Gar-Malleos
Init is Moore (58) > Afina (51) > Mei (47) > Surru (44) > Jaela (39) > Dragon (23) > Canderella (19)
The dragon rears back, bleeding and hurt, beginning to channel arcane power into himself as...
Casting a souped up custom healing spell, since dragons often cheat on spell access. Anyone going to try and counter?
Let's try
21:11 <Lucille> roll 1d20+35
21:11 <Kobot> Lucille rolled 1d20+35 --> [ 1d20=10 ]{45}
I'd held my action until now, I'll fly in and stab it.
Seeing the dragon beginning to cast, Afina flies in to interrupt that with a pair of quick stabs, before she retreats back under the door and to the other side, following Mei as they begin fleeing!
[19:13] <@Ebiris> roll 1d20+94 10th level arcane strike
[19:13] <Kobot> Ebiris rolled 1d20+94 10th level arcane strike --> [ 1d20=14 ]{108}
[19:13] <@Ebiris> roll 1d20+89 10th level arcane strike
[19:13] <Kobot> Ebiris rolled 1d20+89 10th level arcane strike --> [ 1d20=6 ]{95}
[19:14] <@Ebiris> roll 1d4+46+3d6+3d6+6d6+2d6+10d4 and 2 negative levels
[19:14] <Kobot> Ebiris rolled 1d4+46+3d6+3d6+6d6+2d6+10d4 and 2 negative levels --> [ 1d4=1 3d6=11 3d6=13 6d6=17 2d6=4 10d4=23 ]{115}
[19:14] <Kobot> Ebiris rolled 1d4+46+3d6+3d6+6d6+2d6+10d4 and 2 negative levels --> [ 1d4=2 3d6=14 3d6=9 6d6=19 2d6=4 10d4=26 ]{120}
Afina 242+20/329
active spells: haste (CL 27), scalding touch (CL 31), many moments of prescience (CL 31), epic mage armour (CL 29), greater heroism (CL 29), planar bubble (CL 30), shield (CL 30), spell-turning (CL 30), stupendous dragonskin (CL 30), magic tattoo (CL 26), magic tattoo (CL 26)
defences: AC 99 (touch 73), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsight 200, all around vision, see invisible/ethereal, darkvision 60, spot +70, listen +70
spell slots: 6/9/8/9/1/7/0/4/1/4/3/0/1
Jaela and the dragon's magic clashes - and in that moment Afina flies forward. She stabs the dragon deep - and it groans. The spell shatters as it begins to pulse and throb, "N-n-noooooooo!"
The dragon shakes as bright blue spellfire starts to erupt out of it, before exploding violently and consuming you all.
No saves here, but list your type and any subtypes, y'all.
Small Outsider (Fire, Water, Earth, Air)
Small Dragon and Outsider (Half-Celestial)
RIP magic-absorbing door.
Pretty sure Moore is just fey and that's it.
Chaotic Good Aasimar [Outsider]
Amid this, it is a flood of draconic energy. It flows into Surraruthru naturally, bolstering him.
+5 maximum hit points and a +2 bonus to natural armor, Surru.
In the aftermath float ten rings, right where the dragon's center mass would be. They await there, unblemished and each a lovely, shining gold.
Free act.
"Uh... did you get it?" Moore asks as he goes to peek under the door, then flies out on the other side.
"Oh, yeah, I guess you did. Wow."
Jaela stops time! And immediately picks up the rings and stows them away, while recasting her most important spells at no loss of time!
21:28 <Lucille> roll 1d4+1
21:28 <Kobot> Lucille rolled 1d4+1 --> [ 1d4=1 ]{2}
I'll recast 6 of my spells, then use a seventh for a quickened as time resumes and double move outside.
Afina, what will you do with the two rounds?
"Come on Jaela, lets go!" Afina says, seeing she has the looting well in hand she busies herself by throwing down a field of fiery tentacles behind where the dragon was so as to slow any pursuit from that direction before she flies off after Mei and the others.
Fiery tentacles, they'll grapple anything and do 26 fire damage (half to immune) while grappling at +39 cmb
Afina 242+20/329
spell slots: 6/9/8/9/1/6/0/4/1/4/3/0/1
Okay, so y'alla re heading back once the time stop is done?
