Finding Calley
So noted.
Moore smiles at Jetina and gives her a reassuring nod. "Yes, we can all improve. This was a good example of that."
He nods again to the others as he continues on!
Next floor, same routine as the last?
Yep. Take 10 for 74 again on PErception
This floor looks to be the actual armory - it's behind heavy, sealed iron doors that only open to Cresiel's hammer. Glancing in, there's a variety of weapons, arms and similar things stored here.
Take 10 on Spellcraft for 74 to make sure this junk isn't cursed too!
Most of it isn't magical, but there are a few cursed pieces - all in their own section. How much are you taking. There's lots of non magical gear to take, or otherwise you could just take magical pieces or anything in between. It'll just take time.
Are the cursed pieces such that just taking them is bad or is it more of a "only if you try and use them" sort of thing?
If it's the latter, then they'll take everything. Moore will use Limited Wish to mimic Shrink Item, but in a form that's Mass, to just shrink all the non magical things so he can grab it all in one go easily.
Like, as long as just taking them is fine, then they'll take them and remove the curses later.
That'll help speed it up, but it's a matter of it being a few rooms and effort, so it will still take some time. And yeah, latter so only if you try and use them.
Then they will take the time. This is why they were here!
[13:24] <Nephrite> roll 1d100
[13:24] <Kobot> Nephrite rolled 1d100 --> [ 1d100=61 ]{61}
Thus you finish, still no interruptions. "I hope they've given up," Xandra says, "Let us claim this victory completely."
"We can hope," Kaja says, "C'mon, upwards. There's more, probably the living spaces and the like."
Moore nods and will go up!
This floor indeed looks like living quarters - ranging from pleasant to opulent on a glance.
How heavily are you going to search them?
Hmm. Yeah, let's search the higher-end ones and grab n' go.
