Gar-Malleos
The stone is cracking under heat and pressure. Something's forcing fire or lava against them in a particular way and they'll soon half break and half melt open.
Moore frowns. "Lava -- fire, or something from... below and above! I think they're just trying to break this entire place down to catch us in it! It's going to break soon!" He calls out as they continue on.
"Pick up the pace then!" Afina hurries along, magically changing the temperature above and below her in a wide radius in hopes of cooling and slowing the lava!
Control temperature with spell enhancer. CL 30 so can reduce the temperature by 6 bands (enough to go from Unearthly Heat to Moderate, though around the party it's more likely to push us from Warm to Unearthly Cold. That does 1d6 cold damage per minute for those not immune or resistant.
Covers a 600 foot radius around Afina.
Afina 242+20/329
active spells: haste (CL 28), scalding touch (CL 31), many moments of prescience (CL 31), epic mage armour (CL 29), greater heroism (CL 29), planar bubble (CL 30), shield (CL 30), spell-turning (CL 30), stupendous dragonskin (CL 30), magic tattoo (CL 26), magic tattoo (CL 26), control winds (CL 28), recitation (CL 30)
defences: AC 98 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsight 200, all around vision, see invisible/ethereal, darkvision 60, spot +70, listen +70
spell slots: 6/9/8/7/0/6/0/1/1/4/3/0/1
As a note, we're all flying at our top speed rather than running on the ground.
Cool. Movement speeds then?
120 for Afina, though surely we'll move at the pace of the slowest person?
140ft is my base speed, and I'll carry Surru. Afina's correct, we'll slow down for the minimum necessary.
Assuming single move it's 90 fly.
With haste, Surru is 150 fly.
Canderella is 110ft right now and Mei is 60ft right now. So 60ft unless someone's going to pull something out? Your chance to do so, y'all.
Jaela wordlessly picks up Mei so that, gesturing for Canderella to follow suit with Moore!
This way we can dash at base speed of 110ft
Okay.
Someone roll 1d20+32.
[13:47] <Nephrite> roll 1d20+32
[13:47] <Kobot> Nephrite rolled 1d20+32 --> [ 1d20=14 ]{46}
Run!
Run!
RUN!
All of you dash ahead, through the battlefield as it begins to explode behind you. Afina's weather magic slows it, creating great groaning bursts of steam and gushes of rain, enough time to escape as flames immerse the fortress you left behind and the battlefield. You're rushing back, nearly across it - when the way ahead explodes into a gout of flame, blocking the way to those who aren't willing to get burned.
Afina's weather magic helps a ton and helps reduce any damage and DCs (if relevant) here, as well as helping you not get caught in the initial burst. It is facing a powerful epic level threat, though, so it's not enough to stop it by itself.
Jaela shapes a tunnel out of a pair of walls of stone without pausing and continues to dash!
