The Assault on Avernus
Started by Anastasia, May 08, 2018, 02:48:19 PM
For reference his avatar would be making rank checks at +0, right?
Stepping back after her sole hit of that exchange, Alicia whips her sword out of her hand and sends it whirling through Lixer's avatar and his entourage of liches in a final attempt to clear them out of her way!
Quickend whirling blade to cut through all the assholes. 60 ft line, should be 30 ft wide and enough to cover all enemies in front of me.
[19:37] <@Ebiris> roll 1d20+129 whirling blade, smite evil, 13th level arcane strike, channelled flux grasp, moment of prescience (last one)
[19:37] <Rei-chan> Ebiris rolled : 1d20+129 whirling blade, smite evil, 13th level arcane strike, channelled flux grasp, moment of prescience (last one) --> [ 1d20=1 ]{130}
[19:37] <@Ebiris> Again, being a deity is great.
[19:38] <@Ebiris> roll 6d6+60+3d6+2d6+13d4+2*30d12
[19:38] <Rei-chan> Ebiris rolled : 6d6+60+3d6+2d6+13d4+2*30d12 --> [ 6d6=23 3d6=12 2d6=5 13d4=31 30d12=187 ]{505}
DC 37 fort save that the liches have to make assuming they don't all die from that.
Alicia: 500/884
Active spells: Extended nondetection (CL 31), extended greater anticipate teleportation (CL 31), foresight (CL 31), true seeing (CL 31), mass death ward (CL 31), greater heroism (CL 31), miracle (diseaseimmunity, CL 31), vision of the omniscient eye (CL 31), energy resistance x5 (CL 31), spell turning (CL 31), fortunate fate (CL 31), interplanar telepathic bond (CL 31), good hope (CL 31), righteous wrath of the faithful (CL 30), dance of the unicorn (CL 30), recitation (CL 30), greater visage of the deity (CL 30), extended repelling shield (CL 31), master's touch (CL 30), sensual blessing (CL 30), ghost touch weapon (CL 30), ghost touch armour (CL 30), consecrated ward (CL 31)
Defences: AC 77 (touch 28, incorp touch 46), CMD 107, spell resistance 45, energy immunity (fire, cold), energy resistance 30 (all), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affection, fear, dazzled, blinded), freedom of movement, nondetection (DC 46)
Stat buffs/penalties: +2 insight AC/reflex, +4 morale attack/skills/saves, +10 insight perception, +3 morale damage, +2 morale ability checks, +2 luck attack/saves, +36 Str, -2 Dex, +20 Con, +2 Int, +4 Wis, +4 Cha, +15 natural armour, -8 size AC/attack, +7 shield AC, +4 insight skills, +25 competence perception
Perceptions: Darkvision, scent, low-light vision, blindsight, tremorsense 1 mile, true seeing, perception +83
Sorcerer spell slots: 6/9/8/4/4/4/4/8/6/7/4/4/4/2
Duskblade spell slots: 6/12/11/10/9/4
Correct, thank you. Academic due to the rolls, but good to be reminded of.
This time Alicia steps back, body burning with unholy energies. She braces and hurls her blade, holy energies coruscating through it. Bonds flies through the avatar of Lixer's middle, cutting it in half. Both halves fall to the ground, bursting into green hellfire. They burn away in instants as the liches are overwhelmed, a single black robe left behind by the avatar. You did it!
A moment later the ground begins to quake, the temperature dropping a hundred degrees in an instant. Dark, thick clouds are starting to form in the air above as...
Latha's up, but chance for you to react first.
"A truly impressive avatar, Lixer! All the moreso for how you shouldn't have even had time to make one!" Alicia calls out as her titanic blade returns to her hand. "How does it feel to lose it, though?"
'Clear the fodder around us Latha, worse is yet to come.'
'We good?' Seira sends to Alicia and Sulia.
'We're holding,' Sulia sends, 'But we're busy! Good, Alicia, keep pressing him!'
'Lixer's avatar is slain, he'll have felt that,' Alicia's telepathic voice sends, rich with satisfaction. 'After clearing the current area we'll push on to the fortress itself.'
'I'll be waiting for you inside it,' Seira relays cheerfully.
'Do you need healing yet?' Latha asks.
