Pub chat
Started by Anastasia, December 26, 2012, 11:30:09 PM
I have no objections.
It seems that I forgot to set someone up to do logs. So does anyone want to volunteer to do our logging?
There was some discussion as to the Spider being stated as a beast type, so I redid it as a insect type real quick. The only real difference is higher AVD and lower ACC. Compare and contrast with the spider posted in the Bestiary.
Variant Spider
Level 1 Normal Insect
HP 35
MP 4
ACC 1
AVD 10
PWR 2
RES 5
DEX 10
MND 2
Force 1
Finesse 3
ARM 3
M.ARM 2
Destiny -
Earth: - Fire: - Ice: - Lightning: - Water: - Wind: - Holy: - Shadow: -
Status Immunities: -
Biological Attacks: Swift Strikes
Combat Abilities: Poison Touch (100%)
Spiderfang: 2d6+5 and 100% chance of poison
Poison Spit: 2d6+5 and 100% chance of poison, can be used at medium range
I was more curious at the imp being a beast actually.
Imps made me think humanoid, though I could see Fiend as well. One of the main reasons I figured this was they used weapons and wore clothes, which I didn't really imagine beasts being able to.
Taishyr
Quote from: Anastasia on January 11, 2013, 12:56:30 PM
I can, I guess, if I have to.*
*But in all seriousness I can do this.
Thanks Tai, that would be awesome of you.
Quote from: Merc on January 11, 2013, 06:03:07 PM
My logic didn't even consider Fiend. On consideration I don't feel they're particularly fiendish, so I won't linger on that. As for beast vs humanoid? I imagine them as fairly dim that manage some scraps of civilization. The typical Imp doesn't have tendency for magic, item use or humanoid tricks that a typical humanoid has. I see them as humanoid leaning beasts rather than beast leaning humanoids.
It's close either way.
I posted the logs for the first session. Tai is probably better off doing them normally, I'll probably be distracted and fall behind if I'm on the job.
Oh, as a warning for Tai on logs: Doublecheck when you post logs that all of it gets posted, otherwise you'll want to hit modify and repost it.
For some reason, the forum doesn't like posts beyond a certain length during initial post, but you can go back and edit the post to make it the full length.
Re: Geomancy outside of battle. HP restoration is fine and that boat's long sailed with a white mage in party anyway. For game balance reasons I'm going to disallow MP healing geomancy out of battle.
Two notes. First of all, make sure your sheets on SR are up to date. This is mainly aimed at Merc since he hasn't updated his in two weeks. Secondly, I'll be posting the boss shortly. I didn't realize I forgot to Tuesday night.
I'll be posting Serrandale shops shortly. You've already been there so you know what's up. This gives y'all a chance to plan your purchases when you get back to town.
Congratulations! The party has reached level 2! Any questions about leveling up should be posted here.
