Muirfinn carefully makes his way toward Lief, staying wary for any further surprises.
[20:08] <Muirfinn> roll 1d20+33
[20:08] <Serith> Muirfinn roll for Serith < 34 >12 [d20=1]
HP: 261/300
AC: 50
Active Effects: Camouflage, Primal Instinct, Superior Resistance, Fast Healing 11
Yuth, you may want to read Ithea's action and my reply to it first.
> roll 10d6 fire damage first
<Serith> Kotono roll for Serith < 42 > [d6=3,3,6,2,4,4,5,6,3,6]
12 fire damage to all, dealing with this round's iteration of this now.
Yuth, make a Strength check if you're going into the hall.
[20:22] <Muirfinn> roll 1d20+7
[20:22] <Serith> Muirfinn roll for Serith < 8 >12 [d20=1]
Here we go!
Muirfinn is slammed down just like Lief, barely able to move his hands, let alone his head or body. He's pinned hard by the gravity, as suddenly a wall of ice forms, separating the three from Sylvie. A split second later...
> roll 1d20+28 save 1 Sylvie evasion
<Serith> Kotono roll for Serith < 40 > [d20=12]
> roll 1d20+28 save 2 Sylvie evasion
<Serith> Kotono roll for Serith < 44 > [d20=16]
No damage since she made both Ref saves.
Sylvie's voice can still be heard, muffled by the icy barrier. "Back attack!"
Initiative here. None of you can see what's up since there's a wall of ice taking the place of the disintegrated door. Lief and Muirfinn, you can't move due to the gravity, but you can make a Strength check each round to overcome it.
[20:30] <Muirfinn> roll 1d20+20
[20:30] <Serith> Muirfinn roll for Serith < 22 >12 [d20=2]
[21:30] <Dark_Mercury> roll d20+22+5 init
[21:30] <Serith> Dark_Mercury roll for Serith < 39 > [d20=12]
> roll 1d20+21 Init
<Serith> Iddy roll for Serith < 37 > [d20=16]
Conditions: Ongoing heat damage (10d6 a round), astral flight (10ft speed per point of Intelligence, perfect maneuverability), automatic spell quickening (spells are automatically quickened), timelessness (time does not pass normally, creatures do not age/hunger/thirst, items do not decay, wounds do not heal without magic).
> roll 1d20+24 Sylvie
<Serith> Kotono roll for Serith < 26 > [d20=2]
> roll 1d20+5 1
<Serith> Kotono roll for Serith < 19 > [d20=14]
> roll 1d20+6 2
<Serith> Kotono roll for Serith < 12 > [d20=6]
> roll 1d20+9 3
<Serith> Kotono roll for Serith < 13 > [d20=4]
Initiative is: Ithea (39) > Lief (37) > Sylvie (26) > Muirfinn(22) > ?1 (19) > ?3 (13) > ?2 (12) > Environmental Damage (0)
Open Ithea. The wall of ice stops you from seeing anything of what's going on. Ahead is the hall and the stairs going down, all heavy with unnatural gravity. Notably, the Astral's flying property is suppressed in the hallway due to the gravity, though normal means of flying can still fly.
Ithea flings another disintegrate at the wall, grumbling under her breath as she does so. Then she attempts to aid Lief and Muirfinn with the gravity.
OOC: Posting disintegrate rolls as the quickened spell action. Not sure if I just roll strength or what to help the two out with their own troubles. If I can't help them, I'll probably just keep moving forward and let Sylvie drag the devils in or have her come in and Muirfinn/Lief lock them out.
[21:49] <Dark_Mercury> roll d20+30 ranged touch
[21:49] <Serith> Dark_Mercury roll for Serith < 33 > [d20=3]
[21:49] <Dark_Mercury> roll 40d6 disintegrate
[21:49] <Serith> Dark_Mercury roll for Serith < 138 > [d6=5,6,1,3,1,1,2,1,4,5,3,3,3,5,5,4,6,1,2,5,6,4,5,5,6,5,2,3,4,3,2,4,3,3,2,3,3,2,3,4]
You can help them, it'll grant both of them a +3 bonus on the Strength check or one of them a +5 bonus. Up to you on how you split that up.
No, it's automatic. You're doing alright with the gravity and with your modifier, you can't fail the roll.
OOC: Fair enough. I'll help Lief only. He needs the help much more, and Muirfinn can probably get dragon strength going too.
A quick blast of magic dissolves the wall of ice before you, turned into dust. As you go to help Lief, you can see three figures. Three gelugons in the entrance to the chamber, flanking the party from behind.
Lief, you're up. Go.
