Question about getting regular true seeing on an item.
It looks like Sylvie bought something called Fairy Glasses back in the Before Time, are those still available? http://www.soulriders.net/forum/index.php/topic,101784.msg1043800.html#msg1043800 It appears to just be glasses that function as a Hathran's Mask of True Seeing.
I think RAW an item that works like that would be 6x11x2000x2+250x100 but obviously if I can save a ton of gold by going this route that'd be great!  I can always upgrade it to the better version later.
Would a ring that covers all 5 Energy Resistances just be (44,000 x 5) / 4? I.e. 55,000?
There's two items that do this, the latter of which came up in the epic pricing redo a few weeks ago. Check out the ring of greater universal energy resistance.
Oh, I somehow missed that.
Moore has 235221.72 gold.
Okay, then a Ring of Greater Universal Energy Resistance is 300k / 4 = 75000
Moore would like to add a 1/day cast of Endure Elements onto it, so that is...
1*1*2000 = 2000
2000/5 = 400
400/4 = 100
So he'll spend an extra 100 gold for that onto the ring. Really breaking the bank here with that one.
That leaves him with 160121.72.
He's going to buy a Hathran's Mask of True Seeing but use Sylvie's motif and just turn it into a pair of glasses instead (glasses make you look smarter, you see). If the number is still the same, that's 18750 base.
He would like to add the following, so let's see if I got the math right.
Third Eye Clarity Effect (3000 *2) (MIC Doubler) * 1.5  = 9000
+15 Bonus to Appraise = ( 15 * 15 ) * 100 = 22500
+15 Bonus to Spellcraft = 22500
(Do I also need to multiply these by 1.5?)
He'd also like to have Afina make him a Quilium Threaded Cloak that he'll work some magic on, is there a cost or anything for that material?
No cost. Afina scrapes up her already broken suit of quillium full plate to salvage enough for a pixie sized cloak.
Epic Magic Item Booster 2
This is just a placeholder and a title so I can find it in a search easily. When I do the next booster for that, this will be refined and a part of it.
Ring of the Energetic Voice
This silver and emerald ring is flashy, worth several thousand gold from metal and gem value alone. When worn by a character without levels in bard, it grants a +5 competence bonus to Perform (Song) and nothing else. When worn by a bard, the ring's true powers emerge. The wearer gains a +20 competence bonus to Perform (Song) and an additional 5 daily uses of bardic music. The wearer's voice is clear and loud, the range it can be heard at doubles, including for bardic musics that function so long as they can be heard. The wearer's voice penetrates silence effects of 6th level or lower. Finally, the wearer gains a +2 bonus to the caster level of spells with the sonic descriptor.
Overwhelming varied; CL 21st; Forge Ring, carrying voice, shout; Price: 257,250 gold.
Can I just tack on a ring of protection's +5 armor to the Greater Universal Energy Resistance Ring or does it not work that way?
You can. See the rules about adding additional properties to magic items in the SRD. It's in the creation magic items section.
#2333
Okay, so then it looks like it's just the flat cost of whatever I'm adding per those instructions.
Then Let me redo the math post so I make sure I have everything:
1*1*2000 = 2000
2000/5 = 400
400/4 = 100
He's going to further add the Ring of Protection +5 to this, which according to the SRD doesn't actually cost anything since he already has the item in question and can just sell it back for the amount to get the other one enchanted. Let me know if this math is wrong.
Cost is multiplied by 1.5, so that makes it 18750. He already had the ring +5 so I think it's fair to just pay the difference, which is 6250
This creates the following: Moore's Ring of Powerful Protections - 30 resist to all types, 1/day Endure Elements and +5 Deflection AC
+15 Bonus to Spot = 22500
/4 = 16875 * 1.5 = 25312.5
That leaves him with 109059.22
He gets the Quilium-Threaded Cloak from Afina.
Finally he'll buy a Ring of Energetic voice, which should come out to 64312.5.
He's left with 44746.72.    38496.72
I will think of something to do with the cloak, but for now please just double check all the math.
Quote from: Nephrite on May 02, 2017, 01:50:59 PM
1*1*2000 = 2000
2000/5 = 400
400/4 = 100
What about the stacking modifier for adding it to an existing item?
[quote\He's going to buy a Hathran's Mask of True Seeing but use Sylvie's motif and just turn it into a pair of glasses instead (glasses make you look smarter, you see). If the number is still the same, that's 18750 base.
/4 = 16875 * 1.5 = 25312.5[/quote]
Afina's discount applies at the end, after totaling all other modifiers, including the stacking one.
#2336
Okay, then that's an extra 50 gold for the Endure Elements spell.
EDIT: I think I missed some math somewhere, so I'm going to start after the Ring of Universal energy protection and so on. Subtracting an extra 50 gold gives me 160071.72.
Oh, I forgot to include the Third Eye Clarity effect in my totals, whoops.
So in that case then it's:
76500 * 1.5 / 4 =25312.5 28687.5
This leaves him with 131384.22.
At this point he buys the Epic bard ring for 64312.5.
He then has 67071.72.
Oh, I need to add the cost of the actual mask itself too. That's 18750.
This leaves him with 48321.72
Okay. I think I finally have it all correct.
EDIT: Nope! I forgot to include the price of the +5 ring, which is 6250.
REAL final total is 42071.72
Jaela Jungle Loot
1 shield sized golden sun disc, magical.
A pile of various coins, mostly gold. Many are bigger than standard gold coins.
A small sun emblem, made of gold.
An ornate golden knife, dotted with sunstones.
Several gold forks, spoons, knives and other untensils.
A few dozen golden plates with a sun motif.
A golden handbell.
A golden vase.
A fullblade of solid gold with a sun motif.
Sorry for the delay. For some reason I had it in my head this had to be a minor upkeep post instead of sorting and pricing loot.
Jaela Jungle Loot
1 shield sized golden sun disc, magical. - 15,000 gold.
A pile of various coins, mostly gold. Many are bigger than standard gold coins. - 839 gold.
A small sun emblem, made of gold. - 250 gold.
An ornate golden knife, dotted with sunstones. 2,670 gold.
Several gold forks, spoons, knives and other utensils. - 1,183 gold.
A few dozen golden plates with a sun motif. - 940 gold.
A golden handbell. - 750 gold.
A golden vase. - 1,900 gold.
A fullblade of solid gold with a sun motif. 6,100 gold.
