Shadow rondo
Alicia's blade is indeed deadly. It takes five swings, but the gargoyle is cut in half. Hard as diamond but you cleave it from head to legs, two halves falling apart. Its wings fall, cutting into the ground and plunging there, narrow canyons made with no end of them in sight, no bottom glimpsed. You turn on the eye and slash it - several times, blooding it yet more. Cracks erupt around you like a tempest, but you're too strong now. You endure them and slash it open, weeping ichor from those wounds.
But in that moment it falls back, as...
HP now? Matters for something.
870+240/1150
Also I have absurd reach so will AoO if it provokes by moving.
Alicia HP: 870+240/1150
Active spells: Many moments of prescience (CL 39), extended mind blank (CL 40), extended nondetection (CL 40), greater heroism (CL 37), extended ray deflection (CL 40), epic mage armour (CL 37), sensual blessing (CL 37), greater foresight (CL 39), keen edge (CL 37 on sword), dance of the unicorn (CL 37), extended greater anticipate teleportation (CL 39), repelling shield (CL 39), freedom of movement (CL 37), greater visage of the deity (CL 37), recitation (CL 37), good hope (CL 37)
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/2/8/4/6/7/6/3
Duskblade spell slots: 6/23/23/21/11/6/16/3
Moments of prescience left: 4
[13:15] <@Ebiris> roll 1d20+103 aoo blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch
[13:15] <Kobot> Ebiris rolled 1d20+103 aoo blinding speed, 14th level arcane strike, channelled maximised/vivacious vampiric touch --> [ 1d20=10 ]{113}
[13:16] <@Ebiris> roll 6d6+62+2d6+3d6+14d4+120 and a negative level
[13:16] <Kobot> Ebiris rolled 6d6+62+2d6+3d6+14d4+120 and a negative level --> [ 6d6=19 2d6=10 3d6=11 14d4=32 ]{254}
Init is Alicia (Supreme) > Eye Horror (24) > Antenora (23)
Eye is unable to take its turn.
The follow up impales the eye anew as it falls, ripping a hole in it. Antenora flies back to your side, succor mending the acidic burns that plague your body.
220 points of healing to you. Antenora's done, she's just positioning and tending to your wounds this round, since odds are you smack things hard next round and she can clean up as needed.
Warmth. The gemstone of truth draws your gaze to the eye. The pupil opens up, a mouth larger than Hanna opening wide within it. Shiny white teeth can be seen within as from it another emerges. A man, tall and fully formed. A body of muscle and raw power, dripping with strange, globby fluids. He has no hair whatsoever and skin the color of rotted meat.  His head is bowed, no sign of awareness of movement. A slender umbilical cord of solid metal connects him to something deeper within the eye.
The man holds his hand out. In his hand a spear of the globby fluid that drips off him forms, yet stays solid. The haft of the spear has its own umbilical cord, connecting below into the eye as well.
"Madness," Antenora declares, "We will not suffer you to live, nightmare, unless you turn away from this evil."
Will saves negated by divine immunities. Your lucky day.
> roll 1d20+18 spear
<Kobot> Kotono rolled 1d20+18 spear --> [ 1d20=4 ]{22}
Init is Alicia (Supreme) > Faranos (Fell Hunter) > Eye Horror (24) > Antenora (23) > Spear (22)
Go.
Antenora
HP: 959+20/959
Resources: Holy Fury 39/42 (enc) Divine Retribution 1/1 Smite Evil 12/13 Channel Energy 17/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 24/25 Divine Blast 18/18
Spells Used:
SLAs Used:
Typical Charging Numbers: 36 for base smite damage, 72 for charging smite +2 per per level. So 108 bonus damage baseline. Raw attack plus smite is 1d8+145+2d6+2d6 (+4/+4d6 if fiendbane hits). Doesn't include other factors.
"Whatever that eye spawns should not be trusted," Alicia warns, although out of curiosity she sends a beam of silver fire curving past man and spear to cut through those cables to see what result that has.
[17:18] <@Ebiris> roll 40d10 DC 51 ref half
[17:18] <Kobot> Ebiris rolled 40d10 DC 51 ref half --> [ 40d10=243 ]{243}
Just hitting the umbilical cords with this, swifts pending the result.
Alicia HP: 1150+240/1150
> roll 1d20+53 improved evasion man
<Kobot> Kotono rolled 1d20+53 improved evasion man --> [ 1d20=2 ]{55}
> roll 1d20+12 spear
<Kobot> Kotono rolled 1d20+12 spear --> [ 1d20=7 ]{19}
The silver fire somehow misses the man's cord. He moves inhumanly fast, blurring out of the way and dragging the cord along. The spear barely reacts, following but not that fast. The blast severs the cord entirely, rich purple blood spraying from the broken cord as it flops back down. The spear begins to convulse, entire body in turmoil.
