Contact
Started by Anastasia, January 31, 2019, 12:54:36 PM
A nod after that, as he settles in to go to sleep!
Plans for the next day, assuming no interrupts?
It's probably time to look at all the information that's been gathered on the research from our node gathering.
Okay, paste what you have?
231/777, unless you mean "what I have to review," in which case:
Update 1
Raldare's group has found some lore that may help with Calley's notes. Feel free to read them whenever you like.
Update 2
Raldare's group has found even more lore that may help with Calley's notes. Feel free to read them whenever you like.
Okay, gimme an K:A check and Spellcraft check for each of them.
Take 10 on K:A for 106, Spellcraft for 86 for both.
They're both worth 3 points for them for a total of 237/777.
So updated.
If there's nothing else that grabs his attention, Moore will take Xandra and go to Xiranthador.
If he goes there, the idea will be for him to use the research he has to see if he can find any potential connections or further research that might give him some insight.
Sure.
As you prepare to go, Kaja ducks in, "Moore," he calls as you and Xandra are about to walk out, "We found something about that fire knight."
"Oh really?" Moore says. "I'm going to guess they must be important, but I am very curious as to who they serve."
"His name's Lethan, a servant of the previous Oinoloth. Not a lot is known about him, thank you very much yugoloths adoring secrecy, but he's said to control the veins of fire that burn in the ground. Which is definitely true," Kaja scowls, "He wasn't seen for a long time before the Adversary took the Siege Malicious, so no one really knows if he's still serving his old master or not."
"Interesting. I wonder why he interfered with us, then." Moore says. "Can you do me a favor and find out what exactly the operation at Dimtrees was supposed to accomplish? It might explain why this Lethan decided to try and pick a fight."
"Elimination of a dao asset," Kaja says right away, "Hardly unusual the last few days."
"Then... mm." Moore frowns. "That leads to more questions, which we don't have answers to right now. But I suppose it's safe to say if there are any more operations in Hades, we should expect resistance from him and whoever else served the Oinoloth previously."
