Shadow rondo
[16:44] <@Ebiris> roll 1d20+73 ref
[16:44] <Kobot> Ebiris rolled 1d20+73 ref --> [ 1d20=1 ]{74}
Alicia HP: 1120/1150
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/7/3/5/5/4/0
Duskblade spell slots: 6/23/23/21/11/6/15/3
Moments of prescience left: 2
Quick-casts left: 0
> roll 1d20+64 improved evasion
<Kobot> Kotono rolled 1d20+64 improved evasion --> [ 1d20=2 ]{66}
Antenora none, Alicia half. This deals 180 damage, half acid and half unholy.
The acid steams off of Alicia as it reddens her skin but she looks barely ruffled by it.
Alicia HP: 1030/1150
Quick-casts left: 0
Antenora's up.
Ignore the one behind us altogether?
Keep him pinned back there while the crystal expands, don't over-commit and get caught yourself.
> roll 1d20+61 (+4 charge, +7 Alicia, +18 furious strike, +1 blinding speed, divine might used, -30 PA)
<Kobot> Kotono rolled 1d20+61 (+4 charge, +7 Alicia, +18 furious strike, +1 blinding speed, divine might used, -30 PA) --> [ 1d20=19 ]{80}
> roll 1d20+61 (+4 charge, +7 Alicia, +18 furious strike, +1 blinding speed, divine might used, -30 PA) crit?
<Kobot> Kotono rolled 1d20+61 (+4 charge, +7 Alicia, +18 furious strike, +1 blinding speed, divine might used, -30 PA) crit? --> [ 1d20=11 ]{72}
> roll 444*3
<Kobot> Kotono rolled 444*3 --> {1332}
> roll 9d8+1332+2d6+2d6+10d6+4d6
<Kobot> Kotono rolled 9d8+1332+2d6+2d6+10d6+4d6 --> [ 9d8=40 2d6=2 2d6=8 10d6=35 4d6=19 ]{1436}
Antenora's lunge is short but sharp. A balor is impaled around her to no harm, yet the light is opal blue. Several others are touche dby it and burst as well, part of the center cleared out in one strike. As this happens...
Antenora can't fail the ref save and has improved evasion.
Go Alicia.
Antenora
HP: 959/959
Resources: Holy Fury 39/42 (enc) Divine Retribution 1/1 Smite Evil 10/13 Channel Energy 15/18 Lay On Hands 555/555 Remove Disease 11/11 (week), Spiritual Connection 3/3 Blinding Speed 18/25 Divine Blast 18/18
Spells Used:
SLAs Used:
Alicia only moves onwards a little bit, not quite moving at full speed as she invokes the wind to blast all sorts of demons back towards the expanding prisons of life-absorbing crystal, following up with radiant assaults to stun them in place!
Alter reality for control winds, tornado force blast back towards the crystal. DC 50 fort negates (I think alter reality uses the same DC formula as divine SLAs? DC 35 otherwise).
Then two quickened radiant assaults at groups of enemies that were forced back against the crystal. DC 35 will to half the damage and step dazed down to dazzled.
[18:26] <@Ebiris> roll 2#1d20+44 sr for radiant assaults
[18:26] <Kobot> Ebiris rolled 2#1d20+44 sr for radiant assaults --> [ 1d20=9 ]{53}, [ 1d20=4 ]{48}
[18:26] <@Ebiris> roll 2#15d6 damage
[18:26] <Kobot> Ebiris rolled 2#15d6 damage --> [ 15d6=59 ]{59}, [ 15d6=66 ]{66}
[18:26] <@Ebiris> roll 2#1d6 rounds dazed/dazzled
[18:26] <Kobot> Ebiris rolled 2#1d6 rounds dazed/dazzled --> [ 1d6=1 ]{1}, [ 1d6=3 ]{3}
Sorcerer spell slots: 6/16/16/12/9/9/14/4/9/0/5/3/5/5/4/0
Quick-casts left: 0
> roll 1d20+33
<Kobot> Kotono rolled 1d20+33 --> [ 1d20=12 ]{45}
> roll 1d20+30
<Kobot> Kotono rolled 1d20+30 --> [ 1d20=20 ]{50}
> roll 1d20+27
<Kobot> Kotono rolled 1d20+27 --> [ 1d20=13 ]{40}
Quick check for something here, do your spells count as good aligned?
Nope, not unless I use even more metamagic on them... which actually I should've done because I'm having to burn 10th level slots on those radiant assaults after using up all my 9th level slots. I'll toss vivacious spell on them so they do double damage to evil outsiders and count as good.
Winds blow demons back, while Antenora's charge blunts the enemy ahead. Crystals spread yet further, buying you precious time. You're clear for the moment, the two of your efforts enough to momentarily check the hoard. Holy power pushes the demons back, make them bear their teeth and snarl. But you have a brief respite as your radiant assaults further blind and daze them.
Anything else this turn for you?
That was a move, a standard, and two swifts. I'm tapped out.
Init is Alicia (Supreme) > Broken Hawk (Supreme) > Balors = Nalfeshnee (30) > Wretched (30) > Antenora (23)
Sluggish and slow as the hawk man may be, even as winds roar, he lets out the same noise as last time as...
How much control over air does your spell give?
"You alter wind force in the area surrounding you. You can make the wind blow in a certain direction or manner, increase its strength, or decrease its strength. The new wind direction and strength persist until the spell ends or until you choose to alter your handiwork, which requires concentration. You may create an "eye" of calm air up to 80 feet in diameter at the center of the area if you so desire, and you may choose to limit the area to any cylindrical area less than your full limit."
Alicia's currently just causing it to blow full force in one direction away from her and Antenora and towards the crystals.
Let's just call it an opposed CL check then. Gimme one for your spell.
[17:33] <@Ebiris> roll 1d20+42 CL
[17:33] <Kobot> Ebiris rolled 1d20+42 CL --> [ 1d20=5 ]{47}