Alicia hums to herself and then sends a pair of green rays lancing out at the wire trailing behind the fast-dodging man.
Quickened limited wish disintegrate x2. Obviously if the first kills it then no need for the second.
[17:52] <@Ebiris> roll 2#1d20+53 ranged touch
[17:52] <Kobot> Ebiris rolled 2#1d20+53 ranged touch --> [ 1d20=17 ]{70}, [ 1d20=6 ]{59}
[17:53] <@Ebiris> roll 2#1d20+44 SR, (51 on the second if the first does any damage at all)
[17:53] <Kobot> Ebiris rolled 2#1d20+44 SR, (51 on the second if the first does any damage at all) --> [ 1d20=17 ]{61}, [ 1d20=17 ]{61}
[17:53] <@Ebiris> roll 2#5d6 damage if saved
[17:53] <Kobot> Ebiris rolled 2#5d6 damage if saved --> [ 5d6=14 ]{14}, [ 5d6=14 ]{14}
[17:53] <@Ebiris> roll 2#40d6 damage if not saved
[17:53] <Kobot> Ebiris rolled 2#40d6 damage if not saved --> [ 40d6=141 ]{141}, [ 40d6=146 ]{146}
DC 35 fort on those. That's her done.
Sorcerer spell slots: 6/16/16/12/9/9/14/9/9/0/8/4/6/7/6/3
> roll 1d20+12 fort 1
<Kobot> Kotono rolled 1d20+12 fort 1 --> [ 1d20=15 ]{27}
> roll 1d20+12 fort 2
<Kobot> Kotono rolled 1d20+12 fort 2 --> [ 1d20=20 ]{32}
Unfortunate luck on the 20.
Most of the spear is gone, but an outline of goopy ooze remains. It holds together if barely as...
The man slowly rises in the air.
"I am...Faranos."
He speaks as his head rises and his eyes open. Human eyes, an acid green color. His voice is that of a battlefield, of a hundred voices crying out together, death screams.
"You will die by my hand, as is only just."
"Just?" Antenora challenges.
"Die wondering." Then as a blur Faranos charges in, dying spear aimed squarely at your heart.
Provokes an AoO.
Just want to clarify. Alicia's disintegrates were not aimed at the spear, they were aimed at the cord connecting the man with the eye.
Presumably that changes things?
Strike that then, somehow completely misread. The joy of multiple combats.
> roll 1d20+47
> roll 1d20+47
<Kobot> Kotono rolled 1d20+47 --> [ 1d20=17 ]{64}
<Kobot> Kotono rolled 1d20+47 --> [ 1d20=8 ]{55}
The cord is hit but barely fazed by your attack at all. It endures it well, far stronger than it appears. Or perhaps the figure before you is.
"I am...Faranos."
Go ahead with the AoO if you wanna take it.
[19:05] <@Ebiris> roll 1d20+88 AoO with nothing going on
[19:05] <Kobot> Ebiris rolled 1d20+88 AoO with nothing going on --> [ 1d20=1 ]{89}
[19:05] <@Ebiris> roll 6d6+62+2d6+3d6 and a negative level
[19:05] <Kobot> Ebiris rolled 6d6+62+2d6+3d6 and a negative level --> [ 6d6=20 2d6=5 3d6=8 ]{95}
> roll 1d20+108 (+2 charge, +12 smite good,, +4 celestial bane, +20 true strike)
<Kobot> Kotono rolled 1d20+108 (+2 charge, +12 smite good,, +4 celestial bane, +20 true strike) --> [ 1d20=3 ]{111}
AC? I'll sort it all out at once.
113.
Also if he's casting true strike as a spell that'll provoke another from me via spellcasting harrier.
I won't take it however. Keep that as a surprise for when we make it to 666 itself.
The blow sends both of you back. Faranos is blocked at the last moment with Bonds, the impact of it a loud CRACK that sends little, stinging bits of acid all over. The sheer force of it pushes you a few steps back, the ground quaking beneath your heavy tread.
Yet you are unwounded.
From Faranos comes a cry of raw anger, of the rage of thousands no longer held at bay.
...A succubus in a hedge maze, as G'renna...
...Vrocks come down from above as you and Seira...
...Gurlan's battle cry echos...
...Antenora's spear glistens as the horde advances on herself and Muirfinn...
Memories and images from it, clear as crystal in your mind. So many, each possessed of but one desire - your utter destruction.
Go ahead and react, it matters here.
