]{72}
[20:31] <@Lisa> roll 1d8+38+3d12+4d6+5
[20:31] <Rei-chan> Lisa rolled : 1d8+38+3d12+4d6+5 --> [ 1d8=1 3d12=14 4d6=16 ]{74}
The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
If that's not enough, counterspell attempt:
[20:33] <@Lisa> roll 1d20+35
[20:33] <Rei-chan> Lisa rolled : 1d20+35 --> [ 1d20=9 ]{44}
Miss. Duelward is up via the tapestry (and wasn't on your sheets I think, but the level is low enough it was an auto dispel), so do Moore and Surru want to try and counter as well?
Moore is still on the other side of the door so can't actually see what's going on.
Fantastical. Okay, I'm assuming Surru wants to dispel here since he put it up. Moore, could you glance and see what dispelling options he has real quick?
He's only got Greater and Reaving left, which both cap at +20 so I don't think they'd be enough regardless.
Okay then.
> roll 1d4+1
<Rei-chan> Kotono rolled : 1d4+1 --> [ 1d4=3 ]{4}
Time stops - and Afina is not frozen, moving with him. The dragon speaks now, "Aurora is as mighty as the stories say," It intones in contempt, "I will carve it on your tombstone, monster."
Chance to reply before we get to the timestopped rounds, Afina.
"This is a good chance for you to depart then," Afina speaks up, still hovering in the air as her wings beat through the stopped time. "All we care about Silvber, you've defended him to his death, no more can be asked."
A pity she has a big glowing brand on her head that says TRAITOR to draconic eyes, but she may as well make the attempt!
Diplo with the penalty, why not?
[18:55] <@Ebiris> roll 1d20+30-40 TRAITOR diplomacy!
[18:55] <Rei-chan> Ebiris rolled : 1d20+30-40 TRAITOR diplomacy! --> [ 1d20=3 ]{-7}
The roar you get back is one of fury.
Round 1 of 4, timestop. Go Afina.
Can I time stop in a time stop?
No recursive time stopping.
#794
She tried, they all saw it!
Well, she and the dragon saw it. Unfortunately that means she's probably going to be the only witness in a moment, and no one would just take her word for it.
Problems for another day! In the meantime she darts in at that roar and stabs the dragon twice before fleeing into the fog and under the mithral door for some cover!
Using Afame as swift for +4 dodge AC
[19:05] <@Ebiris> roll 1d20+82 10th level arcane strike
[19:05] <Rei-chan> Ebiris rolled : 1d20+82 0th level arcane strike --> [ 1d20=16 ]{98}
[19:05] <@Ebiris> roll 1d20+77 10th level arcane strike
[19:05] <Rei-chan> Ebiris rolled : 1d20+77 0th level arcane strike --> [ 1d20=1 ]{78}
[19:05] <@Ebiris> roll 1d4+42+3d6+3d6+6d6+2d6+10d4 and 2 negative levels
[19:05] <Rei-chan> Ebiris rolled : 1d4+42+3d6+3d6+6d6+2d6+10d4 and 2 negative levels --> [ 1d4=4 3d6=12 3d6=10 6d6=25 2d6=5 10d4=24 ]{122}
[19:09] <@Ebiris> roll 2#1d100 miss chance with blind-fight
[19:09] <Rei-chan> Ebiris rolled : 2#1d100 miss chance with blind-fight --> [ 1d100=75 ]{75}, [ 1d100=4 ]{4}
Afina 329/329
defences: AC 77 (touch 65), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsense 30, darkvision 60, spot +41, listen +41
spell slots: 6/9/8/9/4/7/1/6/2/6/6/2/3
