Hidden truths
'I see it. It's this way.' He sends to the others.
Since they can't see each other he will give them directions and guide them towards it!
As you come closer, you find your sphere of force buffers the windstorms. It's enough to let you sneak into that entrance, only a few elementals around. No sign of being noticed yet.
Moore will continue on.
Although they're being stealthy, he does decide to do something on the way. Akadi assuredly already knows they're here, but having some common courtesy goes a long way.
Lady of Air Akadi, greetings. I do not doubt you noticed us again. I thought it right to still send a courtesy message nonetheless to let you know we would be here only for a short time and then are leaving and do not wish to interfere with what is going on here.
A stirring of wind. Not quite words, but intent. Just a breeze that blows by, harmless and gentle. No sense of hostility at all.
His courtesy done, he will continue on towards the cavern!
You head in. The cavern's mostly quiet - and it's not too hard to find the room before the cave in, a fairly large chamber in any case.
While he could just blast it...
Moore will cast Wish three times for Earth Glide for the three of them and just use that to find what they're after! He'll use Arcane Sight to find it since it's probably like, in the rocks somewhere.
As said, that's exactly where it is. Deep into a wall, covered by thick stone for several feet. It's a simple chest trapped amid the stones, plain wood with metal hinges.
He should be able to just divine blast around the chest to allow him to open it, I'd think? Worst case, if there's another cave in they still have earth glide so it shouldn't be an issue.
Fine with me if that's how you want to do it.
Let's go with that, it seems the simplest plan.
Sure enough, you blow the space around it away, a little hollow for you as the chest drops to the bottom of the hollow.
Moore grabs it and puts it away!
'Let's go.' He says as he will intend to head right back the way they came in!
New round of Stealth checks.
[21:39] <Kobot> Nephrite rolled 1d20+37 Jetina --> [ 1d20=9 ]{46}
[21:39] <Nephrite> roll 1d20+48 Cresiel
[21:39] <Kobot> Nephrite rolled 1d20+48 Cresiel --> [ 1d20=8 ]{56}
Moore takes 10 for 75