'There is a complication,' Sulia sends, 'Donald and I are facing an avatar of Glasya, who has chosen to take the field. With her is Duke Malphas of Avernus, who is deploying some fashion of hellfire weapon.'
Well if Latha insists, she is fairly bruised up. 'Please!'
"Sun, heal us!" Latha prays, as healing energy washes over the two of you.
Mass Heal, +250 HP.
As warmth washes away your wounds and cures what ails you? 'You will pay in blood for that,' Lixer vows in your mind, voice cold.
Chance to react before the baddies go and strike again.
Donald
HP: 313/543
Spells Active:
Bonuses:
Latha
HP: 505/505
Spells Active:
Bonuses:
Resources Used: Legion's Gate, Vivacious Fire Storm, Energized Sunlance, Mass Heal.
Sulia
HP: 714+20/714
Spells Active:
Bonuses:
See through everything within 120ft (True Seeing)
Immunity to disease (Miracle)
Gain 20 temp hp (Greater Heroism)
Energy Res 30 (all)
Interplanar Telepathic Bond (Miracle)
+15 insight to any single skill check (Divine Insight)
+25 to stealth (competence, circumstance, racial)
+20 to disguise (untyped)
+4 competence bonus to Escape Artist (Shadow Form)
+4 untyped to init (Sign)
+2 insight to AC and Reflex (Foresight)
+5 sacred to AC and Reflex if you have and are using a shield (Shield of Warding)
+4 morale on attack and immunity to fear and 20 temp hp (Greater Heroism)
+2 morale to damage/ability checks (Good Hope)
Righteous Wrath of the Faithful (extra attack like haste, +3 morale to attack/damage), CL 31
Recitation (+2 luck to attacks/saves (+3 for Alicia worshippers), CL 31
Speaking of, alter reality for ghost-touch weapon on everyone.
Ghost touch armour of course.
"Try!" Alicia shouts back. "Prove Avernus was earned and not gifted!" she challenges, provoking him.
"Then PERISH!" Lixer's voice booms loud and powerfully, shaking the freezing hellscape before you. Beneath you the ground begins to crack wide open, Latha taking to the air as great rents appear. Below is a great sea of churning ice and green hellfire, countless within. The living dead, the damned who wail and gnash their teeth, the devils who torment them and all of Creation.  Hideous dragons as alive as they are dead, giants of dead flesh and living hatred. Nightmares and those condemned away from the light, burning and freezing at once. Those who cannot rest, will not rest and who will not repent. Hear me.
Ahead, Noir Jardin is growing darker, devils within rising up, as you glance the gate within breached, a glimpse of Seira standing amid a broken field of devils, the shattered toys of war gravestones for all that opposes her. But only a glance. Stand.
Empress Sulia and Donald fight, back to back still. They are surrounded by the broken bodies of the wicked, twin points of ever-glowing light amid the darkness. A woman, a dreadful thing that is both more and less than you can imagine, battles them with a blade of death while hellfire comes. But you only get a glimpse of them. This is your first test. Become my hope. Stand against Hell. Asmodeus will not interfere, not in this, for it is our Competition. Victory is not the key, but defiance. In defiance against the wicked hearts, we find hope.
In a tidal wave of ice and hellfire, the dead and the damned, a torrent comes forth, threatening to engulf both yourself and Latha.
Ref saves, you two.
[17:29] <@Ebiris> roll 1d20+52 ref
[17:29] <Kobot> Ebiris rolled 1d20+52 ref --> [ 1d20=2 ]{54}
[17:29] <@Ebiris> +2 more for 56
Alicia: 884/884
> roll 1d20+55 Latha evasion
<Kobot> Kotono rolled 1d20+55 Latha evasion --> [ 1d20=20 ]{75}
Latha knows when not to fuck around.
> roll 30d6 piercing cold damage, half to immune and ignores resistance
<Kobot> Kotono rolled 30d6 piercing cold damage, half to immune and ignores resistance --> [ 30d6=110 ]{110}
> roll 30d6 hellfire, ignores fire resistance/immunity
<Kobot> Kotono rolled 30d6 hellfire, ignores fire resistance/immunity --> [ 30d6=105 ]{105}
> roll 30d6 negative energy damage
<Kobot> Kotono rolled 30d6 negative energy damage --> [ 30d6=89 ]{89}
Latha takes none, Alicia full. Update HPs and let me know how much total you take from it?
