Gar-Malleos
[20:22] <@Ebiris> roll 1d20+29 missing moment of prescience right now
[20:22] <Rei-chan> Ebiris rolled : 1d20+29 missing moment of prescience right now --> [ 1d20=4 ]{33}
160 damage and nauseated for 1 round. Are you innately immune?
[20:30] <@Ebiris> roll 4d10 Moore buff temp hp
[20:30] <Rei-chan> Ebiris rolled : 4d10 Moore buff temp hp --> [ 4d10=19 ]{19}
12th level slot sacced for -60 damage via spell shield
No immunity to nauseated, but if that was a targetted effect I do have 50% miss chance.
Afina 248/329
active spells: glaciante's spiteful ward (CL 29 attached to nothing), haste (CL 27), scalding touch (CL 31)
defences: AC 73 (touch 61), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsense 30, darkvision 60, spot +41, listen +41
spell slots: 6/9/8/9/2/7/1/6/1/5/5/2/2
> roll 1d100 vs 50
<Rei-chan> Kotono rolled : 1d100 vs 50 --> [ 1d100=78 ]{78}
Got right through, no dice. Sorry Afina.
Speed vanishes as things resume. The dragon roars once more as...
Init is Moore (58) > Afina (51) > Mei (47) > Surru (44) > Jaela (39) > Dragon (23) > Canderella (19)
Canderella's up.
Canderella comes on through, eyeing the wyrm carefully, "Do we have a plan here?" she asks, calling out.
"You know what we came here for!" Jaela calls back. "That takes priority, we don't need to bother with some leftover minion!"
Canderella will hold then, no sense wasting power with a dispeller. Moore.
It's strange, why is this dragon even all the way down here? Especially behind this weird door they can just run behind!
"Whatever the case, I'll support you all, so don't give up!" Moore calls out -- it's muffled, but they can still hear him!
Inspire Courage is getting a redo, this time at +18 for everyone and +20 for Afina.
In addition, everyone is also gaining Destined Strike, which is +4 to attack and damage rolls, Improved Critical Feat, +16 to threat confirmation rolls.
They also get +2 to attack and +2 to Caster Level.
So in total this is +24 to attack, +22 to damage, Improved Crit (stacks if you've already got it), +16 to crit confirms and +2 CL.
Afina retches cutely, backing off towards the door again!
Mei and Surru. Go Iddy.
Surraruthru lets his magical power flow through him, attempting to take cover in the edge of the pit dug under the door to try and protect against countering.
Rain of Devastation. CL 30. 40 ft radius, 80ft high.
All creatures within the radius are treated as being affected by a targeted greater dispel magic (maximum dispel check modifier of +30). Creatures exposed to this rain take 5d6 points of acid damage. This damage rises by 2d6 for each spell or spell-like ability dispelled by this spell, to a maximum of 50d6. This damage applies to all creatures within the Rain of Devastation. A Fortitude save is allowed to halve the acid damage.
How many checks am I looking at?
> roll 14#1d20+39 Greater Dispel
<Rei-chan> Iddy rolled : 14#1d20+39 Greater Dispel --> [ 1d20=1 ]{40}, [ 1d20=16 ]{55}, [ 1d20=5 ]{44}, [ 1d20=8 ]{47}, [ 1d20=15 ]{54}, [ 1d20=7 ]{46}, [ 1d20=8 ]{47}, [ 1d20=17 ]{56}, [ 1d20=12 ]{51}, [ 1d20=13 ]{52}, [ 1d20=11 ]{50}, [ 1d20=1 ]{40}, [ 1d20=8 ]{47}, [
<Rei-chan> 1d20=19 ]{58}
> roll 3#1d20+39 Greater Dispel per Cor Request
<Rei-chan> Iddy rolled : 3#1d20+39 Greater Dispel per Cor Request --> [ 1d20=6 ]{45}, [ 1d20=14 ]{53}, [ 1d20=14 ]{53}
Cor requested this for his two Rains and the Fog. Rain of Devastation/Desolation states that it's for "All creatures within the radius are treated as being affected by a targeted greater dispel magic (maximum dispel check modifier of +30)" so I'm not sure if it applies.
I also still want to take my Move Action to activate Quiescent Weaving. Everyone in the tapestry gains the following:
Haste, CL 30, 30 round duration.
When making a full attack action, a hasted creature may make one extra attack with any weapon he is holding. A hasted creature gains a +1 bonus on attack rolls and a +1 dodge bonus to AC and Reflex saves. All of the hasted creature's modes of movement (including land movement, burrow, climb, fly, and swim) increase by 30 feet, to a maximum of twice the subject's normal speed using that form of movement.
Spell Turning, CL 30, 300 minute Duration
Spells and spell-like effects targeted on you are turned back upon the original caster. The abjuration turns only spells that have you as a target. Effect and area spells are not affected. Spell turning also fails to stop touch range spells. From seven to ten (1d4+6) spell levels are affected by the turning. The exact number is rolled secretly.
Surraruthru only:
Retributive Enervation, CL 26, 26 round Duration
This spell bestows a negative level upon any non-undead creature that makes a successful melee attack against you (regardless of whether the attack deals damage). There is no save, but spell resistance applies.
Retributive enervation can bestow a number of negative levels equal to 1/2 your caster level (maximum 10). Once this limit is reached, the spell ends, even if the duration has not yet expired.
Greater Mirror Image, CL 26, 26 minute Duration
This spell functions like mirror image, except that an additional image is created in each round after the first, up to a maximum of eight concurrent images.
Jaela, are your three spells nuked as well?
Magic tears apart around the dragon, ripping asunder under Surraruthru's rains. The dragon is not harmed, yet magic is ripped from it.
Amid all of this Mei stands firm and aims, taking a shot at the wyrm.
> roll 1d20 1 check since the dragon's magic has been winnowed dow
<Kobot> Kotono rolled 1d20 1 check since the dragon's magic has been winnowed dow --> [ 1d20=3 ]{3}
> roll 15d6+7
<Kobot> Kotono rolled 15d6+7 --> [ 15d6=57 ]{64}
The eldritch blast actually hits home, blasting on the wyrm's chest scales, blackening some of them and scorching others away as...
Jaelaing.
