Tomb Vs Animeverse, Act 3 (Recovered)
Started by Dracos, March 07, 2003, 09:29:34 PM
The below is only the recovered section.  Unfortunately not all of it could be recovered.
This will continue promptly upon my return to home this spring break.
Fearless Leader
From Panda:
Mercury attempted to scan through the wall.
Mercury found...
Rock, hard rock, volcanic rock, odd crushed bone rock, more volcanic rock and...
you guessed it...
VOLCANIC ROCK!
Fearless Leader
From Alita:
Alita moved cautiously back towards the bend in the corridor.  Once there, she tapped around on the inside of the wall, listening for differences and looking for any odd breaks or cracks in the wall.
From Figment:
Jerkily turning back towards the opening behind him, Huitzil takes a half-step before slumping a bit and halting all motion.
WARNING - INTERNAL LOGIC FAULT
WARNING - I/O SUBPROCESSOR FAILURE
ATTEMPTING TO REROUTE THROUGH AUXILIARY SUBPROCESSORS...
REROUTE UNSUCCESSFUL
ATTEMPTING TO INITIATE SUPERVISORY OVERRIDE...
SUPERVISORY OVERRIDE INACTIVE
INITIATING EMERGENCY SHUTDOWN/RESTART...
~fzzzz~
~fzzzz~
INITIALIZING...
OlmecOS v0.3 (copyright 535AD / 4 Tecaptl, Olmec Systems) online...
Running boot sequence... Boot sequence complete. Unit P4X-MM5 "Huitzil"
Online. Clockspeed 28 kHz, available RAM 132 bytes.
RUNNING SYSTEM DIAGNOSTIC...
Liquid-Argon Weapon Cooling System... OPERATIONAL
Izpapalotl Argon Laser... OPERATIONAL
Ehectal Repulsor Flight System... PARTIAL DAMAGE
Tezcatlipoca Magnetic Ensnare System... OPERATIONAL
Xolotl .04 Cubit Dual Autocannon... CRITICAL DAMAGE
Ometoeotl Geometric Transformation System... MINIMAL DAMAGE
Xipe-Totec Optic/UV/X-ray/IR scanner... OPERATIONAL
Tlahuizcalpantecuhtli Blade Extensions... OPERATIONAL
Chimalman Reflection Field Generator... MINIMAL DAMAGE
System diagnostic complete. Estimated combat capability is 83%.
Warning! Current system year is 1998 AD / 45 Tochtli. This unit is 1,397
years overdue for scheduled system maintenance. Please return "Huitzil"
unit to an authorized Olmec Systems repair and maintenance facility
(located in Chichen Itza, Chapultepec, Teotihuacan, and many other
locations) for maximum operational facility. If left unmaintained, the
argon cooling system may cause damage to multiple combat systems, including
autocannons, repulsors, force field generators, and the transformational
engine. In addition, though the copper/tin alloy "Bronze" armor is nearly
impenetrable, prolonged exposure to corrosive and humid environments may
reduce its protective capability.
LOADING USER DATA...
ERROR - USER DATA NOT FOUND
PLEASE INPUT NEW USER DATA
NEW USER DATA ACCEPTED
PRIME DIRECTIVES:
PROTECT THE LIFE OF MECHA-UNIT ALITA
PROTECT THE LIFE OF BIO-UNIT MERCURY
PROTECT THE LIFE OF BIO-UNIT RECCA
FIND A WAY TO BECOME HUMAN AGAIN
ERROR - PRIME DIRECTIVE 004 INVALID...
PRIME DIRECTIVE 004 REMOVED
AWAITING INPUT OF ORDERS...
ORDERS RECEIVED
After a brief period of inactivity, Huitzil straightens up and walks to the room with the bed/altars, where he proceeds to scan for Alita, Mercury, and Recca.
From Mercury:
Mercury made her way back to the hole they had originally come down.
"I think the bot might have been right," she said to the others loud enough to be heard. "We may have to choose another way in."
Alita finds that...
It too is solid rock!
Fearless Leader
Huitzil detects the voice patterns of biounit Mercury.
Fearless leader
From Alita:
Alita walked down the hallway into the room that Recca's flame friend had helped destroyed.
She looked around, thinking this would be the last place to find something other than SOLID ROCK!
Careful to avoid any barrels that where still burning, she took a careful look at the room and it's contents.  Trying to note any changes in wall or floor patterns, hatches, levers, etc.
"Bio-unit Mercury. Please state your location."
Alita found a smouldering corpse burned beyond recognition but still somewhat intact on the floor...but no new hatches, latches, or anything else that might indicate an exit.
Fearless Leader
From Alita:
Moving on to the hard way, Alita moved around the room, banging her blade against the wall in a last ditch attempt to find something more here to kill.
From mercury:
"Down here," she shouted back from the passage.
Mercury flew back into the room with the altars. After landing she studied Huitzil for a moment.
"Feeling better?"
From Recca:
Recca wandered towards where Mercury had come from as she passed by him and went back above to where the robot Huitzil had called from. Stopping when he finds Alita, he asks if she and Mercury had found anything yet.
From Huitzil:
"I am functioning within recommended parameters. Please state the locations of Mecha-unit Alita and Bio-unit Recca."
As he says this, Huitzil does an in-depth scan of Mercury to determine her state of health.
