Hidden truths
"I think it's easier to simply try a location that isn't in Hell." Moore says. "We do still owe a favor to Bel, so I'd rather not cause any upset there for right now. One moment."
He will just cast Commune with Knowledge again. May as well try it like this and see if we get anything.
'Where is one place we find a Ring of Air Elemental Command that has been forgotten?'
That would make sense...
'Where on the Plane of Air is it located?'
"One can be found in the ruins of Earthfall."
K:P or whichever is relevant here for 123 for Earthfall in case it would help me ask other questions.
'What is the most likely source of danger we'd face in Earthfall?'
Earthfall is a location in Air that Aurora battled at before your time. It had to do with Baleruk and a dragon there, and his quest to become a prismatic dragon.
Noted! Will leave the question as it is then.
A proxy of Yan-C-Bin, along with many things that are no true danger to you.
A proxy that isn't guarded enough to be detected? Tsk tsk, Yan-C-Bin.
Moore's avatar reports this information to the others!
"I don't think Akadi would be thrilled if I got into it with him again, but if they oppose us then we'll deal with it." His avatar says. "Anything else we want to ask about this location?"
Meanwhile, he'll ask a question himself to maintain the spell.
'Are there any other items of note in Earthfall we could make use of?'
For the purposes of helping you so you don't have to wonder, just assume this is 'magic items or equipment we could make use of' or even artifacts (as if they're there, but still) rather than '+1 dagger'
"Keep going for now," Sylvie says as they all consult, "And I know Aurora picked it over when it was there, so it must be hidden."
The answer is simple: None.
May as well see if he can get a more specific part of it rather than 'somewhere'...
'Where can we find the ring in Earthfall?'
Entombed within the largest cave, within several dozen feet of thick stone and metal a room before the cave in.
'Is there any particular landmark we can look for to find this cave?'
Yes, the cave with the biggest entrance.
Thanks, Oghma.
Moore dismisses the spell, since he's not going to likely get any further information out of it.
"All right, we're not looking for anything else, thankfully." Moore says. "I wonder what the proxy is doing there? Well, if we run across them we'll just shoo them off if we have to." He adds. "This should be a short operation, so I don't think we all need to go - probably just me and two others. I also expect it to be rather boring." He warns with a bit a smile.
