Okay then, talk to Canderella next time you're at Aurora.
Lief uses the Earth node! His Strength and Constitution score rises by 1. They were both even numbers so nothing huge changes for now.
Lief finds...
Sword with a burned sheathe (from the kidnapper)
250 gold
10 small squares of ceramic, painted with a tiny dragon in flight
A bundle of smooth ebony stone sticks, bound together with a green ribbon
A map. It looks to be a simple map of the area, with a circle around the unicorn's grove
4 sealed clay bottles, probably potions
Since I forgot to prod any of you IC, did any of you take any of that treasure?
I did mention that I was taking it all.
I was waiting on the ID of stuffs before saying anything. If the sword is just mundane, I'd sorta like to keep it as a trophy. Well, once I get back to Aurora and can store it.
Quote from: Iron Dragoon on February 24, 2014, 12:18:21 PM
Okay, we'll sort it out once you all get back to Aurora.
Trivial things omitted. Things of any notable value are below from Lief's search.
4 piles of coins from coinbags and the like
6 gold ingots
Cape (magical)
Cloak (magical)
Sword (magical)
Bow (magical)
5 arrows (magical)
Breastplate (magical)
Boots (magical)
Ring (magical)
Ring (magical)
7 potions (magical)
The sword, bow, & arrows can all be stuffed into my bottomless quiver. The small stuff can be pocketed. I'll wrap up the armor & boots and bundle them under my backpack for carrying.
From the ranger dude Lief murderized:
Longsword+1, keen. 8,000 gold.
250 gold
10 small squares of ceramic, painted with a tiny dragon in flight - Each is worth 100 gold in the Eastlands. 1000 gold total.
A bundle of smooth ebony stone sticks, bound together with a green ribbon - 8 sticks of healing. Each stick can be broken as a standard action to heal 3d8+5 hit points. 750 gold each, 5250 total.
A map. It looks to be a simple map of the area, with a circle around the unicorn's grove - A map. Nothing special about it beyond information.
Potion of Hide from Undead, 50 gold.
Potion of Hide from Animals, 50 gold.
Potion of Delay Poison, 300 gold.
Potion of Invisibility, 300 gold.
874 gold.
6 gold ingots - Each is worth 500 gold for a total of 3000 gold.
Cape of Charisma+2: 4,000 gold.
Cloak of Shadow: Grants a +5 competence bonus to hide and move silently checks. Can turn the user invisible for one round three times per day, as a swift action. 12,000 gold.
Diamond Shortsword+1 - A sword somehow made of what looks to be pure diamond. The magic on it is notably ancient and decayed. Restoring the sword could result in a massive upswing in power, but altering such ancient magic won't be easy - for most. For Aurora it's doable but will be tricky. Doing so will also require some free time. Right now it merely functions as a shortsword+1 with ten times the hardness and hit points of a normal shortsword+1.
Longbow+2, frost. 18,000 gold.
5 sleep arrows. 660 gold.
Breastplate+1, grants a +2 bonus to the wearer's maximum hit points while worn. 4,000 gold.
Boots of Striding and Springing. 5500 gold.
Ring of Deflection+1. 2,000 gold.
Ring of Swimming. 2,500 gold.
Potion of Cure Light Woundsx7: 50 gold, total of 350 gold.
Coins worth a total of 2,105 gold.
Gems worth a total of 8,340 gold.
Frostrime Cloak: Grants resistance to cold 30. Gives the wearer fast healing 2 when in areas of cold, a +2 bonus to attack rolls in areas of severe cold, a +2 bonus to armor class in areas of extreme cold and damage reduction 15/adamantine in areas of unearthly cold. The various benefits stack, the wearer gains fast healing 2 and a +2 bonus to attack rolls in areas of severe cold, for instance.
Scroll of Cone of Cold: 1,125 gold.
Arrow+5, keen, icy burst, merciful and seeking. 4000 gold.
Blue Ice Shard: When held, grants a +1 bonus to the caster level of spells with the cold descriptor. If the spell deals frostburn damage, it instead grants a +2 bonus to the caster level. The shard may be used 10 times before it crumbles. 10,000 gold.
Shell Bracers: By invoking these bracers as a standard action, you gain the benefits of the tortoise shell spell (caster level 11th). 26,400 gold.
Ioneth's Reverie: This 2 foot tall statue is made of solid gold. It shows a man in deep thought, gazing at wonders unknown. 25,000 gold.
