Character sheets
Started by Brian, September 11, 2006, 12:35:07 AM
Post 'em here once you finish. ;)
Bjorn
I, uh, have two.
Only one will actually be played in the end, of course, but I haven't decided which one I'll go with.  So I figured I'd post both here for the moment, partly for reference for those learning HERO, and partly so if someone has a preference for which one they'd rather play beside, they can say so.
Bjorn
Apparently there is a max of 3 attachments per post?
Edward
Okay, let's see if I can get attachments to load today. *grumbles*
Okay, I cannot.  *grumbles more*
I used to be able to load attachments just fine.  I can even load them so they appear when I select Preview.  But they won't post.
*gumble*
If you see Vampire Hikaru Shidou, it is Fox.  No one else does that.  You need no other evidence." - Dracos
"Huh? Which rant?" - Gary
"Do not taunt Happy Fun Servitor of the Outer Gods with your ineffective Thompson Submachine Gun." - grimjack
Edward
Okay, let's see if third session (and umpty-billionth time) is the charm.
Since you said the setting was going to be somewhat comedic, I tried to run with that.
Also, fixed the calculation for leaping based on p.21 of Hero 5th.
Bjorn
Revised and final version of the Gargoyle.
