Finding Calley
As if there was heavy gravity there, correct?
If it's that, Take 10 for Spellcraft for 74 to see if there's an actual source of magic causing it.
No, just indented down.
Caster level on whatever you're using to detect.
[15:28] <Nephrite> roll 1d20+33
[15:28] <Kobot> Nephrite rolled 1d20+33 --> [ 1d20=15 ]{48}
It's a trap. Massive voltage is going to flow through the room and anyone in it if it's touched or the rod is moved in the slightest. What's worst ist hat this lightning will cleave through resistance and immunity like it's not there.
Moving the rod is a good way to die, unless you're really, really, really fast and really, really, really good. That or take dismemberment with a grunt, like Cresiel.
Would logic dictate a Disjunction would likely be powerful enough to stave off the trap for long enough to grab it?
If you can manage to make the dispel check, sure, you don't see why not.
Okay.
Moore hustles everyone out of the room after giving an explanation and plays a small song on his harp -- then asks Jetina to try, since her magic is a bit stronger than his for this sort of thing!
Since I think Disjunction caps at +20, we'll have Jetina use Superb Dispelling.
[12:08] <Nephrite> roll 1d20+33 dispel
[12:08] <Kobot> Nephrite rolled 1d20+33 dispel --> [ 1d20=3 ]{36}
I'm guessing that's not enough but will wait for some sort of reaction before just trying again.
Where are you two relative to it?
Definitely not in the same room with the rod. If we can get an entire room away from it that would be ideal.
Okay, just remember you need line of sight to it, so Jetina has to be able to see it.
Right. We'll just have to hope being as far away (but still in line of sight) is enough for us to not die here! Since the trap itself said the room, my understanding is it'd be localized to the room the rod is in, so it is further my understanding where we are is beyond that.
That is fine, regardless.
The dispel fires - and nothing happens a moment, before lightning fills the room. Jetina grimaces and steps back, but it only arches in the doorway, no more.
"To risk being obvious, it really didn't work," Jetina says. "Not in the slightest."
Moore smiles. "That's okay, just try again. You can do it!"
With that encouragement, another try!
[12:35] <Nephrite> roll 1d20+33 dispel
[12:35] <Kobot> Nephrite rolled 1d20+33 dispel --> [ 1d20=2 ]{35}
"Don't give up!" Moore shouts. "Show them your strength and your resolve!"
And another!
[12:36] <Nephrite> roll 1d20+33 dispel
[12:36] <Kobot> Nephrite rolled 1d20+33 dispel --> [ 1d20=6 ]{39}
I am guessing we probably need something 40+ here, but I am also keeping track of how many more shots she has, which is 3.
"It's okay. Focus your mind and believe in yourself." Moore says, giving her a gentle pat on the back.
[12:38] <Nephrite> roll 1d20+33 dispel one more for good measure in case that one didn't work
[12:38] <Kobot> Nephrite rolled 1d20+33 dispel one more for good measure in case that one didn't work --> [ 1d20=13 ]{46}
Only first goes through, you'll see why.
The second time is cast - and this time the lightning intensifies even more, a few stray bolts zipping out of the room to zap the two of you.
Reflex save, both of you.
> roll 1d20+30 vs SR
<Kobot> Kotono rolled 1d20+30 vs SR --> [ 1d20=12 ]{42}
Note if SR holds instead.
No problem.
[12:44] <Nephrite> roll 1d20+39+18 Jetina evasion
[12:44] <Kobot> Nephrite rolled 1d20+39+18 Jetina evasion --> [ 1d20=7 ]{64}
Moore's SR holds, it's 46.
