Gar Malleos II (Tryll, Surraruthru)
Started by Anastasia, January 08, 2018, 10:22:29 PM
Tryll[blockquote]Rolled 1d20+41 : 18 + 41, total 59[/blockquote]
Calleigh[blockquote]Rolled 1d20+29 : 2 + 29, total 31[/blockquote]
The party can all notice that there's lots of holes in the walls. - maybe a foot in diameter or so, dotting things regularly.
"Ice spike traps maybe? What do you think?"
Balyss swims, speaking clearly enough despite the water, "You could look in to find out," she says, "But that would be unwise. Be on guard."
"Calleigh could phase through the wall and take a peek."
Jaela proceeds, hoping to avoid this part of the trap swiftly.
Tryll erects Walls of Ectoplasm between the group and the holy walls!
HP: 691+54=745
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL30), Inertial Armor (CL30)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal touch)
Negative Conditions: 25% spell failure 1 hr
Resources Used: 93/789
HP: 345+54=399+18
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal), 18 temp HP
Holy walls?
Also, how strong are Walls of Ectoplasm?
Walls with holes. Holy walls.
"You fashion a roiling wall of ectoplasm, imbuing it with solidity. The wall cannot move once it is formed. It is 1 inch thick per four manifester levels and occupies up to one 10-foot square per level. Each 10-foot square of the wall has 10 hit points per inch of thickness and hardness 5. A section of the wall whose hit points drop to 0 is breached. If a creature tries to break through the wall, the DC for the Strength check is 15 + 2 per inch of thickness.
The wall of ectoplasm is susceptible to dispel psionics, but it gains a +4 bonus on any check to determine whether the wall is negated. Spells, powers, and breath weapons cannot pass through the wall in either direction (though they could damage it). It blocks ethereal creatures as well as material creatures (though ethereal creatures can usually get around the wall by floating under or over it through material floors and ceilings). The wall is opaque, so neither vision nor gaze attacks operate through it. The wall does not block psychoportive travel, such as that provided by the psionic teleport power."
In this case, the wall is 8 inches thick. So it has 80hp and Hardness 5.
> roll 1d20 1 check here
<Serith> Kotono roll for Serith < 19 > [d20=19]
> roll 3d8+25
<Serith> Kotono roll for Serith < 42 > [d8=5,5,7]
Tryll's magic is timely, for moments later, one of the sections of wall is struck by something from a hole, shuddering. It holds, at least for now.
"Onward," Balyss says, "We fight here at a dreadful disadvantage."
Surraruthru continues moving to get through this annoying trap as fast as they can.
Speed matters here, so Swim checks, all. In lieu of that if you have a swim speed say so and post what it is.
Incorporeal, flight 120 for Tryll & Calleigh
Could someone figure out if Jaela has one between innate powers, gear and spells on her?
